zvocio79
Funny Or F&*(@$# Up Write Ups.....
Fri Nov 24, 2006 11:02 am
I got some funny ass write ups, all truth stories......like this captain writes:
"MFD (multi functional display) dim"
Corrective action: " set switch to bright" ops ck good.
or the guy the wrote (some ERJ 145)
"trust reversers not installed"
corrective action " this a/c is not equiped with trust reverser"
N231YE
RE: Funny Or F&*(@$# Up Write Ups.....
Fri Nov 24, 2006 11:23 am
(P = The problem logged by the pilot.)
(S = The solution and action taken by the mechanics.)
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Mouse in cockpit.
S: Cat installed.
From and more at: http://www.askcaptainlim.com/humor.htm
RJwrench85
Fri Nov 24, 2006 11:47 am
Not exactly funny but just write-ups I have gotten when the Pilot does not know his Aircraft
-Unable to transmit on OBS Seat ACP
(No supposed to be able to)
-Both Thrust Reversers W/N Deploy on Landing
(They Did not select 14th Stage Bleed Air, Which on a CRJ-200 operates the T/R's)
-Standby Com/NAVUnit Display INOP
(My sign-off was; Found to be normal operation when knob selected to OFF. The guy was so used to it always being on when it was turned off he was stumped)
"Improvise, Adapt, Overcome"
corey07850
Fri Nov 24, 2006 11:56 am
Best I've seen was "Exhaust stack excessively hot"
MX responded with something like "Exhaust temperatures in excess of 1400 degrees... Exhaust will be hot"
lowrider
Fri Nov 24, 2006 1:20 pm
the best corrective action I've read
R/R flight crew, ops check good.
Proud OOTSK member
dw747400
Fri Nov 24, 2006 1:39 pm
Best that I've personally seen:
Squawk: Pilot's seat would not move to rear.
Corrective Action: Removed bottle of Dill Pickels from under seat.
CFI--Certfied Freakin Idiot
Fri Nov 24, 2006 11:19 pm
In reality We cannot write a Rectification Action to a PDR ths way.It'll call for quite some explanation from the Authorities  Smile
regds
MEL
cdfmxtech
Sat Nov 25, 2006 1:07 am
Just saw this one recently;
Discrepancy
Passenger Lost pair of sunglasses in Lav S
Coreective Action
Sunglasses now reside in the Houston Sewer System
RJwrench85
Sat Nov 25, 2006 9:41 am
Quoting HAWK21M (Reply 6):
regds
MEL
Correct but this is exactly how we want to sign it off though!
MXSUP
Sat Nov 25, 2006 12:17 pm
Best one I had was-
Squawk: Loud noise under cockpit floor, sounds like a large bear growling.
Signoff: Found no evidence of bear under cockpit floor, could not duplicate problem.
I figured QC would kick this one back to me, but they didnt (I did verify there was no noise).
Another one I see every couple months is
Squawk: Thrust levers diffcult to move
Our usual signoff: loosened friction knob
It's funny how people forget the obvious. I dont know how many times I've seen write-ups for dim lights, and then a sign-off of "adjusted dimmer knob"
Airgypsy
Sat Nov 25, 2006 12:35 pm
My all time military favorite was: I-F-F inoperative in O-F-F mode.
Fly2HMO
Sat Nov 25, 2006 2:57 pm
A few I remember from recent stuff at my school:
Squawk: Aircraft ran off runway (first time C172 solo student, she was crying on the radio afterwards  cry  )
Signoff: ops chk good (just a few weeds caught in between the brake discs Big grin )
Squawk: Flashlight fell into left fuel tank (a PA-44)
Signoff: Tank drained, flashlight removed, ops chk good
Squawk: a/c yaws left (a PA-44)
Signoff: rudder trim set to neutral, ops chk good
The ones for our sims are even funnier (blue screens of death, 999kts on groundspeed, no control loading etc) and 99% time they can be fixed by a hard reset of the system.
