speedracer1407
Flight Idle And Ground Idle
Wed Aug 16, 2006 5:01 pm
After reading a different thread, I was reminded that I still don't know the what accounts for the difference between flight and ground idle; hopefully, I have the terminology correct. I have a few questions:
Assuming flight Idle is generally higher than ground idle, what causes the difference? Is it part of FADEC software?
In non FADEC engines, is it still some kind of automatic mechanical thing?
Is it simply the result of aerodynamic forces on the engine in flight that makes the difference (windmilling, of some sort)?
is there a detent on the throttle quadrant for it?
Are quicker spool-up times from flight-idle to maximum power a primary reason for the difference, or as before, is it just a natural/practical consequence of high airspeed?
Thanks for any replies,
O
chksix
RE: Flight Idle And Ground Idle
Wed Aug 16, 2006 6:01 pm
I'm interested to know the limits for the 737NG. I know ground idle is at 20% but can't find info on Flight Idle.
[Edited 2006-08-16 11:02:49]
The conveyor belt plane will fly
Tristarsteve
Wed Aug 16, 2006 7:50 pm
Flight idle is always higher than ground idle.
Nowadays it is controlled by the FADEC, but on the RB211 there was a FI/GI solenoid connected to the FFR. Ground Idle is set as the slowest practical speed the engine will operate with bleeds on.
Flight idle is set top acheive the idle to take off acceleration speed required by regulations. FAR is 5 secs, and CAA used to be 6 secs. If the engine will not accelerate from ground idle in this time, then in flight the min speed is set to acheive this. It is very necessary in large fan aircraft where flight idle can be much higher than ground idle, but in small fans it is not always necessary. I await MEL to say something, but I can't remember it on the JT8D-15, or the Spey.
Wed Aug 16, 2006 8:42 pm
From What I recollect offhand.On the RB211-535E4.
The Idle Reset Solenoid on the FFG sets High or Low Idle.
High idle is only used during Landings and when Engine Cowl A/I is on in Flt.High Idle is used for Descent in Icing conditions to prevent possible Engine problems and is used during Landings to reduce time for the Engine to spool up to Maximim rpm if needed in case of G/A.
When the Idle Reset Solenoid is De-Energized Idle speed increases.At sea level the Acceleration time decreases by approx 2 secs.[regular 5-6 secs].
In Flt with Flaps up & Gear retracted.Low Idle is used.When Flaps lowered to Landing position & Engine A/I selected or NLG lowered,Idle Reset solenoid is DeEnergised & speed Increases.
On Touchdown The Solenoid Energizes after a Time Delay of 5 seconds.
1.06 EPR Flight Idle on RB211-535C.
regds
MEL
chksix
Wed Aug 16, 2006 9:37 pm
Any N1 percentages? Would 40 - 50% N1 be probable?
Tristarsteve
Thu Aug 17, 2006 3:18 am
Quoting Chksix (Reply 4):
No lower than that.
On RB211 N1 idle is around 22%, N2 40% and N3 60%.
Flight Idle increases this by about 5% N1.
chksix
Thu Aug 17, 2006 4:42 am
Ok thanks! I'm surprised it's that low.
113312
Thu Aug 17, 2006 7:10 am
Of course, you're only discussing Flight or Ground Idle for tubofan engines. They really shouldn't be called "Flight" or "Ground" at all but rather High and Low.
Many of the high bypass engines in use basically have a closed "throttle" speed of "Ground Idle" (low) on the ground and in the air. They only switch over to "Flight Idle" (high) in the air with a landing configuration such as gear and flaps extended. The reason for this is to facilitate rapid engine response for go around (aborted landing) and reverse thrust after touchdown.
EMC
liedetectors
Thu Aug 17, 2006 7:34 am
Quoting Speedracer1407 (Thread starter):
No. Ground Idle is exactly what is sounds like - idle thrust for on the ground. It is the same detent at Flight Idle, but also requires the Weight on Wheels switch to show that it is on the ground. Tripping the WOW switch will tell the FADEC to spool the engines down to Ground Idle.
If it was said by us, then it must be true.
troubleshooter
Sat Aug 26, 2006 7:24 am
Quoting Chksix (Reply 1):
Note that IDLE is always based on N2 speed.
For the CFM56-7 there are three IDLE modes:
GROUND IDLE
above 58%. Idle speed will increase with increase of OAT, generator load and bleed demand
FLIGHT IDLE
during flight the FADEC maintains a N2 speed of 72%
APPROACH IDLE
the FADEC goes into this mode (72-79% N2) if following conditions occour:
- either cowl anti-ice is swiched on
- either main landing gear down and locked below 15.000 ft
- TE flaps are equal or more than "15" below 15.000 ft
This job sucks!!! I love this job!!!
IFixPlanes
Sat Aug 26, 2006 2:40 pm
B737NG Idle Control:
never tell an engineer he is wrong ;-)
chksix
Sat Aug 26, 2006 5:39 pm
Thank you for that info Troubleshooter and IFixPlanes!
