Claude
Ram Air Turbine
Fri Oct 21, 2005 1:31 am
Hi everyone!
I was wondering if Embraers,Bombardiers,Boeings,Cessnas models have RAM...?
(i know All models of Airbuses have.)
planesailing
RE: Ram Air Turbine
Fri Oct 21, 2005 1:37 am
Search Ram Air Turbine on the photos search page.
MD-11, 767, Canadair RJ's seem to have them.
michaeljp
RE: Ram Air Turbine
Fri Oct 21, 2005 1:38 am
I cant be certain so dont quote me on this but I do remember hearing one time its compulsary to have.
Once again I'm not 100% sure on this though.
Mike
typhaerion
RE: Ram Air Turbine
Fri Oct 21, 2005 1:39 am
I know all Boeing Aircraft have them...
Claude
RE: Ram Air Turbine
Fri Oct 21, 2005 1:40 am
thanks for your answer Planesailing!
Claude
RE: Ram Air Turbine
Fri Oct 21, 2005 1:41 am
Thanks for your answer Typhaerion!
FI642
RE: Ram Air Turbine
Fri Oct 21, 2005 1:47 am
The MD11's is called an "ADG" Air Driven Generator.
N1120A
RE: Ram Air Turbine
Quoting MichaelJP (Reply 2):
No, it isn't
Quoting Typhaerion (Reply 3):
The most popular Boeing aircraft of all time, the 737, does not carry a RAT
Claude
RE: Ram Air Turbine
Fri Oct 21, 2005 1:51 am
no RAT on 737 ... wow...
that's surprising!
thanks for your post N1120A!
Claude
RE: Ram Air Turbine
Fri Oct 21, 2005 1:52 am
Thanks for your answer FI642!
typhaerion
RE: Ram Air Turbine
Fri Oct 21, 2005 1:53 am
Wow, whoops. Thats what I get for assuming and not cross checking to AIPC.
Our 757s and L1011s have them, so I assumed our 737s did too. And if they did, I figured all did.
Thank you for correcting me. I would hate for bad information to get out.
a/c dxer
RE: Ram Air Turbine
Fri Oct 21, 2005 1:55 am
Not all the 757's have them either.
N1120A
RE: Ram Air Turbine
Fri Oct 21, 2005 1:57 am
Quoting Claude (Reply 8):
that's surprising!
The 737 is not particularly reliant on electricity. While manipulating the yoke would be more difficult, it would still be perfectly able to fly. The A32S on the other hand does have a RAT because of the reliance on electricity
Quoting Typhaerion (Reply 10):
No problem, that is what we are here for
RE: Ram Air Turbine
Fri Oct 21, 2005 1:58 am
747s do not have RATs. Windmilling engines provide enough for power and hydraulics in case of all engine failure.
Quoting N1120A (Reply 7):
The reason that the 32x has a RAT and teh 737 does not is because of the mechanical linkages on the 737. You simply need less power to control the 737. If you don't have enough power/hydraulics on the 32x there is no way to move most of the control surfaces.
[Edited 2005-10-20 18:59:49]
RE: Ram Air Turbine
Fri Oct 21, 2005 1:59 am
that's surprising!
With Three Hydraulic Isolated systems & Manual reversion.Its not needed.
regds
MEL
Claude
RE: Ram Air Turbine
Fri Oct 21, 2005 3:40 am
"The 737 is not particularly reliant on electricity" that's it!
Thanks N1120A
Anyone for informations for the Embraers models?
jetfixer
RE: Ram Air Turbine
Fri Oct 21, 2005 3:54 am
Quoting N1120A (Reply 12):
Not entirely true. If the A320 loses of all 3 Hyd system pressures, you're probably not gonna make it.
N1120A
RE: Ram Air Turbine
Fri Oct 21, 2005 3:59 am
Quoting Claude (Reply 15):
I would assume that all the new E-jets (E170-195) have RATs because they are Fly by wire
OldAeroGuy
RE: Ram Air Turbine
Fri Oct 21, 2005 4:05 am
Quoting A/c dxer (Reply 11):
Every 757 has a RAT to provide hydraulic power to the Center hydraulic system in the event of a dual engine failure. The 737 doesn't need a RAT as the primary flight controls have manual reversion and can be moved with pilot yoke input only.
Airmech56
RE: Ram Air Turbine
Fri Oct 21, 2005 5:13 am
What about the 27?
I must write useless sentence so that my question of of little value(according to forum rules) is displayed.
roseflyer
RE: Ram Air Turbine
Fri Oct 21, 2005 5:36 am
CRJ-100/200s (as well as the Global Express) do have RATs (Ram Air Turbines).
The Cessna Citation does not have a RAT as far as I know. I don't know of any other Cessna products that would have RATs.
RE: Ram Air Turbine
Fri Oct 21, 2005 6:15 am
Quoting Jetfixer (Reply 16):
Sure, and that's why it has a RAT. To ensure that there is pressure despite the engine generators being online.
LongbowPilot
RE: Ram Air Turbine
Fri Oct 21, 2005 1:56 pm
I smell a RAT! Damn, I hate it when that happens.
jetfixer
RE: Ram Air Turbine
Sat Oct 22, 2005 11:33 am
[quote=Starlionblue,reply=21]Quoting Jetfixer (Reply 16):
Starlionblue,
I suggest you read the above quotes again, N1120A makes it sound like the A320 has a RAT because or its reliance on electricity. I'll say again, not entirely true. The RAT pressurizes the BLUE hydraulic system. From pressure in the blue system an emergency generator can be driven. The A320 RAT does not directly supply power. The Airbus can fly without power, but will not fly without Hydraulics, hence the A320 RAT's primary purpose is hydraulic.