777wt
Sun Nov 26, 2006 12:26 am
Quoting Zvocio79 (Thread starter):
Wished you were still working at my airline...
Here's a few more to add to the list:
Problem: Emergency flashlight inop
Corrective action: ops check good
Problem: FA's service door won't close
Corrective action: "Closed FA's service door, ops check good"
Man I felt like writing this addtional comment "stop being lazy and use a lil muscle!"
Problem: FA's galley light inop
Corrective action: ops check good, cannot duplicate problem
I'm serious these pilots needs more common sense. And not write up the problem unless it's surely needs to be looked at. I mean did you try it again to see if it works?
I can go on but I don't have it over my head as of now...
Here's a good one:
Problem: Main Cabin door paint does not match aircraft.
Spoke with the captain... he said "the paint on the door doesn't match the plane. I stare at him for a min thinkin how !#$% stupid he is... then I said "ok from the logbook, the door was robbed from a C-check aircraft due to the original door being damaged."
He says the same thing he said a min ago "but the paint doesn't match the plane!"
I said "listen, do you want to fly or not?"
Captain: "yes..."
I said "Ok, go back to the logbook and write "Entered In Error with your employee number"
DashTrash
Sun Nov 26, 2006 1:14 am
Write up: "Turd smell on cockpit".
Fix: "Inspected cockpit ducts, cabin ducts, recirc fan, engine bleed ducts, APU bleed ducts, APU bleed SOV, engine bleed SOV. No turd found, aircraft OK for service."
No joke......
Sun Nov 26, 2006 1:57 am
Quoting MXSUP (Reply 9):
Out here Rectification would be "Lubricated same"  Smile
regds
MEL
AirframeAS
Tue Nov 28, 2006 9:39 am
Quoting N231YE (Reply 1):
S: Cat installed.
One of my instructors did this at America West after a pilot was a total prick to him, he ended up getting into trouble for being a 'smart-ass' in the logbook. True story, I kid you not except the actual problem was something like "Strange noises, sounds like chewing in the cockpit". Then the solution was the same, pretty much "Will Install Cat When Available".
turbonytro
Tue Nov 28, 2006 4:17 pm
A funny thing often occurs in the small jet part 135 arena...I can speak with a pilot via phone about to fly his last leg of a long trip back to base (his home) and he will say the plane's in great shape. When he get's home and finds out he's going back out in the morning (in the same plane) suddenly write ups appear in the logbook! It's funny, but also EXTREMELY unproductive for a company...I can't complain though...it keeps me employed.
Tue Nov 28, 2006 10:34 pm
It helps when the Crew writes the PDRs in more detail like Giving Max Information pertaining to the Phase,Speed,Sequencewise of the snag.More details make Mx work easier to Troubleshoot,rather than one line entries of Two or Three words.
regds
MEL
Lucky42
Wed Nov 29, 2006 3:26 pm
I had one years ago on a 727 pilot writes f/o took a dump in the fwd lav and knocked down the spash pan then went to the aft lav and did the same thing.
Mechanic writes reset splash pans suggest f/o change diet....
Buzz
Wed Nov 29, 2006 8:57 pm
Hi MXSUP, Buzz here. Another weird noise gripe was on a 737-300, with some history of nose gear door vibration: "Nose gear doors moan like a constapated rhinocerous".
I really wanted to become poetic on this one, comparing it to a standard Boeing rhino noise. But after a couple hours (and jacking the nose to re-adjust the NLG door pre-load) I simply signed it off something like "adjusted nose gear door pre-load" If the NLG doors don't have a certain stress on them, they vibrate.
Another gripe was "Cockpit door sticks inflight, OK on ground"... how might we figure out where the problem lies on that one?
Same pilots, same flight: "Capt. side window crazed". This guy had made 4 or 5 gripes on that flight, the #3 window was still within limits and we really wanted to write in the logbook "Window within limits, Captain crazed".
