A3204eva
747 - Gear Up....
Wed Aug 24, 2005 11:30 pm
Ok, Most aircraft put their gear up once they have a positive climb, but the 747 even when it has a positive climb seems to wait a little longer to retract the gear... why is this?
any 747 pilots out there I would love to hear from U!
Scott
"They have lady pilots......... they're not that good, but they have 'em"
RE: 747 - Gear Up....
Thu Aug 25, 2005 9:10 pm
Quoting A3204eva (Thread starter):
Never noticed this really.If its a rare occasion I would attribute it to brake cooling.
regds
MEL
air2gxs
Thu Aug 25, 2005 9:25 pm
I've jumpseated on many B747's and the gear always goes up at the same time; when the PF says "gear up".
A3204eva
Thu Aug 25, 2005 11:12 pm
They always seem to take longer tho.. here's a vid from FL350 http://www.flightlevel350.com/viewer.php?id=3706 . If you look at any 747 takeoff vid they always take a while to retract the gear...
Thx for the replies  Smile
PhilSquares
Thu Aug 25, 2005 11:44 pm
I can assure you as soon as there is a "positive rate" there is a call for the gear up! However is you look closely at the clip, you'll see the first thing that happens is the gear doors open and then retraction begins. The gear door opening doesn't happen very quickly and that is why you get the impression there is some sort of delay.
Fly fast, live slow
highflyer9790
Fri Aug 26, 2005 4:29 am
The 747's gear system is not old, but on the other hand, it isn't new. take a look at these takeoffs in the clip. gear is retracted at the same time, but the doors& wheels mover quicker on different aircraft.
http://www.flightlevel350.com/viewer.php?id=4139
121
DH106
Fri Aug 26, 2005 4:24 pm
Slightly off topic - but has anyone else noticed that the DC-10's retraction sequence differs from most others (certainly all Boeing I've seen) in that the gears begin to pivot inwards BEFORE the door is established fully open. The door however does seem to open faster than most. It seems that the gear and the door start moving together - the gear slower so that it doesn't foul the opening door.
This presumably is done to minimise the total retraction time ?
Are there any protection mechanisms to stop the gear retracting if the door fails to open ? On other airliners I believe that the retraction hydraulics are sequenced so that the gears only move when the doors reach their 'open' limit switches.
Any comments ?
...I watched c-beams glitter in the dark by the Tanhauser Gate....
Mr.BA
Fri Aug 26, 2005 4:38 pm
I suppose "Gear-Up" is called after the "Positive Rate of Climb"? I noticed B747s near MTOW retract their gears as soon as after lift-off... does the calls come much earlier thatn those that are lighter or pilots retract the gears earlier to minimise drag?
Boeing747 万岁!
jeffry747
Sat Aug 27, 2005 4:59 pm
Quoting DH106 (Reply 7):
I have noticed this not only on the DC-10, but EVERY McDonnell-Douglas commercial jet aircraft. Yup, the DC-8s, DC-9s, MD-11s, and MD-80s all do that.
C'mon Big B, FLY!
Sat Aug 27, 2005 5:44 pm
Observed many B747s on T/O last night at work.Found them to be retracting at almost the same speed.Although the mvmt seemed slower than smaller jets retraction speed.
regds
MEL
DH106
Sat Aug 27, 2005 5:45 pm
Quoting Jeffry747 (Reply 9):
Yes - you're quite right Jeffry747  Smile
Here a good shot of a DC-8 showing this:-
https://www.airliners.net/open.file/893404/L/
A3204eva
Sun Sep 04, 2005 12:36 am
Thx for the info guys  Smile
Scott
Sun Sep 04, 2005 1:16 am
Quoting DH106 (Reply 10):
Photo © Michael Van Bosch
Why the red border on the RH Side Window.
regds
MEL
XFSUgimpLB41X
Sun Sep 04, 2005 3:33 am
Thats an emergency exit....
Chicks dig winglets.
Sun Sep 04, 2005 6:14 pm
Quoting XFSUgimpLB41X (Reply 13):
Agreed.But why is it painted Red.All Airlines dont do it.
Even the B737s out here dont.
regds
MEL
Users browsing this forum: acmx and 22 guests
