miamiair
RE: Technical Trivia
Wed Apr 12, 2006 12:21 am
Quoting Matt72033 (Reply 48):
nope, its rear part of the pylon that splits open
What part of the 727 pylon splits open? AFAIK, the trailing edge is a riveted wedge.
kaddyuk
Wed Apr 12, 2006 12:39 am
Quoting Miamiair (Reply 50):
He didnt mention the 727 we're talking about the '74
Ahhh... Where the hydraulics are? I know where you mean... The outboard ones are so friggin heavy, they're an absolute ARSE! LoL!
[Edited 2006-04-11 17:40:34]
[Edited 2006-04-11 17:42:01]
Matt72033
Wed Apr 12, 2006 12:41 am
Quoting Kaddyuk (Reply 51):
He didnt mention the 727 we're talking about the boeing
the 727 is a boeing  Wink
thats the chappy
kaddyuk
Wed Apr 12, 2006 12:42 am
Quoting Matt72033 (Reply 52):
the 727 is a boeing
Alright... Edited because i'm too lethargic today...
miamiair
Wed Apr 12, 2006 2:32 am
Where is the Hell Hole in the 727?
How many leading edge slats does the 707-300 have?
DC-8, has slots or slats?
ReidYYZ
Wed Apr 12, 2006 3:01 am
I know Iv'e already revealed the answer, hoping for short-term memories and even shorter attentoin spans:
Why is it you lose primary flight control indications on eicas when you pull eng oil pressure cb's. Left engine: lh aileron and elevator, Right engine: rh aileron and elevator as well as rudder? (rudder may be on Lh eng)
This may be more common knowledge than I think: A330/A340 mlg shortening mechanism: Why both aircraft, for different reasons?
MX757
Wed Apr 12, 2006 3:37 am
Quoting Miamiair (Reply 54):
Answer: The 48 section.
Answer: 0. The 707-300 has L.E. Kruger Flaps.
Answer: Slots.
[Edited 2006-04-11 20:39:15]
Is it broke...? Yeah I'll fix it.
miamiair
Wed Apr 12, 2006 3:53 am
Quoting MX757 (Reply 56):
707 does have slats. All leading edge devices outboard of the inboard engines are slats. Inboard of the inboard engines are Kruger Flaps. Ref: 707-300 IPC, ATA27.
MX757
Wed Apr 12, 2006 4:02 am
Quoting Miamiair (Reply 57):
Okay, well I guess 2 out of 3 ain't bad.
KELPkid
Wed Apr 12, 2006 4:06 am
Quoting HAWK21M (Reply 40):
Quoting Kaddyuk (Reply 38):
The Cessna Diamond is that award given to the unattentive pilots who happen to make contact with the trailing edge of the wing of a cessna. Forming a neat diamond shaped scar on the forehead...
How does this look like exactly.What causes the Diamond shape.
regds
MEL
Hi MEL,
The trailing edges on the wings of a single-engined Cessna are taken up entirely by the control surfaces (inboard flaps, outboard ailerons). Well, Cessna control surfaces use the skin itself as a structural component (for the most part), so spaced every 3 to 4 inches, there is a diamond-shaped corrugation in the metal.
An inattentive ______ (fill in the blank: pilot, instructor, ramp worker, first-time GA passenger) will receive a rude awakiening when they walk into the trailing edge of the wing, and experience one of these unprotected corrugations for the first time  Wink And it doesn't help that for most people, the wing on the 150/152 or 172 is about forehead level.
I'll see if I can snap a picture in the next day or two when I drop by the airport...
Brent
Wed Apr 12, 2006 5:00 am
Quoting KELPkid (Reply 59):
Did you know this site has over a million pics of aircraft?
Photo © Aernout ten Hulscher
Photo © Alex McMahon
Photo © Luc Willems
[Edited 2006-04-11 22:00:46]
DH106
Wed Apr 12, 2006 6:56 am
I think we're just arguing nomenclature here - but I'm pretty certain all the 707's LE devices would be called Kruger's, or else a similar type of flap hinged at the LE and folding under the wing when stowed.
A slat, when deployed runs out on a track forwards and down, and when fully deployed leaves a slot between itself and the wing. They're usually airfoil shaped.
A Kruger deploys by pivoting down around a hinge set on the LE. They're usually much more flat shaped - especially on the 707.
Here's a good photo showing the full span Krugers - they all pivot down from the LE:
https://www.airliners.net/open.file/1013492/L/
...I watched c-beams glitter in the dark by the Tanhauser Gate....
SkydrolBoy
Wed Apr 12, 2006 8:46 am
Heres one for you guys,
Which commercial aircraft was the first to come with an apu from the factory???
