AvionicMech
RE: B752 Mx Experience
Sat Apr 08, 2006 2:04 am
Another one to remember, but this is true for most aircraft I would have thought is to make sure the electrical power source is not swapped during an FMC Nav Database update as this can kill the FMC.
A/c train
Sat Apr 08, 2006 2:48 am
Ive just been reminded about doing the stall warning test when the Hyd pumps are on, the slats will come out and if you lock yourself out of the flight deck, shut the APU down on the nose leg.
Sat Apr 08, 2006 5:43 pm
Quoting A/c train (Reply 51):
This Autoslat Function was told to us in Training.
Pls elaborate.
regds
MEL
SkydrolBoy
Thu Apr 13, 2006 12:30 am
Quoting HAWK21M (Reply 52):
Pls elaborate.
By shutting down the apu, it will turn off power and unlock that fancy new bulletproof door if it has an electronic lock.
Thu Apr 13, 2006 3:08 am
Quoting SkydrolBoy (Reply 53):
What is the Circuit like for U/s APU in Flight.
regds
MEL
fr8mech
Thu Apr 13, 2006 6:16 am
Quoting HAWK21M (Reply 54):
regds
No issue inflight. The aircraft is still powered. What Skydrolboy is saying is that if the aircraft is on the ground on APU (or ground powe, I assume) and you lock yourself out of the flightdeck, just kill power to the aircraft.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Thu Apr 13, 2006 5:20 pm
Quoting Fr8Mech (Reply 55):
I understood what was meant.What I was curious was.Was the solenoid only de energized on Grd with no power.But in Air has no effect.What caused it.The Air-Grd sense.
regds
MEL
A/c train
Thu Apr 13, 2006 6:32 pm
HAWK21, there is a switch under a red guard in the flight deck witch you switch on to lock the door, kill the power on the nose leg, you de-energise the switch. Air grnd sense??? looking too deep into this I think!
Thu Apr 13, 2006 7:25 pm
Quoting A/c train (Reply 57):
Whats stops an APU shutdown in Flt from Unlatching the Locked door then.
regds
MEL
A/c train
Thu Apr 13, 2006 8:07 pm
The two great big 110 lb IDG's on both engines may do it ?
fr8mech
Thu Apr 13, 2006 8:59 pm
Hawk, the key is power. Power on, door stays locked. Power off, door is unlocked. No need for a/g sense. APU is just a source of power.
AvionicMech
Thu Apr 13, 2006 9:56 pm
Would it not be easier and probably quicker to just enter the access code into the keypad and wait for it to go through the auto-unlock sequence?? Not only would it be quicker but it would mean that the APU is not shut-down without having time to cool down and then having to be re started once you get into the flightdeck.
Fri Apr 14, 2006 2:27 am
Quoting Fr8Mech (Reply 60):
Ok.So presuming on Ground,APU off,but GPU selected.The Door won't unlock.
regds
MEL
SkydrolBoy
Fri Apr 14, 2006 3:43 am
Yank the powercord....
Fri Apr 14, 2006 5:48 pm
Ok.Thanks.
regds
MEL
Users browsing this forum: No registered users and 39 guests
