lehpron
My Proposal For Reducing Impact Of Wake Vortices
Thu Apr 06, 2006 12:20 pm
I came up with this idea maybe last week, please criticize. I have not done any CFD analysis or anything, this is fresh out of my mind and mainly done with thought experiments and MS paint.
I will make many suppositions.
From what I'm reading here, one of many problems with making planes large like A380 (or whatever Y3 ends up being) is their wake vortices. Here's my proposal: I called it a stepped wake wortex wing.
Take a gander at the picture below:
Both wing sections are supposed to have the same half-span, reference area and aspect ratio with respect to each other. The first wing piece is supposed to represent a generic slender wing with a raked wingtip device.
The spanwise flow leads to the tip swirls (vortices), that is, the entire wing "pushes" that air out over the tips. The amount is less than 20% but significant, its turbulent. I'm wondering if some of this flow were allowed to "leak" mid-span, what will happen to the remainder? I figure the resulting spanwise flow will act as if it were supporting less weight, as if it were a smaller wing.
The second wing scetion is supposed to imply that approximate half of the wake leaks over the top of the wing while the other half swirls around the wingtip. I theorize that, in effect, the vortex at the outboard wingtip has less strength.
In a real airplane application setting, instead of having two large wake vorticies, we have four smaller ones. One immediate problem that came to mind waas vortex wing interaction issue with the tailplane. Since vortices do stick to the surface due to being spools of lower pressure, maybe the downwash may carry them underneath, I don't know for sure.
Engine placement however gave me a headache. It seems whether they would be place inboard or outboard of the raked step in the wing, they would have to be oriented such that the intake aims more down and inwards than they are on airplanes now. I'm not certain about sticking the engines in the rear, a la DC-9. Issues may be similar to the tailplane discussed above.
My personal preference, without doing any airflow analysis, I'd place the ngines underwing and inward of the step. I.e. for the right wing pictures the engine would be left of the step, like the pylon would be right at the corner.
[Edited 2006-04-06 05:45:24]
viv
RE: My Proposal For Reducing Impact Of Wake Vortices
Thu Apr 06, 2006 9:35 pm
I see only a red 'x', so cannot comment.
joness0154
Thu Apr 06, 2006 10:34 pm
Here's my problems with a design like that:
Fuel tanks?
Leading edge devices?
Wing chord?
Basically, any benefit from this would be negated by having to add weight for the complex stuff needed for it all to work out....
[Edited 2006-04-06 15:35:46]
I don't have an attitude problem. You have a perception problem
pilotaydin
Fri Apr 07, 2006 12:23 am
Won't the mini change in sweepback cause it's own local drag? thus cancelling any reduced drag from the design itself?
and will that short chord after the taper produce less lift? needing to make the roots of the wing thicker?
Other than that, let's get testing!!
The only time there is too much fuel onboard, is when you're on fire!
Skyslave
Fri Apr 07, 2006 12:29 am
Any chance you could host that picture through image shack? http://imageshack.us/
Its not comming up for me.
Fri Apr 07, 2006 1:01 am
Quoting Lehpron (Thread starter):
Wouldn't Outbd of the Step be more logical.Inbd if righ near the step would negate its very purpose.Just my thought.I would have thought Tail mounted powerplants too.
What about LED distribution.
regds
MEL
OldAeroGuy
Fri Apr 07, 2006 4:27 am
I think you will have a difficult making the second planform's induced drag be as low as the first planform.
Sectional lift coefficients on the outboard wing for the second planform will also be an issue.
Economically, the second wing would never be adopted.
greasespot
Fri Apr 07, 2006 6:19 am
It is one thing to shoot the idea down....But aviation is full of "it will never work contraptions"....
This is what the wow factor is.....Someone has an idea and goes with it....
I think that we have missed a lot by being born now in this airplane world. Back in the 50's it seemed that if you had an idea someone would try and build it....
That is what is cool about aviation....
GS
PS...look at how excited we were when the 787 was first concepted...then the "ugggh" when it was changed to look like a regualr plane...
