zarniwoop
Hold At Idle Thrust
Fri Dec 09, 2005 7:58 pm
Was listening to JFK tower over the internet yesterday and noticed that when some departing planes were cleared to hold on the runway they were told to hold at "idle thrust" by ATC. Why so? What else are they going to do? Hold at take off power with the brakes on.........???
Tristarsteve
RE: Hold At Idle Thrust
Sat Dec 10, 2005 3:06 am
During icing conditions, especially when freezing fog is around, ice tends to build up on the fan blades at taxi power. So before take off the engines are run up to 70% to shed the ice off the fan blades before setting take off power. This is very noticeable here at ARN where we have a lot of SAS MD80 who practise this. This is consequent to the crash back in 1990?. So the tower will often ask them if they intend to do run up, or immediate take off.
fr8mech
Sat Dec 10, 2005 5:19 am
Which runway(s) in use?
Ice could be the issue. At low power settings, the bleed air system may not produce enough air or hot enough air to adequately run the engine anti-ice system. So, the engine are run at a higher setting to produce the necessary results.
Another possibility is that the departure end of the runway in use may be perpendicular to another runways threshold. Landing traffic could be adversely affected by an engine running at higher power settings. Not very likely since it would mean aircraft landing and departing 90 degrees apart, but in the era of noise abatement, who knows?
Mir
Sat Dec 10, 2005 10:14 am
JFK tells traffic in position on 31L to hold at idle thrust when traffic is landing on 4R (traffic landing on 4R passes quite close behind the planes on 31L).
This generally happens in the early morning when the 4s have been in use overnight, and the 31s (which I believe have more capacity) are starting to be used.
-Mir
A300605R
Sun Dec 11, 2005 3:03 am
I've seen an Aer Lingus B735 at FRA holding on 25L with take off thrust set for about two or three minutes. Dried up the wet runway behind and made a great sound as well...
300 319 320 321 332 733 734 735 738 753 763 F27 M83
SlamClick
Sun Dec 11, 2005 3:31 am
Quoting Zarniwoop (Thread starter):
Well, if my engines will make my three hundred and fifty thousand pound airplane go five hundred miles per hour how much of my thrust would it take to make your two thousand pound Cessna go two hundred miles per hour upside down and backwards over the airport fence?
Even idle comes pretty close to that figure.
"Hear that captain? An ELT - and nearby too!"
Sun Dec 11, 2005 11:47 am
Quoting TristarSteve (Reply 1):
The Gottr�ra crash was caused by sheets of ice detaching from the wings and being sucked into the engines on takeoff, not icing in the engines themselves. Icing in the engines is different. The running up of engines before takeoff will not affect wing icing.
2H4
Sun Dec 11, 2005 12:18 pm
During especially foggy conditions, pilots have been known to strategically position themselves near the runway transmissiometers, select higher-than-idle power settings, and enjoy their on-time departures.
2H4
Intentionally Left Blank
Dakar
Sun Dec 11, 2005 3:30 pm
Not to hijack the thread, but what website did you use to listen to internet ATC communications?
Thanks, Nick
Mir
Sun Dec 11, 2005 4:52 pm
www.liveatc.net has a good JFK feed.
-Mir
zarniwoop
Sun Dec 11, 2005 10:44 pm
Thanks for your replies everyone!
Quoting Mir (Reply 3):
-Mir
Thats exactly the situation when i was listening
Quoting Mir (Reply 9):
-Mir
Thats the site I was using to listen to the JFK tower.....
SlamClick
Mon Dec 12, 2005 12:43 am
Quoting 2H4 (Reply 7):
Now that is just a rumor that got started by ATC asking us not to do that anymore.
 Wink
Users browsing this forum: No registered users and 18 guests
