Photo © TZ Aviation
Is this correct.
Using a Forklift rather than a Main deck loader to off load a Pallet from the Main deck.
regds
MEL
Quoting Ha763 (Reply 1): Aloha actually modified a truck to hold all the seats of a 732QC, drive up to the main deck door, and push the seats on and off of the truck into or out of the aircraft |
Quoting Dogfighter2111 (Reply 2): If there wasn't a loader available at the time and the aircraft was required soon, then just improvise. If it works, do it |
Quoting HAWK21M (Reply 4): The concern of the Forklift use is that there is always a chance of Tilt.Also the Dolly seems forklift Enabled but the Pallet is held only by End locks upto a certain height.Considering the Proximity of the MCD to the Engine.Does not seem a very bright idea. Agree as there is no Main Deck loader Available at the time,Improvisation may be needed,but it could be a very Expensive one too. Is this Airport a Frequently used one,If so a Main Deck loader should be a mandatory Equipment. |
Quoting Greasespot (Reply 6): we use a forklift exlusively |
Quoting HAWK21M (Reply 4): Any pics of this unit. |
![]() Photo © Rafael Cordero - AeroImagenes de Mexico | ![]() Photo © Richard Barsby - Aviation Photography CYEG |
Quoting Greasespot (Reply 8): Since the aircraft were not QC we had to install every seat and lock every time. |
Quoting Ha763 (Reply 9): The truck in question is currently parked under an enclosed tent next to their cargo ramp and since I don't work for AQ I can't exactly get a picture of it. |
Quoting HAWK21M (Reply 15): Any Pics. |
Quoting HAWK21M (Reply 10): How long. |
Quoting L-188 (Reply 18): You have to remember that a pallet loader is a fairly complex piece of equpment, and for outstations would be too expensive to maintain. A forklift is simple, easy to use, and since it is a mass produced piece of equipment, as opposed to a specialty one, parts availablity is much greater. |
Quoting HAWK21M (Reply 19): I think a Forklift has multiple uses for a Cargo Airline,Hence reduces Stores Inventory too |
Quoting HAWK21M (Reply 19): However the Mechanism of an MDL is not as complex as it seems.Mainly relying on Solenoids to move spool valves that port Hydraulic fluid to MPF,Bridge,PDUs & Stablizer Jacks.Apart from the Drive that moves the MDL. |
Quoting L-188 (Reply 20): Sorry I have to go ahead and say that is a complicated systems....A forklift has a pump and valves. |
Quoting Ha763 (Reply 25): I don't really know, but it looks like it can hold 3 or 4 88-inch pallets |
Quoting Greasespot (Reply 27): Canadian NOrth had that same storage as AQ. They never put palletized seats in ..It held the floor locks and seats only |
Quoting Greasespot (Reply 29): 2/76 3/60 4/54 5/24 |
Quoting Greasespot (Reply 27): NOt every combi is a QC. Lots are jsut combies with the seats mounted to the brownline. I know for us QC pallets cost us to much in freight as there are no roads where we fly |
Quoting HAWK21M (Reply 30): So the ratio is not specific but varies.Is 5 the Max |
Quoting L-188 (Reply 31): I'll have to find my old AS config card, but I am really sure that the max pallets you can get into one of their 737's is 6 no pax. |
Quoting HAWK21M (Reply 32): If not mistaken it should be 7 |
Quoting L-188 (Reply 34): No it six the way that AS had theirs configured. |
