Quoting LHRBlueSkies (Reply 2): The wings have fences, not winglets, as the advanced wing design doesn't need the extra stablising effect provided by winglets. I think! |
Quoting DL767captain (Thread starter): Is there a reason that there are no winglets on the A380 (instead of those little triangle things)? |
Quoting DL767captain (Thread starter): Is there a reason that there are no winglets on the A380 |
Quoting Breiz (Reply 8): Therefore, it does not require the winglets, but merely "wingtip fences" similar to those of the Airbus A320." |
Quoting DL767captain (Thread starter): Is there a reason that there are no winglets on the A380 (instead of those little triangle things)? Not like the 737 ones, they would probably be huge, but something like the 747-400 has. Did it just not save enough to matter? |
Quoting Breiz (Reply 8): However, the Airbus A380 has very large wing area due to the large wingspan that gives it a high aspect ratio. |
Quoting 2H4 (Reply 12): Quoting Tdscanuck (Reply 11): It doesn't need them. Well, technically, no aircraft needs winglets....the aircraft will simply be less efficient without them. |
Quoting EGNR (Reply 7): They're not so little... |
Quoting RJ111 (Reply 10): The additional weight must outweight the drag reduction benefits. |
Quoting Tdscanuck (Reply 11): A winglet only makes sense when you are span-restricted. |
Quoting Art (Reply 1): I believe it needs to fit in an 80m box at the airport. The A380 wingspan is over 79m, so winglets would take it over the 80m mark. |
Quoting Zvezda (Reply 3): Adding winglets to the WhaleJet would put the wingspan over 80 meters and then there would be zero airports with suitable gates. |
Quoting Bill142 (Reply 17): Hawker de Havilland to be specific |
Quoting 2H4 (Reply 6): The purpose of winglets is not to provide a 'stabilizing effect'...it's to reduce drag. 2H4 |
Quoting NEMA (Reply 16): So if the wingspan is currently over 79m and, it needs to fit in an 80m box, its already looking a bit tight with almost no room for error, isnt it? |
Quoting 3MilesToWRO (Reply 21): Quoting Art (Reply 18): Perhaps you don't sideslip large commercial aircraft, making my question irrelevant. If you're gliding without fuel you do |
Quoting Tdscanuck (Reply 13): To put it a little more properly...the potential performance gain for winglets on the A380 doesn't justify the cost and weight increase winglets would impose. |
Quoting Art (Reply 18): Looking at the pics in reply 7 made me wonder. What effect do large fences have when sideslipping? Wouldn't they cut a lot of wingtip lift? |
Quoting Ph-tvh (Reply 20): Adding winglets will reduce INDUCED drag to be specific..... Downside: its adds PARASITE drag and weight to the airplane |
Quoting BristolFlyer (Reply 22): 'm sure the 'room for error' has been already built-in to the 80m figure. If the airports say that the aircraft can be no wider than 80m then the aircraft can be up to 80m safely. |
Quoting Tdscanuck (Reply 13): the potential performance gain for winglets on the A380 doesn't justify the cost and weight increase winglets would impose. |
Quoting 2H4 (Reply 24): Quoting Ph-tvh (Reply 20): Adding winglets will reduce INDUCED drag to be specific..... Downside: its adds PARASITE drag and weight to the airplane Nevertheless, the net effect (of properly designed winglets) is a decrease in overall drag and an increase in efficiency. |
Quoting Art (Reply 1): A380 wingspan is over 79m, so winglets would take it over the 80m mark. |
Quoting Zvezda (Reply 3): Adding winglets to the WhaleJet would put the wingspan over 80 meters |
Quoting Bond007 (Reply 27): I'm not a genius, but I assume that if winglets were designed for the A380, then the overall wingspan, including winglets, would still be 80m or less. |
Quoting 2H4 (Reply 28): I'm no genius, either, but I would guess that such an approach would involve much more work than simply adding structural reinforcements and bolting on some winglets. You seem to be talking about a wing shortening. The mere mention of such an undertaking has probably sent a chill through the spines of many engineers over in Toulouse. |
Quoting Bond007 (Reply 29): Well, my point is that had the engineers designed winglets for the A380, it would most probably still be 80m or less. The fact that the wingspan without winglets is 80m, IMO has little to do with why it doesn't have any. |
Quoting Art (Reply 18): What effect do large fences have when sideslipping? Wouldn't they cut a lot of wingtip lift? Perhaps you don't sideslip large commercial aircraft, making my question irrelevant. |
Quoting Bond007 (Reply 27): The wingspan is 80m because it does NOT have winglets. I'm not a genius, but I assume that if winglets were designed for the A380, then the overall wingspan, including winglets, would still be 80m or less. |
Quoting Tdscanuck (Reply 11): Something's not right about this...large wing area with a large wingspan gives you a lower aspect ratio, not a higher one. |
Quoting 2H4 (Reply 28): The mere mention of such an undertaking has probably sent a chill through the spines of many engineers over in Toulouse. |
Quoting Scbriml (Reply 14): Quoting Tdscanuck (Reply 11): A winglet only makes sense when you are span-restricted. Then why do the A350 and 787 both have wing-tip devices on clean-sheet designs? scratchchin Maybe it's just to make the planes look cool. wink |
Quoting 2H4 (Reply 35): Quoting Tdscanuck (Reply 34): A raked wingtip will always have better performance Why? |
