Quoting ZANL188 (Reply 14): Quoting BoeingFixer (Reply 12):
Use a belt loader for the last person off the aircraft from another door. |
Quoting ZANL188 (Reply 14): Pointless if the idea is to reduce the aircrafts dependence on ground support equipment.... |
Heavy emphasis on REDUCE in your comment, not eliminate.
Although you may think it's pointless, have you ever tried loading/unloading 757 belly pits without a belt loader? The first picture indicates that one is required and most airports will have one despite not having Airstairs.
Other options include lift trucks, lift platforms, ladder in the back of a truck etc.... to get the last crew member off. Lots of ways you can do it.
The main reason to have those retractable Airstairs is for passenger comfort/safety when real Airstairs are not available.
John
