Quoting SlamClick (Reply 3): Stop, set parking brake. Shut down left engine. Offload passengers with right engine running. Crossbleed start left engine. Shut down right engine. Offload bags. Load outbound bags. Crossbleed start right engine. Shut down left engine. Board passengers. Crossbleed start left engine. Taxi away. |
Quoting HAWK21M (Reply 6): Using a trestle to access the APU inlet door on the RH side of a B737 to tap it in ,ensuring the microswitch contacts to continue the start sequence. |
Quoting Tristarsteve (Reply 8): Not quite in the same vein but, In the early 80s Gulf Air had two US registered Tristars, N92TA and N92TB. These were run under an FAA log book/MEL etc. One of them had a defect with the Slat PDU (sorry can't remember what) and had a 3 day MEL which ran out Thursday. Under CAA rules, which the other L1011 were under this was an unlimited time defect(in those days). We had to approach the FAA in FRA for a disp to continue to fly the aircraft until we got a new slat PDU due Sat. No answer. So on Thursday afternoon Colin and I interchanged the slat PDUs with another L1011 to get both aircraft flying Thursday night (when the whole fleet was in the air). |
Quoting DeltaGuy (Reply 9): Moved a P-51 with a John Deere tractor and a chain |
Quoting SlamClick (Reply 12):
Quoting DeltaGuy (Reply 9): Moved a P-51 with a John Deere tractor and a chain Moved an L-188 with a puny old half-ton Chevy pickup. Moving it was not a problem. Stopping it was. Wow! |
Quoting 474218 (Reply 11): Good story Steve; However, the only part of the L-1011 slat system that has MEL relief is the indicating system. If the PDU was inoperative you can not dispatch a TriStar as it must have the slats operational. |
Quoting MD11Engineer (Reply 15): Giving the nav lights on the wing tip of a 727 a "technical tap" |
Quoting TheGreatChecko (Reply 7): Things I've seen done to get a 1900 moving: Rocked back an forth by pushing on the wings to help crack ice that has frozen the brakes when the brake deice is inop. Watched a 1900 slide around on the ice outside a terminal for the same reason. Lesson learned: "Don't taxi through snow piles if you can avoid it!" Checko |
Quoting Boeing767mech (Thread starter): My example 6 of us had to jump up and down to get the outer wing tank to drain down to the middle wing on a DC-10, |
Quoting MD11Engineer (Reply 15): Giving the nav lights on the wing tip of a 727 a "technical tap |
Quoting Jetstar (Reply 21): During an engine change the QEC which was attached to the airframe with 4 bolts, we were only able to get 3 bolts in, the fourth was just a little off, instead of forcing or hammering the bolt in, I went out to the wingtip and started to jump up and down, the wing flexed enough so they were able to get the last QEC bolt in. |
Quoting MD11Engineer (Reply 25): On the 737 classic there is a bracket beneath the main gear actuator in the main wheel wells |
Quoting Buzz (Reply 28): While doing 737-300 accel runs, we'd need to tweak the flight idle speed. Of course we're out on a deserted taxiway and no ladder to get down out of the airplane. Idea: flaps out to 10 degrees (leading edge slats full extended), go out the overwing exit, jam my feet into the outboard half of the fan exhaust (engine shut down of course), hold onto the aft edge of the slats and slide down. I might even still be able to crawl back up on top the wing that way... it's been several years. Anyway, tweaked the flight idle, finally passed the acceleration check, taxi back to the terminal. Things happen at night. |
Quoting Cancidas (Reply 5): last time we did that with a CRJ-700. 67 pax, 92 bags, 12000 lb of fuel in 28 minutes. |
Quoting N710PS (Reply 30): Been there done that! Not with you though obviously. When we work together it is for some reason flawless except for you bitching at me about a missed entry. |
Quoting MD11Engineer (Reply 29): he let himself hang be his hands from the trailing dge of the pylon and let himself drop down to the ground. |
Quoting CanadianNorth (Reply 33): At Air North our front end loader, large forklift and aircraft tug are all the same vehicle |
Quoting Boeing767mech (Thread starter): My example 6 of us had to jump up and down to get the outer wing tank to drain down to the middle wing on a DC-10, because the float switch in the middle tank did not open letting the fuel out of the outer wing tank. The |
Quoting HAWK21M (Reply 34): How about control panel.Is it the same for each function or at different locatons on the vehicle. |
Quoting CanadianNorth (Reply 36): But apparently it's much the same as a normal loader |
Quoting Gr8Circle (Reply 35): Wow! If I was a pax in a plane and looked out of the window and saw six guys jumping up and down on the wing, I would be seriously worried.... |
