txkf2010
Simultaneous Taxi Into Position & Hold On...legal?
Wed Sep 26, 2007 3:26 pm
So in calgary about 6 weeks ago and was told 2 taxi into position and hold but 2 roll forward about 400ft so a 727 could also be in position and hold behind me, on runway 34. Ive looked all around and didnt find anything bout this being legal or not legal. Anyone know for sure or seen this b4? Controllers, other pilots?
ACDC8
RE: Simultaneous Taxi Into Position & Hold On...legal?
Wed Sep 26, 2007 4:13 pm
I couldn't find anything either, but from what I remember (having this happened during my flight exam) is that it is legal as long there is still sufficient runway length for take off and is at pilot's discretion if they feel it's safe or not safe. The same is with intersection take-offs (departing from another point on the runway other than the threshold), they are technically illegal however, can be made if the same criteria as above are met.
Perhaps, someone who isn't as tired would care to check up on the CAR's or AIP for a definitive answer.
A Grumpy German Is A Sauerkraut
cloudyapple
Wed Sep 26, 2007 4:47 pm
It's legal. Line 2 up on the runway so that the second one is ready to roll once the departure separation is satisfied. This used to save a few seconds. Add a few double line ups together that's an extra slot. It's done at Heathrow, Hong Kong, you name it, and these are major international airports.
Usual caveats - subject to local CAA rules and sufficient distance between the 2 to prevent jet blast/FOD.
A310/A319/20/21/A332/3/A343/6/A388/B732/5/7/8/B742/S/4/B752/B763/B772/3/W/E145/J41/MD11/83/90
theginge
Wed Sep 26, 2007 5:01 pm
They line up 2 at a time at LHR using the intersections to get traffic away a bit quicker.
InnocuousFox
Wed Sep 26, 2007 11:09 pm
I've seen it before at OMA but it involved a small private aircraft in front of a commercial jet. Not a lot of jet blast there.
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
kstatepilot
Wed Sep 26, 2007 11:28 pm
At PHX they clear the first aircraft to takeoff and immediately clear the second on to taxi into position and hold. Not exactly the same, but pretty close.
atct
Thu Sep 27, 2007 12:21 am
Ehhh. I wouldnt do it as a pilot or as a controller.
Two aircraft in position at the same time from the SAME interesection, thats illegal as far as I can see. (I also think youre an incompetent controller if you "have" to do that). Now one at an intersection in position and one full length, well this changes daily it seems with the FAA. We can do it during daylight, but not between sunset and sunrise I believe at the moment.
ATCT
Trikes are for kids!
Acey
Thu Sep 27, 2007 12:46 am
Quoting Kstatepilot (Reply 5):
That's done at every airport that uses position and hold, so it's a not an issue.
If a man hasn't discovered something that he will die for, he isn't fit to live. -- Martin Luther King, Jr.
B6JFKH81
Thu Sep 27, 2007 1:03 am
I have done this during the summer when there are a lot of GA departures. They would have some a/c taxi for a full length departure, some for an intersection departure. It was interesting to be in a Warrior III and have a GV right behind me LOL!
JRadier
Thu Sep 27, 2007 2:35 am
Quoting Theginge (Reply 3):
I've seen 3 at AMS. 2 at the beginning of the runway, and an F50 on an intersection
NWA ARJ
Thu Sep 27, 2007 3:05 am
It just depends upon where you go. In Fargo, ND they have done away with TIPH all together. Same at Bismarck, ND. And the airports that do do it have a waiver of some kind. And now the FAA says we cannot put two into position and hold simultaneously on the same runway
Nightmare 68, Fargo Tower, Runway 36, Fly Runway Heading, Mantain 10,000, Cleared For Takeoff, Change To Departure
9VSIO
Thu Sep 27, 2007 4:29 am
Here's another example: while at EGLC in little cessnas, there were two of us holding at the same point as a bizjet took off, then the guy ahead of me was instructed to enter, backtrack and line-up. I was then instructed to backtrack and line up behind the first cessna. So we positioned ourselves on the centreline while he was slightly to the right. Sounds silly, but I got more of a rush from this t/o. Reminded me of the photos of two planes being shot off a carrier! So far, its the only time that I've experienced it.
As we were both staying in the pattern, the separation wasn't that much resulting in a slow downwind leg so I wouldn't have to go around!
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
Mir
Thu Sep 27, 2007 5:30 am
I've done it many times as a pilot, all during daylight hours, and all in light aircraft. They'll line three up on the runway and then give them takeoff clearance once the required separation is established.
