airfoilsguy
Engine Testing And Sphere What Is It? (Video)
Mon Feb 26, 2007 11:42 pm
What is the function of the giant sphere in this video?
http://www.geaviation.com/engines/commercial/genx/firstflight.html
It's not a near miss it's a near hit!!
Spruit
RE: Engine Testing And Sphere What Is It? (Video)
Tue Feb 27, 2007 1:06 am
Pure guess but if your refering to the moment when the engine is on the test rig it's a filter to stop FOD ingestion?
Spru!
E=Mc2
darkblue
Tue Feb 27, 2007 1:09 am
The large dome you saw is called a TCS dome - for Turbulence Control Structure. Each of the panels you see that make up the dome is about 3in thick and consists of thousands of holes. It's used to smooth out the airflow coming into the engine. Very useful on windy days.
grandtheftaero
Tue Feb 27, 2007 3:25 am
Also...
The sphere is only an approximate shape. Ideally the panels on the dome would be normal to the streamlines of air flow at all points and its shape would form an equipotential surface. In other words, the speed of the incoming air would be the same over the entire surface of the TCS. If you were to actually build on of these to rigorous aerodynamic rules it would actually look like a large misshapen ball of clay... esp if you have a drooped flight inlet on the engine instead of an axisymmetric bellmouth.
--Shane
Users browsing this forum: trex8 and 18 guests