MX757
Wed Apr 12, 2006 9:24 am
Quoting SkydrolBoy (Reply 62):
727?
aogdesk
Wed Apr 12, 2006 10:11 am
B737-100??
Original 727 APU wasn't OEM judging from its location
SkydrolBoy
Wed Apr 12, 2006 12:55 pm
You got it MX757, the 727 was the first aircraft to come with an APU.
OK next question, on factory original 727-100's what does the "APU" light on the FE's annunciator panel indicate???
DH106
Wed Apr 12, 2006 4:47 pm
Quoting SkydrolBoy (Reply 65):
The APU needs waitress service?  Smile
VC-10
Wed Apr 12, 2006 5:22 pm
What about the BAC One-Eleven in 1963?
Wed Apr 12, 2006 9:36 pm
APU Abnormal Shutdown......A guess.  Smile
regds
MEL
Wed Apr 12, 2006 9:48 pm
The APU was not part of the original design. And weren't there props with APUs in the 40s/50s?
fr8mech
Thu Apr 13, 2006 6:25 am
APU fuel valve open, I believe.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
474218
Thu Apr 13, 2006 7:02 am
Quoting DH106 (Reply 61):
Correct answers DH106:
A Leading Edge Flap when extended will not create a Slot between the Flap and the Wing.
A Leading Edge Slat when extended will create a Slot between the Slat and the Wing.
As stated in another reply the DC-8 wing had Slots, but they are a fixed part of the Wing Structure.
The 707-300 in the picture has Kruger Flaps = Leading Edge Flaps.
Mainliner
Thu Apr 13, 2006 7:14 am
The exhaust exit door (if installed) is open?
Every flight counts.
SkydrolBoy
Thu Apr 13, 2006 8:11 am
Quoting Fr8Mech (Reply 70):
Quoting Mainliner (Reply 72):
Both of you are correct, on original 100's there was an exhaust exit door, and when the light was on indicated that the door was open, on -200's and modded 100's(without the exit door) the light indicates the fuel valve is open.
Quoting VC-10 (Reply 67):
Sorry my bad, after some research the 727 was the first BOEING aircraft to come with an APU, not sure on which a/c was the actual first to come with an APU.
avt007
Thu Apr 13, 2006 2:17 pm
Some early turboprops came with a sort of APU. The Convair 580 had what they called a GTC- gas turbine compressor. It was used for starting the engines, but did not have a generator, so wasn't called an APU. Bloody noisy thing, though!
SkydrolBoy
Thu Apr 13, 2006 4:12 pm
Quoting Avt007 (Reply 74):
Actually some CV-580's did have an APU, some a/c had it mounted in the tail while others had what we call an upside down GTC, its basically the same as the GTC but was more powerful and had a generator (the reason it was called an upside down GTC is that it was the same basic model as the standard but the intake was on the bottom instead of the top.)
We just brought up a CV-240 that had an APU in it. It was a two-cylinder air cooled piston engine with generator mounted to it.
DH106
Thu Apr 13, 2006 4:38 pm
Quoting 474218 (Reply 71):
Yes, the slots were formed by doors in the main wing surface near the LE opening inwards. The spanwise extent of these slots is actually quite small on the DC-8, limited to an area inboard of each engine only - the outer engines having a larger slot for some reason.
dl757md
Sat Apr 15, 2006 10:21 am
Quoting Dl_mech (Reply 11):
Assume external power is already powering the A/C.
1) Place throttles full forward.
2) Turn off Stby power and External Power from the Cockpit panel.
3) Return Throttles to idle.
The plane is now on Ground Service.
Finally got a chance to try it out last night on ship 1404. Works as advertised. Have tried it on several 764s though with no luck.
Neat trick
DL757Md
SFOMB67
Sat Apr 15, 2006 1:17 pm
OK, I have to get in on this with my favorite : where is the SOB fairing on a 767? If you ever replaced or rigged this, you won't forget it.
VC-10
Mon Apr 17, 2006 12:59 am
Looking at my copy of Boeing 707-720 Reference Guide (Boe Doc D6-40942) it says the 707 has 3 L.E. Flaps per side & 10 L.E. Slats per side.
miamiair
Mon Apr 17, 2006 9:56 am
I agree with everything you wrote, but the "slats" on the 707 are not simply hinged, but articulated; and they do leave a slot. This is the difference between the Kruger flaps and the slats. This was done so that the inboard end of the wing would stall first. The 707 slats evolved to the variable camber devices found on the 747.
MD11Engineer
Mon Apr 17, 2006 10:56 am
Ok, where is the snake pit on a 737?