I haven't had many "colorful" gripes in the last 5 years or so.
g'nite
kaddyuk
Thu Nov 30, 2006 6:33 am
We have a booklet at work on how NOT to write entries in the Tech Log and on Unservicable Labels...
Such US labels in the "Reason For Removal" box include the words... "Shit", "Crap" and my always favourite "Made By Airbus"
Dougloid
Thu Nov 30, 2006 6:38 am
When I worked at Douglas there was a female inspector who wrote a DI-SR on something or other on the horizontal stabilizer of an MD80. She identified it as "the little wing above the big wing".
Which lead to an early retirement-later that afternoon, so I'm told.
ReidYYZ
Thu Nov 30, 2006 7:16 pm
Years ago, our cabin defect logbooks had white master, yellow and pink carbon copies. It took years to figure out that the yellow and pink went everywhere together once pulled. With a new book, sans pink, a F/A wrote up: "defect book missing pink paper sheets" rectification: "pink sheets not installed due shortage of pink trees"
Thu Nov 30, 2006 10:33 pm
Quoting Kaddyuk (Reply 20):
Whats the contents like.
regds
MEL
lowrider
Fri Dec 01, 2006 5:08 am
I almost forgot about this one, we had a flight attendant who could not get one of the galley drawers to open. The captain sent the FO back during a turn to see if he could figure out why it was stuck. Since the FO couldn't budge the drawer either, the captain entered into the aircraft log, "FO unable to get into Flight Attenants drawers."
Proud OOTSK member
charlienorth
Tue Dec 05, 2006 6:03 am
It pisses me off when they tell you about a problem at the outstation and expect it to be corrected before they leave,why did you leave the outstation with this problem?If you left there you could leave here...
Work hard fly right..don't understand it
Tue Dec 05, 2006 6:00 pm
Quoting Charlienorth (Reply 25):
Thats why the M.E.L. is Important at Outstations.
regds
MEL
charlienorth
Wed Dec 06, 2006 2:49 am
Quoting HAWK21M (Reply 26):
regds
MEL
Absolutely...sad thing is too many of them are too lazy to write items up at an outstation
Thu Dec 07, 2006 1:14 am
Quoting Charlienorth (Reply 27):
Are you saying the Crew don't write up snags at outstations.
regds
MEL
charlienorth
Thu Dec 07, 2006 1:50 am
Quoting HAWK21M (Reply 28):
regds
MEL
Not bad here and now,but I worked for operation in the late 80's where the crews took pride in carrying an airplane,here it's not a problem,with ACARS they can get deferral authorizations pretty quick and be on their way home.
Thu Dec 07, 2006 6:57 pm
Quoting Charlienorth (Reply 29):
Why defferal authorisations if the Equipment is covered under M.E.L. Are you talking of Mx or Flight crew.
regds
MEL
777wt
Fri Dec 08, 2006 1:27 am
Quoting HAWK21M (Reply 30):
regds
MEL
So the problem can be tracked and have it fixed before the MEL limit expires.
We're talking about Mx. Say if you have engine bleed valve fail, you can lock it closed and defer it.
But the deferral authorization is there to keep track of the problem and make sure it can be deferred.
Also is the APU is inop and theres a bleed valve fail, we can't defer it unless we fix one of them due to the MEL requring the engine bleed valve to be working while the APU is inop. Or the other way around.
charlienorth
Fri Dec 08, 2006 2:49 am
To add to that,any MEL items will show up on the release,so the crew will know of restrictions,and also to brief the cabin crew of any items which might affect service i.e. ovens,coffee makers,that type of stuff,some items also require a call to dispatch and routing in case of the impact it might have downline...airstart units at an airport..enroute weather forecasts which might restrict flights...as 777WT posted it helps planning and mx control if we provide any troubleshooting info that may help with ordering parts and schedulin downtime.
Buyantukhaa
Fri Dec 08, 2006 2:50 am
Quoting ReidYYZ (Reply 22):
Brilliant!!!!!
I scratch my head, therefore I am.
