Photo © David Lednicer
Does anyone have a photo of one of these detached from an aircraft?
Thanks.
Quote: Those are the rear wheels. |
Quoting KELPkid (Reply 3): It is quite clearly the Chevrolet or GMC's front axle... |
Quoting KELPkid (Reply 3): It makes it nice for the FBO's, in that they don't have to hire line employees with a DOT Hazmat endorsement and a commercial driver's license to re-fuel aircraft. |
Quoting SlamClick (Reply 4): They also don't have to pay them as if they had those quals. |
Quoting KELPkid (Reply 5): I'm trying to steer my 15-year old nephew that way for a summer job (he lives right by a very busy GA airport, and loves planes). |
Quoting SlamClick (Reply 1): The front wheels are barely visible between the Beaver floats. It is not a tow but a lift. The white metal frame you see extending under the plane are a permanent part of the vehicle. |
Quoting HAWK21M (Reply 8): |
Quoting HAWK21M (Reply 8): BTW.Whats this Model called. regds MEL |
Quoting SlamClick (Reply 11): Does that mean it is street-legal or does Washington require plates on offroad vehicles? |
Quoting HAWK21M (Reply 12): Interesting Observation.Don't most Airport Vehicles have Driving Licence plates,if needed to drive on the City side for any reason. regds MEL |
Quoting FlyDeltaJets (Reply 13): At JFK all of the fuelers have to have a CDL with hazmat endorsment. |
Quoting SlamClick (Reply 9): I've never seen one of these before. (Unless you are referring to the DeHavilland Beaver) It is possible that this is just something they welded up in their own shop. It looks like a really clever design; drive the lift part down a boat ramp and get it under the plane, pull it up out of the water while the cab of the tug stays dry. |
Quoting L-188 (Reply 16): As mentioned what you do is find a beater 4WD truck and cut everything aft of the differential off. They you get yourself 2 pieces of steel beam mount a couple of wheels on them and weld them to the front of the frame. You drive the truck through the front axle. |
![]() Photo © Curtis Kreklau | ![]() Photo © John Olafson |
Quoting KELPkid (Reply 20): You probably meant the transfer case.... (most American 4x4 pickups don't use a center diff, only differentials are on the axles). Minor point... |
Quoting KELPkid (Reply 20): Wonder how they keep the rear seal on the transfer case from leaking, as presumably the driveshaft yoke is now missing? Just let the oil leak and replace it regularly? Or put some sort of plug where the rear driveshaft yoke went? I don't think you could leave the yoke in without the driveshaft...wouldn't the yoke just fall out? (Remembering back to replacing the rear seal on the transmission in my first car...which was rear wheel drive). |
Quoting HAWK21M (Reply 23): Hows the Corrosion rate on these Trucks |
