I'll start this off with this little question.
What is the "La Guardia bend" mean when pertaining to the 767?
Please feel free to add any Technical Triva questions you like.
Quoting DALMD88 (Reply 3): LGA in someplaces is built on piers. To spread out the weight load the gear on the 767 is bent. |
Quoting Fr8Mech (Reply 6): The LaGuardia bend can also be called the SFO bend. The B767-100 could not land at either LGA or SFO because of runway loading. In order to alleviate this problem Boeing and I believe Goodrich redisgned the gear so that the gear footprint is wider. This added width caused a clearance problem in the wing root. Hence the little pop-up door on top of the wing. As the gear cycles, the top of the strut passes through the door. |
Quoting Dl_mech (Reply 7): Question #3: How do you put a 767 on Ground Service power from the cockpit? Let's assume external power is on the A/C and the switch on the F/A panel is not used. |
Quoting Dl757md (Reply 10):
OK. I give up. Do tell |
Quoting Dl_mech (Reply 11): Assume external power is already powering the A/C. 1) Place throttles full forward. 2) Turn off Stby power and External Power from the Cockpit panel. 3) Return Throttles to idle. The plane is now on Ground Service. This works on DL's 767's and may not work on other configurations (not sure about 764). I tried it on a 757 and it didn't work. I was shown this at work by someone who was shown by an instructor. Sorry, I don't have a manual reference. I thought it was pretty cool. |
Quoting Deltamike172 (Reply 5): Well, I don't know if the correct answer is up there, but I'll throw down Question #2: What is an ATCAA? -DM |
Quoting Deltamike172 (Reply 5): What is an ATCAA |
Quoting Matt72033 (Reply 16): start the APU? wouldnt that bring up the APU page automatically? |
Quoting Kaddyuk (Reply 17): Hillarious... What if you've Just shut down the APU and you have no ground power? The ECAM screen goes blank because its not part of the "essential" instruments and the batteries are shedding all non-essential loads... |
Quoting Matt72033 (Reply 18): how do you do it then? and why would you do it? i can't really see a point to it! |
Quoting HAWK21M (Reply 15): Whats an AFOLTS card. |
Quoting MX757 (Reply 22): So, how did I do |
Quoting Kaddyuk (Reply 24): Which instrument in the cockpit can be used to listen to commercial radio stations |
Quoting AvionicMech (Reply 25): Thats an easy one!!! The ADF can be tuned to MW stations such as 909 (Radio 5 Live) for the sport when you are working in the flightdeck. |
Quoting AvionicMech (Reply 32): Of Course it is, but I am thinking more like the ice cream. |
Quoting Kaddyuk (Reply 33): Currently you can find marble cake in Galley #2 on flights from the USA and i must tell you... It is to DIE for... :P |
Quoting KELPkid (Reply 28): obviously not something you'd want to use in actual IMC |
Quoting AvionicMech (Reply 34): Yeah but I am sure your airline probably has slightly better catering that we have |
Quoting Miamiair (Reply 35): Fairings attached at the inboard end of the inboard mid flap... |
Quoting Kaddyuk (Reply 38): The Cessna Diamond is that award given to the unattentive pilots who happen to make contact with the trailing edge of the wing of a cessna. Forming a neat diamond shaped scar on the forehead... |
Quoting Miamiair (Reply 35): Quoting HAWK21M (Reply 29): Which Part on the B737s is called "Elephant Ears". Fairings attached at the inboard end of the inboard mid flap... |
Quoting VC-10 (Reply 20): Q4. What is a Denver Go Vlv? Q5. Where would you find a Wiffletree? Q6. On what system would you find the smallest dia cable on a DC10 and what is the dia? |
Quoting HAWK21M (Reply 40): How does this look like exactly.What causes the Diamond shape. |
Quoting Fr8mech (Reply 45): Sailboat on a B747 (classic). |
Quoting Fr8mech (Reply 45): Donkey Dick on a DC8. |
Quoting Fr8mech (Reply 45): Doghouse on a B747 (classic). |
Quoting Fr8mech (Reply 45): Elephant Ear on a B727. |
