Quoting Matt72033 (Reply 48): nope, its rear part of the pylon that splits open |
What part of the 727 pylon splits open? AFAIK, the trailing edge is a riveted wedge.
Quoting Miamiair (Reply 50):
What part of the 727 pylon splits open? AFAIK, the trailing edge is a riveted wedge. |
Quoting Miamiair (Reply 54):
Where is the Hell Hole in the 727? |
How many leading edge slats does the 707-300 have? |
DC-8, has slots or slats? |
Quoting MX757 (Reply 56): Answer: 0. The 707-300 has L.E. Kruger Flaps. |
Quoting Miamiair (Reply 57): 707 does have slats. All leading edge devices outboard of the inboard engines are slats. Inboard of the inboard engines are Kruger Flaps. Ref: 707-300 IPC, ATA27. |
Quoting HAWK21M (Reply 40): Quoting Kaddyuk (Reply 38): The Cessna Diamond is that award given to the unattentive pilots who happen to make contact with the trailing edge of the wing of a cessna. Forming a neat diamond shaped scar on the forehead... How does this look like exactly.What causes the Diamond shape. regds MEL |
Quoting KELPkid (Reply 59):
I'll see if I can snap a picture in the next day or two when I drop by the airport... |
![]() Photo © Aernout ten Hulscher | ![]() Photo © Alex McMahon |
Quoting Miamiair (Reply 57): 707 does have slats. All leading edge devices outboard of the inboard engines are slats. Inboard of the inboard engines are Kruger Flaps. Ref: 707-300 IPC, ATA27 |
Quoting SkydrolBoy (Reply 62): Which commercial aircraft was the first to come with an apu from the factory??? |
Quoting SkydrolBoy (Reply 65): what does the "APU" light on the FE's annunciator panel indicate??? |
Quoting SkydrolBoy (Reply 65): on factory original 727-100's what does the "APU" light on the FE's annunciator panel indicate |
Quoting SkydrolBoy (Reply 65): You got it MX757, the 727 was the first aircraft to come with an APU. |
Quoting SkydrolBoy (Reply 65): 727-100's what does the "APU" light on the FE's annunciator panel indicate??? |
Quoting DH106 (Reply 61): think we're just arguing nomenclature here - but I'm pretty certain all the 707's LE devices would be called Kruger's, or else a similar type of flap hinged at the LE and folding under the wing when stowed. A slat, when deployed runs out on a track forwards and down, and when fully deployed leaves a slot between itself and the wing. They're usually airfoil shaped. A Kruger deploys by pivoting down around a hinge set on the LE. They're usually much more flat shaped - especially on the 707. Here's a good photo showing the full span Krugers - they all pivot down from the LE: |
Quoting Fr8Mech (Reply 70): APU fuel valve open, I believe |
Quoting Mainliner (Reply 72): The exhaust exit door (if installed) is open? |
Quoting VC-10 (Reply 67): What about the BAC One-Eleven in 1963? |
Quoting Avt007 (Reply 74): The Convair 580 had what they called a GTC- gas turbine compressor. It was used for starting the engines, but did not have a generator, so wasn't called an APU. Bloody noisy thing, though! |
Quoting 474218 (Reply 71): As stated in another reply the DC-8 wing had Slots, but they are a fixed part of the Wing Structure |
Quoting Dl_mech (Reply 11): Assume external power is already powering the A/C. 1) Place throttles full forward. 2) Turn off Stby power and External Power from the Cockpit panel. 3) Return Throttles to idle. The plane is now on Ground Service. |
Quoting DH106 (Reply 61): A slat, when deployed runs out on a track forwards and down, and when fully deployed leaves a slot between itself and the wing. They're usually airfoil shaped. A Kruger deploys by pivoting down around a hinge set on the LE. They're usually much more flat shaped - especially on the 707. |
Quoting VC-10 (Reply 79): Looking at my copy of Boeing 707-720 Reference Guide (Boe Doc D6-40942) it says the 707 has 3 L.E. Flaps per side & 10 L.E. Slats per side. |
Quoting MD11Engineer (Reply 81): Ok, where is the snake pit on a 737 |
Quoting Fr8mech (Reply 45): What is: Sailboat on a B747 (classic). We always called it the sail-tail fairing (behind the pylon) Doghouse on a B747 (classic). cabin storage compartment in front of a bulkhead Donkey Dick on a DC8. ? What is a Plasta-Jet (early term). |
Quoting Miamiair (Reply 80): I agree with everything you wrote, but the "slats" on the 707 are not simply hinged, but articulated; and they do leave a slot. This is the difference between the Kruger flaps and the slats. This was done so that the inboard end of the wing would stall first. The 707 slats evolved to the variable camber devices found on the 747. |
Quoting DH106 (Reply 86): Do the variable camber 747 devices leave a slot ? I didn't think so. |
Quoting MX757 (Reply 41): What part on the DC-9/MD-80 are called "Elephant Ears"? |
Quoting MX757 (Reply 43): Quoting Miamiair (Reply 42): Guess would be the Main Gear Wheel Well Doors? Nope, guess again. |
Quoting MX757 (Reply 88): Besides the damage stated in the picture, there is some permanent damage not mentioned. Figure out what that is. |
Quoting MX757 (Reply 89): Quoting MX757 (Reply 41): What part on the DC-9/MD-80 are called "Elephant Ears"? Quoting MX757 (Reply 43): Quoting Miamiair (Reply 42): Guess would be the Main Gear Wheel Well Doors? Nope, guess again. Are there no other takers? |
Quoting MX757 (Reply 88): Question 1: This particular 747SP has a famous nickname. Name it. |
Quoting MX757 (Reply 88): Question 2: Besides the damage stated in the picture, there is some permanent damage not mentioned. Figure out what that is. |
Quoting HangarRat (Reply 92): Quoting MX757 (Reply 88): Question 1: This particular 747SP has a famous nickname. Name it. |
Quoting HangarRat (Reply 92): "The Dive Queen" |
Quoting HangarRat (Reply 92): Quoting MX757 (Reply 88): Question 2: Besides the damage stated in the picture, there is some permanent damage not mentioned. Figure out what that is. |
Quoting HangarRat (Reply 92): can't recall, or find the specifics, but she landed with a permanent set to the wings, resulting in the loss or gain of several inches of dihedral. |
Quoting MX757 (Reply 89): Quoting MX757 (Reply 43): Quoting Miamiair (Reply 42): Guess would be the Main Gear Wheel Well Doors? Nope, guess again. |
Quoting DH106 (Reply 91): Elevator trim handles? |
Quoting Sfomb67 (Reply 78): where is the SOB fairing on a 767? |
