Quoting CoolGuy (Thread starter): What does a positive G maneuver have to do with it? |
Quoting KELPkid: the limiting factors would be the gravity-fed fuel system (no fuel pump ) and the oil pump in the engine cavitating. |
Quoting TristarSteve: The engine stopped, then restarted when you went the right way up again. |
Quoting B737200: Now if a aircraft were to fly upside down, not in a roll or anything, wouldn't the area of negative pressure act downwards towards the ground (sort of like the inverted "wings" on formula 1 cars designed to keep the cars on the ground) ? So then how would the aircraft stay aloft ? |
Quoting B737200: I'm assuming that if the deflection of the air is to keep the aircraft aloft is must be equal to the combined weight and suction of Bernoulli right? |
Quoting B737200: By the way does anybody (I'm assuming one exists) know the equation that gives the lift generated by Bernoulli. |
Quoting BAe146QT (Reply 8): You mean when the aircraft is inverted? Yes, I expect so. Essentially, the pressure effect would be on the opposite side of the weight/lift equation from where it normally is. |
Quote: Aircraft that are designed for aerobatics have symetrical wings. i.e. they work the same upside down as the right way up. |
Quote: For aircraft that habitually fly inverted, e.g. aerobatic planes, the wing cross section is symmetrical so that stall angle and lift characteristics are the same regardless of the attitude of the aircraft. |
Quoting B737200 (Reply 14): can you suggest any textbooks on aerodynamics |
Quoting CoolGuy (Thread starter): The exceptions would be the A320, A330, A340, A380, and the 777 because the flight control laws for their fly by wire software will not let them do it. |
Quoting B737200 (Reply 4): During normal flight the curved upper surface of the wing creates an area of negative pressure which creates lift. Now if a aircraft were to fly upside down, not in a roll or anything, wouldn't the area of negative pressure act downwards towards the ground (sort of like the inverted "wings" on formula 1 cars designed to keep the cars on the ground) ? So then how would the aircraft stay aloft ? |
Quoting B737200 (Reply 4): I'd imagine that in such a case the combined forces of weight and suction from the wings' pressure differences both acting downwards and the lack of anything to counter it would cause the aircraft to fall to the ground. |
Quoting B737200 (Reply 16): Just a point of order. It's not really suction from the lower pressure above. It's the higher pressure below the wing that pushes up. |
Quoting B737200 (Reply 14): You guys seem like you really know your stuff, can you suggest any textbooks on aerodynamics I can order (I don't really enjoy looking this stuff up on the internet)? |
Quoting B737200 (Reply 7): I'm assuming that if the deflection of the air is to keep the aircraft aloft is must be equal to the combined weight and suction of Bernoulli right? |
Quoting Starlionblue (Reply 17): Does the 777 really limit this? I don't think so. |
Quoting CoolGuy (Thread starter): For the second part, what does the software restrict? No more than 45 degrees? |
Quoting BAe146QT (Reply 8): I'm not really clear on what would happen to the airflow on the "top" of the wing at this point, (which is the normal bottom of it, of course). Flying normally, the upper surface of the wing is designed to encourage laminar flow and maintain the boundary layer in a predictable shape. The underside is not going to be as good at this and I would think you would have turbulence (with a corresponding increase in drag) and maybe even a higher clean stall speed. |
Quoting David L (Reply 19): But, in a barrel roll, the aircraft is supposed to lose some altitude when inverted anyway - it's inverted at the top of the spiral and the right way up at the bottom of the spiral. |
Quoting FredT (Reply 18): For your typical wing in the typical regimes of flight, the delta between ambient pressure and the low pressure on top of the wing is significantly larger than the delta between the ambient pressure and the high pressure below the wing. In addition the area on top of the wing will be larger. This means that it is indeed correct to say that lift (mainly) sucks! |
Quoting Starlionblue (Reply 21): The process pushes the wing up. It's not the lower pressure "calling" the molecules to it. |
Quoting David L (Reply 23): The only things allowed to suck in physics are exams. |
Quoting Starlionblue (Reply 24): Black holes too surely? |
