B752 Integral Inflation Valve Pressure Gauge.
Tue Aug 30, 2005 11:12 pm
Explain the B752 Integral Inflation valve Pressure Gauge.
regds
MEL
air2gxs
RE: B752 Integral Inflation Valve Pressure Gauge.
Wed Aug 31, 2005 9:37 am
What's to explain? It is a stem mounted gage that has 3 color bands: Red, Yellow, and Green.
We use them only on our through flights. We will use a tire pressure gage on all other checks.
Anything in the yellow or red requires a tire pressure gage to confirm the reading.
They do not have any pressure indications except for the colors.
And no, I don't have pictures.
amtrosie
Wed Aug 31, 2005 12:59 pm
Mel wants to know about a URL link.
Sorry Mel, it had to be done!
Wed Aug 31, 2005 6:11 pm
Quoting Air2gxs (Reply 1):
Quoting Amtrosie (Reply 2):
Guess We are all on the same Frequency as mine  Smile
Are these Gauges reliable.If so why use the TPG.
regds
MEL
air2gxs
Wed Aug 31, 2005 9:28 pm
Mel,
It's not that they are unreliable, but they only show a range of pressure. The green band only indicates that the tire is at its rated pressure, not the actual pressure. The yellow band tells you that the tire may be in need of servicing, it does not tell you how much.
I should also tell you that we have been removing all our indocator stems because we determined a lot of mechanics were jsut using the indicators and not performing the prerssure checks with the gage when required.
Wed Aug 31, 2005 10:56 pm
Quoting Air2gxs (Reply 4):
Thanks.Thats Interesting Information.I guess Mx tends to get Lazy when the Indicator is around  Smile
Is this feature only common to the B757s.
Out here its the Good O'l TPG for all Wheels on the B737s.
regds
MEL
dl757md
Thu Sep 01, 2005 12:14 am
Quoting HAWK21M (Reply 5):
At DL the 57 doesn't have the indicator stems but the 738 does. It just depends on the airline.
DL757Md
amtrosie
Thu Sep 01, 2005 11:27 am
I have seen these gauges on varying A/C. It is not specific to an aircraft type. I found them to be a hassle because flt. crews would insist that mx. be called if "it isn't in the green band" When I was contract, this was an easy money maker, when I worked direct, what a pain!
Thu Sep 01, 2005 12:51 pm
Quoting Amtrosie (Reply 7):
But if the Indicators are reliable,then if its not in the Green band.It would need Recharging.
regds
MEL
air2gxs
Thu Sep 01, 2005 10:46 pm
Quoting HAWK21M (Reply 8):
There you have it. The indicators are not as reliable as we would like them to be. They are mechanical devices subject to extreme mechanical stresses. The ones I know about aren't even temperature compensated.
They are (were) basically used as reference devices. The flight crews treated them as the gospel.
Fri Sep 02, 2005 12:36 pm
Quoting Air2gxs (Reply 9):
That makes sense then.So Mx double checks with a TPG with the Indicators shows a Doubt.
regds
MEL
Users browsing this forum: No registered users and 19 guests