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
Staffan
Fri Apr 07, 2006 7:22 am
Quoting Greasespot (Reply 7):
It has much to do with the fact that it's considered better to evolutionize than to revolutionize. Introducing to many big changes at once, may give you some bad surprises down the road.
The aviation industry growing, but the number of fatal accidents aren't. And that's no coincidence.
Boeing7E7
Fri Apr 07, 2006 8:35 am
Where possible, put the heavies on a 3.00 degree approach glideslope and the non-heavies above them on a 3.30 degree slope. If you need CAT II/III put them on 2.80 and 3.10.
[Edited 2006-04-07 01:36:31]
rolfen
Fri Apr 07, 2006 9:46 am
What about putting vertical separations on the wing to reduce the spanwise flow? Sort of what the caravelle had, but more angled, with the front being closer to the fuselage and the back being further away.
Your design seems ok, but from my limited knowlegde, I feel that leaking part of the flow will sort of short-circuit the the wing and might require bigger wings for the same load.
[Edited 2006-04-07 03:11:10]
rolf
joness0154
Fri Apr 07, 2006 12:25 pm
Quoting Boeing7E7 (Reply 9):
Well you'd need 4 different Glideslope antenna's then. Thats 4x the cost of what it is already, 4x the maintenance, etc. Then you'd need 4 different frequencies. It'd get out of hand real fast!
If you put people on a 2.8 glideslope you might not have adequate obstacle clearance, etc.....and people on a 3.3 degree slope would have to chop and drop.... not good for the engines.
WingedMigrator
Fri Apr 07, 2006 1:52 pm
Before we get all Navier-Stoked... let's get back to basics.
Nobody has yet pointed out that to first order, the strength of the wake is determined not so much by the wing shape, but instead by the aircraft's mass and how slow it's moving.
In order to stay aloft, an aircraft must shove downwards a large flow of air. This is simple conservation of momentum, and no voodoo aerodynamics need be invoked to explain this. The magnitude of this flow (per unit distance) depends on
1) mass. The more massive the aircraft, the more air it has to shove downwards, and the stronger the wake.
2) speed. If the amount of air shoved downwards per unit time is proportional to mass, and if the speed diminishes, then the amount of air shoved downwards per unit distance increases, and the stronger the wake.
So, to first order, the strength of the wake is given by how big and how slow. There's no way around that.
Then come the aerodynamic tricks, having to do with making the wake vortices, inevitably produced by the downward flow, dissipate as quickly as possible. But keep in mind these are only second order effects...
speedracer1407
Fri Apr 07, 2006 5:19 pm
This subject is pretty far out of my league, but I'd like to take a shot at it anyway.
In order to support a large aircraft with Lephron's proposed wing, the pan wouldn either need to be greately increased to account for the sudden reduction in chord, or the inboard chord would need to be very thick indeed. Since wing span is the most likely limiting factor given current airport terminal limitations, it seems that the inboard section of Lephron's wing would need of an enormous chord length, and thus bear the vast brunt of the lifting duties. Wouldn't the midspan vortices on this wing be, therefore, severe enough to reduce or eliminate the advantages of dividing wake turbulence/vortices along the span in the first place?
O
viv
Fri Apr 07, 2006 5:51 pm
Quoting WingedMigrator (Reply 12):
Ummmm, not so.
Lift comes from the pressure differential between the upper and lower surfaces of the wing. This pressure differential occurs because the upper surface is convex, so that air passing over the wing has to travel further than air passing under it.
Staffan
Fri Apr 07, 2006 6:47 pm
Quoting Viv (Reply 14):
Ummmm, not so.
How can a longer travel distance above the wing the way you describe result in a pressure difference?
Answer: It can't.
As the air is deflected downwards by the wing, a lower pressure region will appear on top of the wing. It's this lower pressure that accelerates the air over the top. The wing's lift is proportional to the amount of air that is deflected downwards. Newtons third law.
[Edited 2006-04-07 11:48:53]
joness0154
Fri Apr 07, 2006 7:05 pm
Quoting Staffan (Reply 15):
Answer: It can't.
