N231YE
P&W JT8D Idle Sound "Vaccuum Cleaner"
Thu Jul 27, 2006 10:46 am
Just wanted to know, what causes the Pratt & Whitney JT8D to create that (in my opinion, beautiful) "vaccuum cleaner" sound when idleing. Is it possibly from the blade tips moving at a velocity higher than that of the speed of sound (like the "buzz-saw" of high bypass engines on takeoff)?
N231YE
Skookum
RE: P&W JT8D Idle Sound "Vaccuum Cleaner"
Thu Jul 27, 2006 12:41 pm
The tips shouldn't be going supersonic at such a low power setting. Now I'm no jet engine expert or acoustics engineer, but I think that this higher (compared to other jet engines) pitch idle sound is caused by the smaller (compared to other jet engines) diameter of the engine.
I'm sure that the others will have a much better explanation.
Good flying
n8076u
Thu Jul 27, 2006 1:35 pm
Quoting Skookum (Reply 1):
True.
The JT8D (and other low-bypass turbofans and turbojet engines) sucks the air in at a higher velocity than a high-bypass engine with comparable thrust output, like the CFM-56. The big fan on the high-bypass engine makes up for the lower velocity by moving a larger volume of air, and a benefit of that is less noise.
Chris
Don't blame me, I don't work here...
ElpinDAB
Fri Jul 28, 2006 4:37 am
Please correct me if i'm wrong b/c i'm just taking what I learned in my turbine engines class at ERAU. I'm sure there are many (much) higher qualified people out there, but...
Spools of the compressor section are composed of rows of rotating compressor blades and stationary vanes called stators. On turbojets and early turbofans, such as the JT8D, the compressor blades spin very fast right next to the stationary vanes. This shears the air between the compressor blades and the stators, creating the 'vacuum cleaner' sound you hear when the engine is at lower power settings. This is very similar to how a siren creates noise: by a rotating a set of blades next to stationary vanes.
Newer high bypass turbofans are designed with lower noise levels as a priority, so the rotating compressor blades in the fan section of the engine are much farther away from the stators, eliminating this shearing and the the resulting sound.
Fri Jul 28, 2006 6:37 pm
This sound is a very peculiar Varied noise level when the JT8D is Idling.
Low Bypass Engines sure are noisy.
The Airflow passing through the Compressor blades at that speed contributes to this Whining sound.
regds
MEL
avioniker
Fri Jul 28, 2006 10:11 pm
Gee
I always thought Mother's Kirby sounded like a JT-3 above idle and the newer JT-8 sounds like my Hoover;
I never realized it's actually that a jet engine sounds like a vacuum cleaner
 Smile
N231YE
Sun Jul 30, 2006 9:44 am
Thanks for the input,
Quoting Avioniker (Reply 5):
 biggrin  - I thought my mom's Hoover sounds like a PT6A turboprop more than a JT8D. Anyways, nice one
corey07850
Sun Jul 30, 2006 10:12 am
True... To continue with that, the tips shouldn't be going supersonic any power setting
speedracer1407
Sun Jul 30, 2006 12:30 pm
Quoting Corey07850 (Reply 7):
It's my understanding, based on numerous threads about fan aerodynamics on this forum, that tip speed does indeed reach and exceed Mach 1 at high power settings.
747400sp
Thu Aug 03, 2006 12:35 am
Quoting ElpinDAB (Reply 3):
Quoting HAWK21M (Reply 4):
At taxi a F-119 that powers F-22A are as quite as a 737 classic or NG CFM56-3 or 7. They also sound like CFM56-3 or 7. At take off, well that's a totally different story.
Thu Aug 03, 2006 5:13 pm
Out here The Few B732s that operate sure wake up the Airport when they Get Airborne  Smile
But I think another 2-3 yrs for Freighters & another year for Pax B732s in the country.
regds
MEL
Users browsing this forum: T54A and 11 guests
