Cargolux Incident.
Thu Jan 26, 2006 5:32 pm
Photo © Elizabeth
Anyone having details of what exactly transpired.
https://www.airliners.net/discussions...eneral_aviation/read.main/2570127/
is being discussed in Civil Forum.
Was the Gear selecter lever moved to check for Hyd leak from upline without Lock pinning the gears.Anyone aware of details.
regds
MEL
[Edited 2006-01-26 09:44:09]
PhilSquares
RE: Cargolux Incident.
Thu Jan 26, 2006 5:55 pm
Quoting HAWK21M (Thread starter):
The gear was supposed to be pinned. Obviously, it wasn't, gear lever was cycled for troubleshooting. The rest is history.
Fly fast, live slow
Matt72033
Thu Jan 26, 2006 6:42 pm
why isnt weight on wheels logic built into gear retraction?
jush
Thu Jan 26, 2006 7:12 pm
Quoting Matt72033 (Reply 2):
I always thought it is anyway. But as you clearly see it's not but it might be on newer planes than the 744.
Whose fault was it? How much is it going to cost?
Regds
jush
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
MD11Engineer
Thu Jan 26, 2006 7:24 pm
There is but you can override it e.g. for MX purposes or to retract the gear in flight if the WOW sensors fail.
Jan
PhilSquares
Thu Jan 26, 2006 7:50 pm
There is the "lever latch over-ride" that you can use to raise the gear handle when the ground logic is active.
Fly fast, live slow
Matt72033
Thu Jan 26, 2006 8:10 pm
Quoting MD11Engineer (Reply 4):
why would you need to override it for mx?
surely the only time you want the gear to retract for maintenance is when the aircraft is jacked!
Mr.BA
Thu Jan 26, 2006 9:18 pm
And just wondering what problems or errors in the system would require the recycling of the landing gears?
Boeing747 万岁!
fr8mech
Thu Jan 26, 2006 9:27 pm
Quoting Matt72033 (Reply 6):
There are a few reasons. Leak check the upside of an actuator. Check the indication logic. Check the switches in the gear handle. It's done often.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Matt72033
Thu Jan 26, 2006 9:33 pm
Quoting Fr8mech (Reply 8):
right, so when you do this you stick the pin in and cycle the gear?surely if your doing this you double check that that pin IS in! i know i would be!
fr8mech
Thu Jan 26, 2006 10:00 pm
Quoting Matt72033 (Reply 9):
In fact, usually an item is put in the logbook stating the fact that the gear pins are installed.
The nose gear on the B747 is a difficult one to install. It's up in the lock mechanism and you need to climb up the gear to install it. If there is no flag attached to the pin, its quite easy to miss it. Its also easy to think that the pin is in, if you don't know exactly where to look on the gear. That's why of the 6 gearpins on the B747 (steering pin included) we make sure the nose pin has a flag. The others a fairly easy to see.
Matt72033
Thu Jan 26, 2006 11:03 pm
Quoting Fr8Mech (Reply 10):
ours are on a long pole, the actual pole extednds down to well below the gear door so its very visible if its still in!
don81603
Fri Jan 27, 2006 2:07 am
Okay, this is going to sound like a stupid question, and feel free to laugh as hard as you like, but would it be possible for them to extend the nose gear (after making sure it's still operational) to lift the nose off the ground, then tow it away and make the repairs, or do they have to jack it up and tow it away for repairs?
Eagles may soar, but weasels don't get sucked into jet engines.
Matt72033
Fri Jan 27, 2006 2:29 am
Quoting Don81603 (Reply 12):
they have to jack it, they often slide a biginflatable under and inflate it to lift it off the ground!
Fri Jan 27, 2006 2:46 am
Quoting Mr.BA (Reply 7):
Cheking a suspected leak on the Upline side of the Gear Actuator after installing the Lock pins.
regds
MEL
Fri Jan 27, 2006 2:52 am
Quoting Matt72033 (Reply 13):
I don't think the gear extension mechanism is anywhere near strong enough to lift the plane (what would be the point). The gear is only fit to hold the plane when it's locked.
EDIT: The exception to this rule might be planes that can kneel, like the An-124, where the nose gear will compress to allow loading from the nose door. However I believe the gear is actually in the down and locked position when it compresses. So in this case, with the gear in the well, the feature still wouldn't help.
[Edited 2006-01-26 18:55:17]
Poitin
Fri Jan 27, 2006 4:06 am
Looking at the photograph, I notice that at least one in-board engine is touching the ground. Wouldn't that suggest damage to the pylon and wing spare is possible?
Now so, have ye time fer a pint?
Nudlaug
Fri Jan 27, 2006 9:36 am
Would it be possible for them to extend the nose gear (after making sure it's still operational) to lift the nose off the ground, then tow it away and make the repairs, or do they have to jack it up and tow it away for repairs?
The 747 Nose gear extends via free fall, so since no hydraulic is pushing the gear down it would be impossible to lift the aircraft up by extending the nose gear. It would just sit on the floor doing nothing.
cancidas
Fri Jan 27, 2006 10:55 am
this is like the second time it's happenned... i need to stop taking home those pins i find out on the ramp...
"...cannot the kingdom of salvation take me home."
2H4
Fri Jan 27, 2006 11:00 am
I'm sure most of you have heard this one, but I'm reminded of it anytime gear pins are mentioned:
While taxiing out in sequence behind a Lufthansa airliner at Frankfurt, a C-130 crew noticed an orange "Remove before flight" streamer hanging out of the Lufthansa nose wheel well (their nose gear locking pin was still installed). Not wanting to cause too much embarrassment by going thru the controller, the 130 crew simply called the Lufthansa aircraft on the tower frequency: "Lufthansa aircraft, Herky 23." No reply.