This was a few years ago, however, and I understand that the TIPH rules may have changed since then.
-Mir
NWA ARJ
Thu Sep 27, 2007 8:33 am
Yea it used to be done alot. At VFR towers I would do it all the time as a pilot. But as MIR pointed out it was changed a few years ago, in the US you cannot put two or more simultaneously into position and hold on the same runway.
P3Orion
Thu Sep 27, 2007 1:01 pm
Quoting NWA ARJ (Reply 10):
If you miss using TIPH, put in your paperwork and come down to ORD. We need people.
Baker's 7 year, Carpano Antica, Luxardo, Bittercube cherry bark vanilla bitters
737tdi
Thu Sep 27, 2007 4:25 pm
Now that we (my airline) have a ton more flights leaving early. When we are taking aircraft back to the gate from the hangar, I have been cleared across the runway but told to hold short of taxiway Charlie. If you look at most airports this is a very limited space. The first time the controller told me to do this I hesitated and asked him to repeat his instructions. One of our birds took off behind me and that gave me room to get between the other 4. About 0600 at Love Field. Dang it's getting busy here. I am taxi/run qualified and a licensed pilot. You will be amazed at what will be asked of you in your flying experience. Just be safe.
737tdi
Mir
Thu Sep 27, 2007 9:06 pm
Quoting P3Orion (Reply 14):
What things do you ORD guys NOT have waivers for?  biggrin
-Mir
ednovak
Thu Sep 27, 2007 11:59 pm
Quoting NWA ARJ (Reply 13):
According to 7110.65R, para 3-9-4g2, only one aircraft can be taxied into position and hold at an intersection. This seems to imply (right?!?) that you CAN use TIPH with multiple aircraft at the end. Anyway, that's my story and I'm sticking to it.
NWA ARJ
Fri Sep 28, 2007 9:05 am
In change 3 for the 7110.65 I found this in 3-9-4i:
i.Do not authorize aircraft to simultaneously taxi
into position and hold on the same runway,between
sunrise and sunset,unless the local assist/local
monitor position is staffed.
The whole change can be found here:
http://www.faa.gov/airports_airtraff...at_orders/media/CHG3ATC8-30-07.pdf
I also found this:
f. Change paragraph 3-9-4, subparagraph f, to subparagraph g and to read as follows: An
aircraft may be authorized to taxi into position and hold at an intersection between sunset and
sunrise. The procedure must be approved by the appropriate Director, Terminal Operations
(service area office), and by the Director, Terminal Safety and Operations Support, and must be
contained in a facility directive. The following conditions must apply:
(1) The runway must be used as a departure-only runway.
(2) Only one aircraft at a time is permitted to taxi into position and hold on the same runway.
This was found in Notice 7110.465 which can be found here:
http://web.nbaa.org/public/ops/airspace/tiphnotice_200612.pdf
So it can be done with alot of waivers and if there is enough personell in the tower. Howver our ATC instuctors at the FAA academy tell us we cannot do it. So who knows
[Edited 2007-09-28 02:20:45]
2H4
Fri Sep 28, 2007 9:09 am
Quoting Mir (Reply 16):
...all the things OSH has waivers for.  Wink
2H4
Intentionally Left Blank
atct
Sat Sep 29, 2007 6:06 am
Yea at most small facilities it is done away with.
They only wish they had the waivers and skills as IAH controllers  Wink
Quoting 2H4 (Reply 19):
Next year OSH...I will wear my pink shirt proud!
P3Orion
Sat Sep 29, 2007 10:56 am
Quoting ATCT (Reply 20):
IAH? Do you ever get to say "Number two, cleared to land?" When are you gonna step up to and play in the Major Leagues?
[Edited 2007-09-29 04:05:31]
phxplanes
Sat Sep 29, 2007 4:01 pm
I got to position and hold behind a P-51 mustang who was holding, that was pretty cool.
atct
Sun Sep 30, 2007 6:58 am
Quoting P3Orion (Reply 21):
:P
ATCT
IAHFLYR
Mon Oct 01, 2007 9:06 pm
LMAO.....they only get to say #2 if we hold the first airplane someplace until the second is close!  Smile
Hey ATCT, skills, come on, you really didn't think that would fly did ya?
atct
Tue Oct 02, 2007 12:43 am
Quoting IAHFLYR (Reply 24):
It was worth a try. Not to hard to slip something past I90 people  Wink
j/k j/k
keep the blue side up and green between
ATCT
Users browsing this forum: No registered users and 25 guests
