Quoting Kaddyuk (Reply 1): Adding DC4 electrical grease to a whistling door seal will normally shut it up... |
Quoting FlyMatt2Bermud (Thread starter): Our popular idea with others was to carry cheap mouthwash aboard aircraft with recirculating toilets. Adding it to a ripe recirc toilet will make it much more tolerable for a few more hours. |
Quoting Aogdesk (Reply 3): Adding vodka to the bluejuice will make it slightly more palatable |
Quoting N8076U (Reply 5): we had these little packets you could throw in, and it turned the regular water into the blue water, as it was merely a concentrated powder of the same thing |
Quoting FlyMatt2Bermud (Reply 6): But at $125, I'm here to tell you we might start carrying more Evian and finding the little blue packet vendor. You just need to be careful because the skin breaks easy on those little pills |
Quoting N8076U (Reply 7): The packets we had were made of some sort of paper that dissolved quickly. If you held on to one too long it would start to come through and stain your hand, so wearing gloves and working quickly was of utmost importance! |
Quoting Midnights (Reply 11): Pepsi/Coke works great to clean bugs from a windshield, gum from a tray table and anything spilled and baked in an oven....SP-40 (our version of WD-40) will take any sort of graffitti off tray tables left by little artists. Also, a friend of mine gave his wife a small squirt bottle full of skydrol in place of mace or pepper spray and told her to shoot for the face and eyes....she hasn't had to use it but I know how well that could work, not too sure how leagle that is. |
Quoting N8076U (Reply 9): On the PW4000s that we had on our 747-400s and 767-300s, sometimes you'd get a fuel or oil leak from the drain mast, but you couldn't quite determine where it was coming from. Sometimes, more than one of the drain lines (drivepad drains, case drains) were plumbed together into one common line. If you disconnect where the unit's drain connects to the common drain and put a plastic baggie over each one and tape it in place, you can then do an idle run, and check the bags to see what exactly is leaking. Luckily, most of the time, it was obvious when you disconnect each individual line. But this bag trick came in handy a couple times, once when there was a fuel puddle under the engine only after it came in after a flight, but no leak after an idle run. We had to do a high power run to find that one. Of course, this trick should work on other engines too. |
Quoting NKP S2 (Reply 14): One more thing: 'Kroil". Makes every other penetrating oil seem like a "cotter pin in a can". Great stuff that'll help break just about fastener loose. |
Quoting NKP S2 (Reply 13): Sometimes we've checked the breather exhaust as well... |
Quoting NKP S2 (Reply 13): Since it's not possible to do a leak check on the cores of many or most High-bypass fan engines while running |
Quoting Dougloid (Reply 12): I used to keep a small 4 ounce squeeze bottle of olive oil |
Quoting N8076U (Reply 16): I remember a couple guys always had a bottle of oil (castor, olive) in their toolboxes. |
Quoting Kaddyuk (Reply 17): Be careful however because the bacteria in milk could cause an infection (never heard of it though). |
Quoting CosmicCruiser (Reply 19): From the pilot point of view...always open the yogurt facing away from you!! |
Quoting Kaddyuk (Reply 17): Tinfoil around bleed air joints when leak checking... If you have a leak, it will destroy the tinfoil... |
Quoting 2H4 (Reply 22): When reaching into the gap of a control surface during preflight to inspect hinges, nuts, etc, hold the control surface firmly in place with your other hand to prevent the wind or another person from chopping your finger off.... |
Quoting Starlionblue (Reply 27): My daughter has a wooden box with a hinged lid that has blocks inside. She put one hand in the gap and pressed down on the lid with the other hand. She looked completely mystified, then started crying. But she kept pressing! Poor baby got a red thumb. So I'm glad to hear adults still manage this trick |
Quoting N8076U (Reply 28): Once on its nose, a 757's nose gear will not be able to raise the aircraft out of that "oh sh*t" position, as he tried that next. I think they made him a supervisor after that... |
Quoting Dougloid (Reply 23): You want to be the guy with answers and solutions, not questions and problems. |
Quoting ReidYYZ (Reply 31): Quoting Dougloid (Reply 23): You want to be the guy with answers and solutions, not questions and problems. I know a few mech's who don't get this: They have a problem and ask the sup "What do I do now?" Then the sup has to pull up a high chair and spoon-feed the info and instructions. If you run into a problem, your sup should be kept apprised of the situation, your future course of action, or your ideas to solve the problem. Think it through, nobody wants to lead somebody by the hand especially if they are paid the same as the rest of the staff. This is one of my largest pet peeves. |
Quoting ReidYYZ (Reply 31): If you run into a problem, |
Quoting Dougloid (Reply 32): If you must go to your boss with a problem, for heaven's sake have a solution in hand. |
Quoting Scarebus03 (Reply 37): Just make sure it's not the gap of a hydraulically operated control surface you stick your finger in! |
Quoting Midnights (Reply 11): Also, a friend of mine gave his wife a small squirt bottle full of skydrol in place of mace or pepper spray and told her to shoot for the face and eyes....she hasn't had to use it but I know how well that could work, not too sure how leagle that is. |
Quoting N8076U (Reply 28): I think they made him a supervisor after that... |
Quoting Sfomb67 (Reply 39): Reminds me of a supervisor at the base that made a w/u, signed it off, and bought it. |
Quoting Sfomb67 (Reply 39): He went on to become a Gen Mgr. |
Quoting Dougloid (Reply 23): "Never get good at something you don't like, because you'll end up doing it forever." |
Quoting MesaMXORD (Reply 41): AMEN To that. I changed a Stick Pusher Capstan on a Crj-700 in around half the time as the last person that did it. Next thing I know every day those were scheduled I got pulled off the line to sit all the way fwd in the little E/E bay for 2 hours multiple times!!! Never gonna do that again. |
Quoting Dougloid (Reply 23): Never get good at something you don't like, because you'll end up doing it forever. |
Quoting Ilikeyyc (Reply 42): Quoting Dougloid (Reply 23): Never get good at something you don't like, because you'll end up doing it forever. Being one of three guys on my shift on my line that can fit into the CRJ fuel tanks means that I often get assigned the fuel tank mods. |
Quoting Dougloid (Reply 43): However on the first one (Marie Callender's) Canadair sent a broad out from Windsor Locks to walk us thru it. She had a fine rack and it was better than a lap dance in a strip bar watching her go in. |
Great Gawd almighty. Give your ass to Jesus, brother. They gotta be the same as the Cl600/601, right? Football shaped panel just outboard of the wing root? |
Quoting Dougloid (Reply 23): Avoid the company of tattlers and teacher's pets. They'll try to screw you to make themselves look good. |
Quoting Miamiair (Reply 46): we had a real practical joker in our crew that took offense to a hangar rat coming into our shop at break time and would smoke at our table. He had is own ash tray, so the joker one day added a small amount of gunpowder to the ashes...When the cigarette was placed in ash tray....FLASH...SMOKE...Guy fell out of his chair...never came back. |
Quoting Miamiair (Reply 46): Tricks of the trade also involves dealing with schmucks like these. |
Quoting Miamiair (Reply 46): Then again, there is "justice" for this category of people you work with: |