Fri Dec 08, 2006 9:53 pm
Its similiar out here,however the terms used are very much different.Thanks for the update.
regds
MEL
charlienorth
Sun Dec 10, 2006 12:40 am
Quoting HAWK21M (Reply 34):
regds
MEL
The problem is here the terms can be different between operators,so going to another co. you have to leave some of your "past life" behind. It's all basically the same idea just slightly terminology.
Sun Dec 10, 2006 2:03 pm
Quoting Charlienorth (Reply 35):
Its amazing how even asimiliar component is reffered to differently namewise by the Airframe & Engine AMMs.
regds
MEL
ex52tech
Wed Dec 13, 2006 4:20 am
Ok guys this is a little long but bear with me.
The 727-100 engine fire loops when tested are actually heated, current is applied to them, they heat up and set off the light and the bell. Procedure is to pull the circuit breakers and test them one at a time, cutting the bell out with each one tested. You only test them once with each flight leg, they can burn out.
I get a call out to a gate, as I come in the aft stair door I hear the fire bell sounding, as I get to the mid cabin galley I hear the bell again.
I enter the cockpit and find the FE doing his preflight.
Me: Whats wrong?
FE: The fire warning test isn't working right.
At this point he hits the test button, for the third time that I know of,.The #1 fire handle lights up, bell sounds, #2 and #3 fire handles light up at the same time, and he says "see it's not right".
Me: did you pull the breakers on the other two and test them one at a time like you are supposed to do?
FE: Why would I want to do it that way? That's not how you test it!
Me: Yes it is, this is a 727-100......and I preceded to tell him how the system works and how to test it again.
By this time the captain has arrived and he is listening to me explain this to the FE. The FE reaches for the button to test it AGAIN so the captain can see what the problem is, and I say "Don't touch that button again, you burn those fire loops out and the airplane is out of service"
FE: That's not how it works on all the other 727s I fly.
Captain: Looks at me and says "can I see you on the jet bridge".
I take the logbook out on the jet bridge and sign off the write up.
Captain: Sorry about that, I'll take care of it...ok.
Me: Have fun chief.
AT that point the captain went back to the cockpit and I let the jet bridge door slam but stayed on the jet bridge.
Captain: You [email protected]&!ing moron, do you realize how stupid he thinks you are, I'm not sure if I want to fly with you!
FE: But....But....but.
Captain: He's right about how you test that system.......idiot!
I slid out of the jet bridge door giggiling like a little kid.
"Saddest thing I ever witnessed....an airplane being scrapped"
charlienorth
Wed Dec 13, 2006 5:01 am
Quoting Ex52tech (Reply 37):
 rotfl The other good one with a newbie F.E. on a B727 was the call,APU shutdown on the gate,go in the cockpit Capt and FO in their seats arms folded aircraft dark...what happened...just testing the APU fire test....that's why it shut down...from the other two was an almost simultaneous "DUMBASS..but you didn't listen"
JAFA
Wed Dec 13, 2006 6:57 am
I have a couple:
"Captain's ding dong is too soft"
"Coffee maker only makes hot water"
cactusTECH
Sun Dec 17, 2006 9:27 pm
The best one that happen to me was a DO328jet that came back to the gate for NO ENG START ON EITHER ENGINE.
My corrective action after looking at configuration of flight deck was
....SELECTED APU BLEED ON, BOTH ENG STARTS NORMAL AT THIS TIME.
flametech21
Mon Dec 18, 2006 3:25 am
Almost wet myself reading that!  rotfl
Here's a few of my own:
MD82:
"Loud, baby-like whining noise coming from under the cockpit."
Nose gear hydrualic pump told to toughen up and act like a man, ops check good."
ex Reno MD87, before we got rid of them:
"Forward airstair won't extend, had to call for stairs truck to deplane."
"AC not equipped with forward airstair, try deplaning through the aft one. Ops check good."
They build them to a higher standard at Long Beach!