They repeated the transmission and again there was no reply. Instead, the Lufthansa pilot called the tower and asked the tower to tell the Herky crew that "the professional pilots of Lufthansa do not engage in unprofessional conversations over the radio."
The 130 pilot quickly replied, "Frankfurt tower, can you please relay to the professional pilots of the Lufthansa aircraft that their nose gear pin is still installed?"
2H4
Intentionally Left Blank
Mr.BA
Fri Jan 27, 2006 12:51 pm
I remember about a posting here about a CI B744 at TPE not having their pins removed amid warnings from pilots and they ended up taking off and having to dump fuel and return. Was a long haul flight and I think they did waste some fuel!
It'll be interesting to know how the LH pilots reacted!
Boeing747 万岁!
Sat Jan 28, 2006 12:41 am
Quoting 2H4 (Reply 19):
Is that a true story or an Aviation tale.
regds
MEL
pilotwhale
Mon Jan 30, 2006 8:16 pm
Reading this exchange with interest. Since I am not a mechanic/engineer can someone explain the procedure involving a B747 - or point to a site that can. I tried google and it referred me to this thread. And, by the way, this has also happened to Eva Air in London, Singapore Airlines in Changi, Qantas and Korean Air in Sydney and China Airlines in Taipei - so someone must have written about it publicly!
Mon Jan 30, 2006 11:38 pm
Quoting Pilotwhale (Reply 22):
The procedure of lifting the plane?
They have to jack it up somehow, then lower the gear. This could be done with inflatable bladders and/or jacks, or even a large crane. Once the plane is up, the gear is lowered and this time I bet they won't forget the pins.
2H4
Mon Jan 30, 2006 11:45 pm
Quoting HAWK21M (Reply 21):
I've only ever read it online, so I'm not sure how true it is.
2H4
pilotwhale
Tue Jan 31, 2006 10:21 am
No, the procedure for preparing a B747 for towage and then preparing it for departure without use of a tow truck -i.e. how pins inserted and then removed. Any advice?
fr8mech
Wed Feb 01, 2006 9:37 am
In order to tow a B747 you must:
-install a steering bypass pin or depressurize #1 hydraulics.
-pressurize #1 hydraulic system (body gear steering) or pay very close attention to your turn radius.
-pressurize #4 hydraulics for brakes.
-gear pins don't need to be installed (though some operators require them for maintenance tows).
Matt72033
Wed Feb 01, 2006 6:10 pm
Quoting Fr8Mech (Reply 26):
we always use the nose gear pin for towing!
fr8mech
Thu Feb 02, 2006 9:59 am
Quoting Matt72033 (Reply 27):
We only use the nose gear downlock pin on the DC8.
Thu Feb 02, 2006 8:30 pm
Quoting Fr8mech (Reply 28):
Is it because a possibility of the Towbar pressure unlocking the Downlock.
regds
MEL
AvionicMech
Thu Feb 02, 2006 9:22 pm
The only time an aircraft of ours is towed without gear pins is on push-back, every other time all three pins must be installed. It is just not worth the risk, and I am sure anyone who has been onboard during an extended tow will testify to say how bumpy it can be on those taxiways especially with very little fuel and no pax. Also there are some new tug drivers who are not the smoothest at pulling away and stopping which puts extra stress on the nose gear.
fr8mech
Thu Feb 02, 2006 9:36 pm
Quoting HAWK21M (Reply 29):
One of the reasons is that the aircraft has no APU. With no APU, you can't have hydraulic power. The downlock on the aircraft is pretty flimsy, in my opinion, and with only accumulator pressure...bad things may happen.
Fri Feb 10, 2006 9:37 pm
Photo © Jeffwell
Photo © Jeffwell
The rectification commences.
Any idea why the Pic on the Left has the FMC/MDL attached.
regds
MEL
airbusA346
Sat Feb 11, 2006 6:00 am
Quoting HAWK21M (Reply 32):
FMC/MDL
What's an FMC/MDL.
Tom.
Tom Walker '086' First Officer of a A318/A319 for Air Lambert - Hours Flown: 17 hour 05 minutes (last updated 24/12/05).
fr8mech
Sat Feb 11, 2006 6:06 am
Quoting AirbusA346 (Reply 33):
What's an FMC/MDL
A main deck loader. FMC is probably the best known manufacturer of this type of loader.
Mon Feb 13, 2006 1:21 pm
What's an FMC/MDL.
Main Deck loaders Used to load Pallets in Cargo Decks.
regds
MEL
airbusA346
Mon Feb 13, 2006 5:39 pm
From pictures I have seen.
There were stairs at the main door when the incident happened and they had to use step ladders to get into the aircraft.
Photo © Elizabeth
There is probably a FMC at the aircraft in place, ready for loading of the pallets into the aircraft.
Tom.
satx
Mon Feb 13, 2006 8:57 pm
What a mess. I would feel so bad if I was in charge when this happened. Any guess how much this would cost to resolve?
Quoting Cancidas (Reply 18):
:D
A300 319 320 321 332 333 388 B727 732 733 735 737 738 739 742 743 744 752 753 763 764 772 77E 77L 773 77W 788 789 C200 700 900 DHC2 DC9 E145 170 175 190 F100 MD81 82 83 87 88 90 | 38 Lines 44 Craft 58 Ports
Tue Feb 14, 2006 4:22 pm
Quoting AirbusA346 (Reply 36):
Unless this pic was taken when the Loading ops was in progress.Amazing that the FMC was not struck.Which gives evidence to believe it was positioned later maybe to access the aft area.
What about the Pallets on board.
regds
MEL
