Page 1 of 1
Turbine Cooling Tech Questions
Posted: Wed Jan 24, 2007 10:42 am
by Blackbird
Was some turbine cooling technology patented? For example GE's J-93 first turbine stage featured hollow with holes drilled in the rear of the blades, and GE-used this in later designs.
BTW: While not turbine cooling related, I felt like asking anyway-- was variable stators ever patented?
-Andrea K
RE: Turbine Cooling Tech Questions
Posted: Wed Jan 24, 2007 11:18 am
by kaddyuk
Posted: Thu Jan 25, 2007 1:11 am
by grandtheftaero
Quoting Blackbird (Thread starter):
According to About.com, Gerhard Neumann of GE was awarded 8 patents for inventing variable stator vanes. Those patents were either very loosely worded or have long since expired since Pratt and Whitney uses VSVs too. I think Roll-Royce even tried them out once but proved to themselves that and extra spool was the way to go for operability. Even Chrysler used variable stators in their turbine-powered car. Today high end turbochargers have variable vane geometry, too
Posted: Thu Jan 25, 2007 2:17 am
by Blackbird
When did Gerhard Neumann get his patents, and when was the first time Pratt used Variable Guide-Vanes?
Andrea K
Posted: Thu Jan 25, 2007 4:05 am
by grandtheftaero
The J79 was the first engine to use VSVs and it was a 1950s era engine so I assume the patents were awarded around that time.
I don't know enough about PW to tell you about their use of VSVs. Maybe a Google search will turn up something.
Posted: Fri Jan 26, 2007 3:30 pm
by TimT
I can't say anything about all of the RR engines, but the RB-211-22B uses VSV's. I used to climb in the cold stream duct to adjust them.