Quoting Starlionblue (Reply 24): Which reminds me of the following bash.org transcript: |
Quoting David L (Reply 25): 1 part gin, 1 part Vermouth, extra dry, 1 part Vermouth, Bianco, as many green olives as you can fit on a cocktail stick (I don't think there's a limit on the size of the cocktail stick). |
Quoting David L (Reply 25): No, still not allowed... unless you feel you're being sucked on to the surface of the earth. |
Quoting FredT (Reply 27): And Starlionblue... for posting that bash.org link... you owe me 30 minutes of my life! Thanks man, got a few good laughs there. I used to be a computer geek before I converted to aero engineering (and became a dual purpose geek). |
Quoting Starlionblue (Reply 17): Just a point of order. It's not really suction from the lower pressure above. It's the higher pressure below the wing that pushes up. Not quite the same thing. |
Quoting FredT (Reply 27): and often for the sake of convenience will, be (drumroll) designated suction. |
Quoting N231YE (Reply 29): I was told the correct response is, "the relatively higher pressure (in relation to the ambient surroundings) below the airfoil and the relatively lower pressure above the airfoil interact to generate lift." |
Quoting Starlionblue (Reply 28): Quoting David L (Reply 25): No, still not allowed... unless you feel you're being sucked on to the surface of the earth. I know. |
Quoting Scooter01 (Reply 26): Cover the bottom olive |
Quoting David L (Reply 30): Quoting Starlionblue (Reply 28): Quoting David L (Reply 25): No, still not allowed... unless you feel you're being sucked on to the surface of the earth. I know. Ah, OK. Just a security check - you can't be too careful |
Quoting CoolGuy (Reply 32): For commercial airliners, is it a rule that aircraft cannot bank more than 30 degrees? |
Quoting CoolGuy (Reply 32): Also is there anything else that the FBW systems do not permit? Like a very quick climb? I remember hearing that the system will automatically prevent a stall by pushing the stick down at high angles of attack, though a pilot can try to override it. |
Quoting Starlionblue (Reply 24): For those who don't know, bash.org collects funny or outrageous IRC (Internet Relay Chat) transcripts. Before you click this link, make sure you have an hour to kill and a penchant for chatroom humor. IMHO one of the funniest sites on the web http://bash.org/?top |
Quoting A320ajm (Reply 40): The fly by wire system ca be turned off on the aircraft mentioned and can do barrel roles. |
Quoting BAe146QT (Reply 5): modified to fly in the southern hemisphere |
Quoting ThirtyEcho (Reply 34): Tex was THAT good |
Quoting AirSpare (Reply 42): Quoting BAe146QT (Reply 5): modified to fly in the southern hemisphere Don't props spin in the opposite direction also? uggh, sorry about that one, flame away. |
Quoting AirSpare (Reply 42): damn, I'm trying to remember the name of the WWII pilot that performs airshow demos in a Shrike Commander, I saw a video of him rolling the Shrike while another guy poured a glass of ice tea. He is an excellent pilot, I talked with him for 10 in Reno, nice person also. How could I forget. Ah yea, Bob Hoover, in his big floppy hat. |
Quoting 474218 (Reply 43): Maybe thats why the P-38 was such a good fighter during WWII. It's props turned in opposite directions, making it a efficient in both the European and Pacific theaters. |
Quoting Starlionblue: Well, first of all, the earth is flattened to the equator is slightly closer to the center than the poles. |
Quoting Starlionblue (Reply 44): Bob Hoover in action: http://www.youtube.com/watch?v=9ZBca...xGHjE |
Quoting BAe146QT (Reply 45): Quoting Starlionblue: Well, first of all, the earth is flattened to the equator is slightly closer to the center than the poles. Are you sure about this? The Earth is an oblate sphere, but the bulge is at the equator. |
Quoting BAe146QT (Reply 45): Quoting Starlionblue: Well, first of all, the earth is flattened to the equator is slightly closer to the center than the poles. Are you sure about this? The Earth is an oblate sphere, but the bulge is at the equator. Think about it - centripetal force means that the bulge has to be perpendicular to the axis of spin. |
Quoting David L (Reply 47): I have to agree with BAe146QT on this one. I seem to recall that the force of gravity is about 9.81 ms-2 at the equator and about 9.83 ms -2 at the poles. |
Quoting Starlionblue (Reply 48): However this doesn't change the fact that balancing an egg on a nail isn't any easier at the equator. CoG is CoG wherever you are. |