A little picture I made while drunk
Staffan
Fri Apr 07, 2006 7:16 pm
In your sketch, why does the air aft of the trailing edge not have an angle downwrds? With air moving horizontally under the airfoil meeting up with air at a downward angle from the top of the airfoil, wouldn't it be logical that the resulting flow would have a slight downward angle? That downward flow would be proportional to the airfoil's produced lift.
The venturi theory is flawed:
http://www.grc.nasa.gov/WWW/K-12/airplane/wrong3.html
[Edited 2006-04-07 12:17:33]
joness0154
Fri Apr 07, 2006 7:30 pm
Quoting Staffan (Reply 17):
Cause I was drunk when I drew it  Smile it will flow downwards.....haha
They say the venturi model is flawed, but this is the lame explanation they give:
"Lift occurs when a moving flow of gas is turned by a solid object. The flow is turned in one direction, and the lift is generated in the opposite direction, according to Newton's Third Law of action and reaction. Because air is a gas and the molecules are free to move about, any solid surface can deflect a flow. For an aircraft wing, both the upper and lower surfaces contribute to the flow turning. Neglecting the upper surface's part in turning the flow leads to an incorrect theory of lift."
That is the weakest theory I've heard. Coming from NASA no doubt.
But theories are theories, and there are always more than one so i'd happily believe another one if it could be explained to me...
Skyslave
Sat Apr 08, 2006 12:08 am
http://www.grc.nasa.gov/WWW/K-12/air....html
Heh, I think you need to read up on Bernoulli's Principle. If you dont want to take the time, he basically states that the higher the velocity, the lower the pressure. Although newtons 3rd does create lift, Bernoulli's principle also contributes. There are some wing designs, however, that dont use Bernoulli's principle, like a aerobatic wing. They have a cemetrical camber so when flying inverted there is no uneven liftage.
edit: Also, the air moving along the bottom of the wing meeting up with the air at top of the wing doesnt create any lift. By the time air joins back together aft of the wing, the lift process is done for that "unit" of air. The downward deflection comes from the angle of incidence between the airframe and airfoil (Airplane longitudinal Axis vs. The chord line).
[Edited 2006-04-07 17:14:38]
[Edited 2006-04-07 17:27:17]
grandtheftaero
Sat Apr 08, 2006 3:08 am
*SIGH* Yet another innocent life lost because someone was mishandling Bernoulli's principle. How much more can we take? Think of the children!
Jetlagged
Sat Apr 08, 2006 4:07 am
Quoting Skyslave (Reply 19):
How do these wings "know" when to use Newtons laws or Bernoulli's theorem
BTW remember to use spell check next time (cemetrical) and what on earth is liftage?
The answer is that both concepts explain lift and can be used interchangeably. You can't add the two effects together! What is wrong is to use the venturi idea to explain the change in velocity over a wings surface. Bernoulli's theorem does not properly explain the velocity changes, but it does correctly predict the pressure distribution that arises.
Note, for a venturi, the velocity change is calculated using the continuity equation:
density * area * velocity = constant
Bernoulli's equation can then be used to calculate static pressure changes.
A flat plate basically produces lift by momentum change (Newtonian), but there is also a pressure differential between upper and lower surfaces. You can measure the lift with pressure tappings or a force gauge and get the same answer.
Please, no more Newton versus Bernoulli arguments and keep the simplified explanations of lift out of supposedly serious posts.
Regarding Lephron's wing proposal, the structures people would have nightmares. Such drastic changes in planform would seriously affect structural strength and fatigue resistance. Straight taper to the outboard section would be better, rather than that sudden kink.
[Edited 2006-04-07 21:12:24]
FredT
Sat Apr 08, 2006 5:49 am
Long wings = vortices far apart = good and efficient / weak vortices.
Short wings = vortices close = bad and inefficient / strong vortices.
You have basically created half a short wing combined with half a long wing. Sorry.  Smile
Boeing7E7
Sat Apr 08, 2006 6:16 am
Quoting Joness0154 (Reply 11):
You set up the glideslope for the prefered glideslope angle and use GPS for the other. Eventually LAAS for both.