Jan
474218
Mon Apr 17, 2006 11:08 am
Quoting VC-10 (Reply 79):
In Reply 61 there is a picture of a 707-720 wing, do the Flaps/Slats extend further forward until the line up with the mark on the nacelles?
Mon Apr 17, 2006 1:56 pm
Quoting MD11Engineer (Reply 81):
Near Main Distribution Manifold,Aft wall of Fwd Cargo Compt.
regds
MEL
VC-10
Mon Apr 17, 2006 4:52 pm
Quoting 474218 (Reply 82):
Yes
SFOMB67
Tue Apr 18, 2006 5:18 am
Did we establish the correct answers for these ?
Quoting Fr8mech (Reply 45):
What is:
Sailboat on a B747 (classic).
We always called it the sail-tail fairing (behind the pylon)
Doghouse on a B747 (classic).
cabin storage compartment in front of a bulkhead
Donkey Dick on a DC8.
What is a Plasta-Jet (early term).
DH106
Tue Apr 18, 2006 4:41 pm
Quoting Miamiair (Reply 80):
Yes - I take your point about the articulation & slot, but never the less in an engineering sense they do pivot down around a 'notional' LE hinge point rather than sliding out on a track. It's obviously all really in the name, but I'd regard these as slotted Kruger's, Boeing calls them slats.
Do the variable camber 747 devices leave a slot ? I didn't think so.
MD11Engineer
Tue Apr 18, 2006 7:06 pm
Quoting DH106 (Reply 86):
No, they don't.
Jan
MX757
Wed Apr 19, 2006 7:39 am
This is a two part question:
Photo © Peter Vercruijsse
Question 1: This particular 747SP has a famous nickname. Name it.
Question 2: Besides the damage stated in the picture, there is some permanent damage not mentioned. Figure out what that is.
MX757
Wed Apr 19, 2006 7:47 am
Quoting MX757 (Reply 41):
What part on the DC-9/MD-80 are called "Elephant Ears"?
Quoting MX757 (Reply 43):
Quoting Miamiair (Reply 42):
Guess would be the Main Gear Wheel Well Doors?
Nope, guess again.
Are there no other takers?
SFOMB67
Wed Apr 19, 2006 1:30 pm
Quoting MX757 (Reply 88):
Don't know the nickname, but if this is the plane that made an emergency landing at SFO after the named incident, I seem to remember something being bent. Like maybe a wing spar???
DH106
Wed Apr 19, 2006 5:20 pm
Quoting MX757 (Reply 89):
Nope, guess again.
Elevator trim handles?
hangarrat
Wed Apr 19, 2006 10:32 pm
"The Dive Queen"
I can't recall, or find the specifics, but she landed with a permanent set to the wings, resulting in the loss or gain of several inches of dihedral.
Now N4522V, sitting on a ramp in Thunder Bay, Ontario. Her owners are hiding her from creditors and seizure by the FAA for unauthorized charter operation.
http://www.747sp.com/NewsDetail.asp?id=32
Air & Space Smithsonian had a more detailed article a few months ago.
Photo © Jason Knutson
Spell check is a false dog
MX757
Thu Apr 20, 2006 2:26 am
Quoting HangarRat (Reply 92):
"The Dive Queen"
 checkmark
 checkmark
Two inch gain to be exact.
Boy, I thought that one would be a little harder figure out.
Do you have a subscription Air & Space magazine?  scratchchin
MX757
Thu Apr 20, 2006 2:37 am
Nope, guess again.
Quoting DH106 (Reply 91):
Nope.
Here's a hint:
Photo © DIAspotter
miamiair
Thu Apr 20, 2006 3:22 am
Quoting MX757 (Reply 94):
Here's a hint
Horizontal Stab Fairings?
MX757
Thu Apr 20, 2006 11:14 am
Quoting Miamiair (Reply 95):
Correct! bigthumbsup
SFOMB67
Thu Apr 20, 2006 11:45 am
Quoting Sfomb67 (Reply 78):
I can't believe nobody has guessed at this ! Are there no 767 mechanics out here? It's on the 762 & 763 (probably the 764). It's called the SOB in the MM.
aeroweanie
Thu Apr 20, 2006 2:23 pm
Krueger Flaps, not Kruger Flaps! Krueger was a German aerodynamicist...
Here is a good question: what commercial airliner type has been in service with engines supplied by four different manufacturers?
cdfmxtech
Thu Apr 20, 2006 4:02 pm
U gotta do this again.
I got in after this topic was already gang banged Big grin
Users browsing this forum: Charleytuna and 36 guests
