B757 & 767 Flight Deck Differences
Fri Aug 18, 2006 8:02 pm
Are there any Noticable Differences with The Panels on the B757 & B767 Aircraft from Flight Deck Point of View.If so what are they.
regds
MEL
AvionicMech
RE: B757 & 767 Flight Deck Differences
Fri Aug 18, 2006 8:53 pm
The first one that comes to mind Mel is that the Hydraulic panel is completely different on the 767, it has primary and demand pumps with a rotary switch for the demand pumps with 'OFF', 'AUTO' and 'ON' positions.
The pneumatic/air conditioning panel is also different on the 767, it has left and right isolation valve switches. It also has 4 zone temp selectors (3 cabin and 1 flightdeck), on the -300 anyway, I can't remember the -200.
The 767 has cargo heat push button switches on the overhead for the 'FWD', 'AFT' and 'BULK'.
The equipment cooling selector is a 3 position rotary switch on the 767 as opposed to a push button switch.
There is also the fuel jettison system on the 767 aswell, and these are only overhead panel differences, I am sure I could come up with more if I thought about the whole flightdeck.
[Edited 2006-08-18 13:56:21]
Fri Aug 18, 2006 10:24 pm
Photo © Gabriel Savit
Photo © Krzysztof Skowronski
Photo © Marcel Venema - DutchOps
Photo © Dan Rabolt
B767 & B757 comparism Pics.
What about P61 panel [RH side].Is it present on B767.
regds
MEL
AvionicMech
Sat Aug 19, 2006 1:22 am
Yes the P61 panel is present on the 767 aswell. The layout of the equipment on the P61 panel is usually down to the customer spec at build.
On the 757 you have hydraulic isolation switches for the 3 systems going to the tail but on the 767 you can isolate the wings aswell. There are 6 switches one for each system for the tail and one for each system going to the wings.
The squib test lights are different, there is two test switches and only the test switch one will light up the APU light because there is only one squib for the APU.
There are a few other slight differences aswell that I can't remember right now.
Tristarsteve
Sat Aug 19, 2006 1:26 am
And don't forget the step into the cockpit!
Up into a B767 and down into a B757.
LAXintl
Sat Aug 19, 2006 2:05 am
Quoting TristarSteve (Reply 4):
By far the most important difference!
I nearly broke my neck rushing into a 757 cockpit once!
Sat Aug 19, 2006 2:21 am
Let's not forget the F/E position in the 767 cockpit. Big grin
Tristarsteve
Sat Aug 19, 2006 2:26 am
Quoting Starlionblue (Reply 6):
I have seen the EICAS screens there on El Al, but never a real F/E panel.
Who has this? Are they still working, or have they all been converted to 2 crew operation now?
Your top photo looks like a standard B767. Very similar to a B757. No switches there to operate in flt.
aogdesk
Sat Aug 19, 2006 3:42 am
It's Starlionblue's personal B767, assembled over eight years and thousands of Ebay purchases.... Smile
Sat Aug 19, 2006 3:44 am
Quoting Tristarsteve (Reply 7):
I believe these particular pics are from Ansett. I believe Aeroflot also had a 3 man cockpit on the 767.
As far as I know, they have all been converted to standard.
Sat Aug 19, 2006 4:22 am
Why is this Difference present.Any reason.Is the Main Deck Floor Height Different.
An EICAS screen on P61.Thats new.
regds
MEL
Tristarsteve
Sat Aug 19, 2006 4:26 am
Yes now I remember.
When the B767 was designed it was a 3 crew aircraft. Before delivery it was changed to a two crew aircraft, but the Ansett unions managed to insist on a 3 crew aircraft.
While short range aircraft had been two crew for ages, it was the B767 and A310 which introduced long haul two crew aircraft, and it was very contoversial at the time.
Sat Aug 19, 2006 4:29 am
Quoting HAWK21M (Reply 10):
My interpretation is that the upper lobe of the 767 is much larger, so there is more space for the flight deck. The 757 has a narrower body, so the flight deck has to be pushed down towards the centre of the fuse to avoid making it stick out..
As I recall, that whole F/E position was a huge hash-up.
Tristarsteve
Sat Aug 19, 2006 5:02 am
This was done to make the physical cockpit size the same in two different fuselage sizes.
DL_Mech
Sat Aug 19, 2006 12:29 pm
Quoting AvionicMech (Reply 1):
There is a fourth position "refrig" if the aircraft has an ACRU.
https://www.airliners.net/discussions...h_ops/read.main/143280/6/#ID143280
This plane is built to withstand anything... except a bad pilot.
Former AMT on A220,A310,A319/20/21,A330,A350,B707,B717,B727,B737,B747,B757,B767,B777,DC-9,DC-10,L-1011,
MD-80/90,MD-11
Sat Aug 19, 2006 5:35 pm
Quoting Dl_mech (Reply 14):
What about Moisture in that Air going to the Modules.
regds
MEL
Users browsing this forum: glen and 29 guests