Where practical. Plenty of major airports out there without obstructions that can accomodate 2.80 vs the existing 3.00.
[Edited 2006-04-07 23:18:23]
Sat Apr 08, 2006 6:31 am
Ouch, painful. But I must admit you see this flawed view of lift in many respectable encyclopedias and taught in many high school physics classes. Shame on them.
Having said that, the principle is not entirely wrong. I found this explanation for lift: http://travel.howstuffworks.com/airplane5.htm (read on for a few pages). It's the only one I have found so far that explains lift in easy terms without a lot of math (though in the end they admit that you pretty much need math to get an accurate result). This passage summarizes the problem:
If you read any college-level aerodynamics textbook, you will find plenty of mathematical methods for calculating lift. Unfortunately, none of these explanations are particularly satisfying unless you have a Ph.D. in mathematics.
There are many simplified explanations of lift that appear on the Internet and in some textbooks. Two of the most popular explanations today are the Longer Path explanation (also known as the Bernoulli or equal transit time explanation) and the Newtonian explanation (also known as the momentum transfer or air deflection explanation). While many versions of these explanations are fundamentally flawed, they can still contribute to an intuitive understanding of how lift is created.
[Edited 2006-04-07 23:32:25]
Jetlagged
That won't make much difference to the problem, especially closer to the threshold, where a 0.3 degree difference in glideslope angle makes just over 5 feet difference vertically.
lehpron
Sat Apr 08, 2006 8:20 am
Nice to see what looks like health discussion on fresh ideas.  Wink
Quoting Pilotaydin (Reply 3):
The intended purpose of this idea was not to reduce drag, but toInitially, This wing proposal was supposed to be the same drag and thus performance, etc.
Quoting HAWK21M (Reply 5):
Yeah I see what you mean. Any spanwise flow would technically run up against the engine. But if that was the case, then it would seem the spanwise flow outboard of any engine in the quad-jet setup would support all of the vortex...! Unless the outboard wing on those aircraft outboard of the #1 and #4 engines were repplaced with giant raked wingtips, that just sounds weird, I don't know about that.
Quoting OldAeroGuy (Reply 6):
maybe not any time soon, I was speaking from an aerodynamics perspective.
Upon thinking of ways to make it work, may I pose another question: What is the velocity of the spanwise flow at the tip of a generic wing? It is a vector quantity, so coupled with freestream, it should be less than the speed of sound. Knowing the variation of spanwise velocity would help in determining if/how this could work. How would you do it?
Would varying the approach angle be the cheaper route? Granted, the proposal is with respect to approach, not cruise.
I get the impression of an idealized wake if actual wing shape doesn't greatly affect it. My current common sense (which is growing) tells me if I don't use a wing and go for a lifting body, I'd see a change in wake pattern. What am I missing?
Quoting Jetlagged (Reply 21):
I can't picture that completely, could you draw something or find an example online?  Smile
Quoting FredT (Reply 22):
Aspect ratio...hey I tried. Big grin
Boeing7E7
Sat Apr 08, 2006 11:06 am
Quoting Jetlagged (Reply 25):
There's a 20' difference in the threshold crossing height between the types of aircraft that would use each slope, dictated by the slope. The higher slope woudl be at Aircraft arrive at that cross point and effectively flare to a standard 3.0 slope at the threshold and beyond to touchdown. This is how the FAA intends to mediate much of the problem in conjunction with ADS-B so obviously it works. The higher TCH used by smaller aircraft would cause them to touch down about 800' further down the runway than the aircraft on the lower slope.
Quoting Lehpron (Reply 26):
More than likely. In cruise with free flight, it's not a major issue because of flexible routing.
OldAeroGuy
Sun Apr 09, 2006 3:44 am
And my reply is from an aerodynamic perspective. The second wing is uneconomic based on higher induced drag alone, not to mention the structural and construction issues. Ponder FredT's reply.
Staffan
Sun Apr 09, 2006 6:54 am
Thanks, will do  Wink