CosmicCruiser
RE: Ram Air Turbine
Sat Oct 22, 2005 11:54 am
Quoting Airmech56 (Reply 19):
What about the 27?
If you mean a 727, no it does not have one.
No one mentioned the DC-10. It has an ADG.
RE: Ram Air Turbine
Sat Oct 22, 2005 1:54 pm
Quoting Jetfixer (Reply 23):
Lets put it this way.With no Manual reversion available like the B737.The A320 being FBW needs a RAT.
regds
MEL
KBGRbillT
RE: Ram Air Turbine
Mon Oct 24, 2005 3:12 pm
Quoting FI642 (Reply 6):
Same on the DC-10-30 series as well.
RE: Ram Air Turbine
Sun Nov 20, 2005 3:00 pm
Starlionblue,
Ok thx for the clarification. But the fact remains that the RAT spins and somewhere electricity is produced for something  Wink But you are quite right that hydraulics drive the surfaces, not electrics.
RE: Ram Air Turbine
Sun Nov 20, 2005 5:03 pm
Does the B744 have a RAT.
regds
MEL
CosmicCruiser
RE: Ram Air Turbine
Sun Nov 20, 2005 10:37 pm
One must be very very careful when saying ALL have them. The 727 did not have a RAT.
RE: Ram Air Turbine
Mon Nov 21, 2005 12:02 am
Quoting CosmicCruiser (Reply 29):
Add the B737 to that list  Smile
regds
MEL
RE: Ram Air Turbine
Mon Nov 21, 2005 12:10 am
Quoting HAWK21M (Reply 28):
Nope. The windmilling of even one engine is enough to provide hydraulics and electrics.
RE: Ram Air Turbine
Mon Nov 21, 2005 12:16 am
Quoting Starlionblue (Reply 31):
What stops a Windmilling Engine on other type Aircraft providing Hydraulics & Electrics.
regds
MEL
Jetlagged
RE: Ram Air Turbine
Mon Nov 21, 2005 11:53 am
Some hydraulics yes (enough for flight controls at least), but not enough rpm to get the generator on line. However, you have three other engines with generators and an APU with two as backup. In the event of a four engine flameout, there's the DC battery and inverter running the standby busses.
pilotpip
RE: Ram Air Turbine
Mon Nov 21, 2005 2:01 pm
Citations don't have RATs, their control surfaces are cable actuated. 172s, however, have been known to revert to RAT status when the pilot doesn't have enough fuel to get where he's going. As far as Embraer, the 170/190s have them, as mentioned but the 135/145s do not.
474218
RE: Ram Air Turbine
Mon Nov 21, 2005 2:02 pm
L-1011 Ram Air Turbine (RAT) provides hydraulic power in the event of three engine failure. Standby battery provides electrical power. Battery can also be used to start APU.
RE: Ram Air Turbine
Mon Nov 21, 2005 7:29 pm
Quoting HAWK21M (Reply 32):
Well, as Jetlagged kindly corrected, other planes don't have 4 huge engines like the 747.
RE: Ram Air Turbine
Mon Nov 21, 2005 8:20 pm
Quoting Starlionblue (Reply 36):
Does the A340 have a RAT.
regds
MEL
EMBQA
RE: Ram Air Turbine
Mon Nov 21, 2005 10:37 pm
All commercial aircraft either have a RAT or enough battery power to safely land the plane. I think the ruling is that a manufacture can omit the RAT, but must provide enough battery power to run the aircraft emergency back-up systems for 'x' amount of time. That is why larger commercial aircraft use RAT's as the weight of the batteries would be huge. The Embraer 135/140/145 do not have RAT's, but the Embraer 170/175/190/195 do.
SlamClick
RE: Ram Air Turbine
Tue Nov 22, 2005 12:10 am
Quoting Starlionblue (Reply 13):
Quoting CosmicCruiser (Reply 24):
So, production numbers being as they are, I guess it is safe to say most Boeing aircraft don't have a RAT.
RE: Ram Air Turbine
Wed Nov 23, 2005 3:52 am
Quoting SlamClick (Reply 39):
... he said while smugly grinning Big grin
Quoting HAWK21M (Reply 37):
Good question actually. Pity I don't know... But considering 330/340 commonality they might just have left it in there.
Tristarsteve
RE: Ram Air Turbine
Wed Nov 23, 2005 4:26 am
Quoting Jetlagged (Reply 33):
Sounds good but the B747 APU will not start in flight.
The Vickers VC10 had two RATs. One electric and one hydraulic.
Jetlagged
RE: Ram Air Turbine
Wed Nov 23, 2005 6:12 am
Quoting TristarSteve (Reply 41):
Yes it will, but probably not at cruise altitude after a cold soak. If I was in an emergency situtation I'd certainly try and start it. It may not be certified for in flight use, but there is no system logic preventing it being started.
[Edited 2005-11-22 22:19:02]
IFIXCF6
RE: Ram Air Turbine
Wed Nov 23, 2005 11:44 am
Not on a 744. One of the common mistakes of new technicians is to have the scissors (nose steering links) disconnected, placing the aircraft in the "air", and wondering why the APU won't start.
Mike
RE: Ram Air Turbine
Wed Nov 23, 2005 5:13 pm
Considering the Time it was flying not Surprisingly.Now both can be Incorporated into one RAT indirectly.
Quoting IFIXCF6 (Reply 43):
Does the B747 not take MLG Air-Grd Sense too.
regds
MEL
Users browsing this forum: Max Q and 14 guests
