Rom1
Cabin Crew, How Many?
Thu Feb 15, 2007 6:55 am
Hello.
I think the rule for the number of FA for a flight is 1 for 50 pax in high density. (at least)
Now, I was wondering how many uses:
- Ryanair for their B738 (179 pax?) ?
- Jet Blue's A320 (156 pax)
- and more importantly Southwest B737-700 (149 pax?)
- Air Tran B717 ans B737-700 (roughly 110 and 149pax?)
- Frontier on A319 and A318.
thanks in advance
Rom1
WNCrew
RE: Cabin Crew, How Many?
Thu Feb 15, 2007 7:07 am
Quoting Rom1 (Thread starter):
We don't have any aircraft that hold 149pax
737-500 = 122pax
737-300 = 137pax
737-700 = 137pax
We staff 3 FA's on ALL aircraft at ALL times. The only exception would be if a charter requested 4 FA's.
BMED
Thu Feb 15, 2007 8:17 am
They seat 189 PAX and operate with 4 cabin crew.
Living the jetset life! No better way to be
jamesbuk
Thu Feb 15, 2007 8:21 am
I always thought it was 1/48 or 1/49.
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
WNCrew
Thu Feb 15, 2007 9:21 am
Quoting Jamesbuk (Reply 3):
In the US it's 1/50 and then when you get into larger aircraft it gets more complicated.
Tom12
Thu Feb 15, 2007 9:56 am
Quoting WNCrew (Reply 4):
Interesting stuff. Could you further information on that a little more or post a link or something to read through?
Thanks, Tom
"Per noctem volamus" - Royal Air Force Bomber Squadron IX
WNCrew
Thu Feb 15, 2007 10:06 am
Quoting Tom12 (Reply 5):
Thanks, Tom
I'm looking but I can't find anything. I remember my friend at CO saying that their minimum crew for one of their aircraft was more than the 1/50 so I enquired about it. She said that since CO had certified the aircraft (FAA Evac Trials) with MORE than the 1/50 they HAVE to have that number and can't go below it...however at another carrier they hay have less depending on how it was certified. I also think number and location of exits plays into it. Then again I work on 737's what do I know about large aircraft..Ha!
lincoln
Thu Feb 15, 2007 12:36 pm
For part 121 carriers in the US, this information can be found in 14 CFR § 121.391 (I've bolded the portion relevent to WNCrew's comment about CO's staffing)
(a) Each certificate holder shall provide at least the following flight attendants on each passenger-carrying airplane used:
(1) For airplanes having a maximum payload capacity of more than 7,500 pounds and having a seating capacity of more than 9 but less than 51 passengers—one flight attendant.
(2) For airplanes having a maximum payload capacity of 7,500 pounds or less and having a seating capacity of more than 19 but less than 51 passengers—one flight attendant.
(3) For airplanes having a seating capacity of more than 50 but less than 101 passengers—two flight attendants.
(4) For airplanes having a seating capacity of more than 100 passengers—two flight attendants plus one additional flight attendant for each unit (or part of a unit) of 50 passenger seats above a seating capacity of 100 passengers.
(b) If, in conducting the emergency evacuation demonstration required under §121.291 (a) or (b), the certificate holder used more flight attendants than is required under paragraph (a) of this section for the maximum seating capacity of the airplane used in the demonstration, he may not, thereafter, take off that airplane—
(1) In its maximum seating capacity configuration with fewer flight attendants than the number used during the emergency evacuation demonstration; or
(2) In any reduced seating capacity configuration with fewer flight attendants than the number required by paragraph (a) of this section for that seating capacity plus the number of flight attendants used during the emergency evacuation demonstration that were in excess of those required under paragraph (a) of this section.
(c) The number of flight attendants approved under paragraphs (a) and (b) of this section are set forth in the certificate holder's operations specifications.
Lincoln
(Edited to fix quote)
[Edited 2007-02-15 04:37:16]
B6JFKH81
Sat Feb 17, 2007 7:49 am
Hi Rom1,
B6 now only has 150 seats on the A320 to make 36" pitch in the front of the a/c. We will be reducing to 3 f/a's in the cabin. (1 per 50)
The E190 has 100 seats and 2 f/a's. (1 per 50)
vhqpa
Mon Feb 19, 2007 2:33 pm
For Australia it's 1:36 for most aircraft not sure about the larger widebodies though.
J
"There you go ladies and gentleman we're through Mach 1 the speed of sound no bumps no bangs... CONCORDE"
ACFA
Tue Feb 20, 2007 12:59 pm
In Canada the rule is 1 per 40 pax. The government recently tried to implement 1 in 50 but the measure failed.
Viscount724
Sat Feb 24, 2007 11:50 am
As far as I know, the rule in Europe is 1 for 50 passengers. LX operate their Avro RJ85s (82 seats) and RJ100s (97 seats) with 2 flight attendants, down from 3 a couple of years ago.
When their predecessor, Crossair, operated these aircraft I believe they used 4 flight attendants due to their higher standard of inflight service in those days with hot meals for all passengers on many sectors.
Rom1
Sun Feb 25, 2007 5:25 am
Quoting B6JFKH81 (Reply 8):
Hi Rom1,
thanks a lot B6JFKH81
FlyingColours
Sun Feb 25, 2007 6:46 pm
Quoting Viscount724 (Reply 11):
Ahh yes, above minumum crew. I thought I'd let you know that various charter airlines here are planning on cutting right down to minimum crew on longer flights (their reason being, a longer flight gives the crew more time to work - the dumbest logic yet, maybe managment should try doing MAN-SSH on a 757 with 5 crew), we did it with 6 and still didn't get to sit down.
Yup Europe is 1 per 50 passengers. However there is a minumum number for each aircraft as well.
It is possible to go below minimum crew if downroute to bring the aircraft back home, but to do this you need to remove some passengers, get the Chief of Operations permisson as well as the CAA & of course the Skipper must approve also. This is really only used when a crewmember falls ill downroute, in ye olden days when there was more than the bare minumum crew on board it would rarley be used, now though.....
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
Users browsing this forum: hongkongflyer and 44 guests