777wt
Mon Dec 18, 2006 4:27 am
Just this one from yesterday call on one of the aircraft for a missing observer headset... came to the plane with a new one only to be told that they found it in the cockpit....... Told them to write 'Entered in Error' in the logbook.
Other one from sometime back, they couldn't find the other logbook which a new one was installed. The new one didn't have an Airworthiness release, it was in the old one and they called us for it.
And the plane was already boarded with pax...
Came to the plane and found the old logbook right behind the captain's seat....
flametech21
Mon Dec 18, 2006 5:46 am
Quoting 777WT (Reply 42):
We usually keep an extra headset, logbook, QRH, and other essentials in the front wardrobe to keep stuff like this from happening.
Although we have had a few pilots that were so stupid that they forgot to look here and called mx anyways...  banghead
777wt
Mon Dec 18, 2006 7:28 am
Quoting Flametech21 (Reply 43):
The logbook they were looking for had an airworthiness release signed in it and it was full already, the new one only had a few pages used and it wasn't in it, it was supposed to be stored inside the metal logbook case but for some reason they left it out because the end of the logbook was curling and causing problems keeping it shut closed.
I wish I could have the often needed parts left in the truck to save the time it takes to get back to the office and finding the parts in the parts dept. It used to be like this from what I was told but then the manager moved everything back into the office because people wern't signing them out in the truck and parts dept lost track of them.
So since it's being done this way, I'm not going to rush to get the parts. If it has to cause a delay for a minor thing, then there's the reason why.
zvocio79
Mon Dec 18, 2006 12:52 pm
i dont know if you were working with us then 777WT but once we got a call from Shuttle to go on a roadtrip to JFK, the book said something like this:
"upon taxing a passanger reported a loud grinding noise coming for the left hand inboard landing gear brake"
i always wondered if the passenger knew the tire pressure and the O2 chrage as well.
777wt
Mon Dec 18, 2006 3:13 pm
Quoting Zvocio79 (Reply 45):
How could the pax know it was the left hand inboard brake and not the l/h outboard brake...
Since 2 months ago, We don't do roadtrips for shuttle anymore.
Now a contractor does it.
About 2 months ago, the manager set up a conference call with the DM, Shuttle Mtx Ctrl and their managers and he told them we only do contract work for them if we have time. If not, then they will have to call a contractor if we're busy with the planes we're working on.
And to respect us more when calling us. No demanding or do this and that. Just ask if we can do it and if we tell them we're kinda busy, they have to call a contractor from there on.
This was because they were basically telling us "YOU MUST DO IT" for a reinspection and it wasn't done and the plane took off.
Even told them that they can't give us more than a few service checks because we are not their mechanics, we are for the company planes and contract if time is avail, and they must contact our company mtx control first to see how busy we are and how's the day looking.
Ever since, it's been a bit better.
charlienorth
Wed Dec 20, 2006 1:40 am
How about this one.."Lav stinks"
Ratzz
Wed Dec 27, 2006 6:23 am
-At one time I was about to tow away a 767 from it´s gate to a remote parking during it´s nightstop and found a friend of mine crawling in the fwd lav.
-He had already torn almost the entire assy.apart:panels,pipes and the chair..obviously searching for something and got a little disturbed as I asked him to stop whatever he was doin´and get into the captain´s seat to watch the tow and apply brakes if needed ( this was a snowy cold winter night).
-A qiuck glance in the log told me why the entire fwd lav was scattered all over the fwd parts of the cabin,the note read:"Fwd toilet stinks"...
-We completed the tow and went back to the toilet problem...of course nothin´was found malfunctioning so the toilet was restored into working order and the note was written off as :"Fwd toilet always stinks after use,ops check ok"..
Valcory
Wed Dec 27, 2006 8:14 am
How about this one,A F/O on a 757 said when starting APU the EGT spike then decrease i was like that's why they are called Hot Starting Garret.
Users browsing this forum: jetmatt777, Zeke2517 and 29 guests
