Quoting Faro (Thread starter):
Quoting Jetlife2 (Reply 3):
We haven't given up on this idea but the problems are just as you say. |
Quoting JetMech (Reply 7): Quoting Jetlife2 (Reply 3): We haven't given up on this idea but the problems are just as you say. I've been thinking some more about the various issues. Perhaps an aft fan could be designed such that the ring of material between the turbine and fan blades is made radially thicker and axially wider. It could then act as an annular fan disc, and react the centrifugal forces of the fan blades as pure tensile loads in the annular ring. The extra axial width of the annular disc will allow a normal, fir tree fan blade attachment to be made. The creep issue could be mitigated by having the turbine blades designed such that they transmit torque forces only. Centrifugal loads can be prevented from reached the turbine blades by having a connection to the annular fan disc that is free in the radial direction. The thermal difference issue could be minimalised by using ceramic insulators between the tips of the turbine blades and annular fan disc. If the turbine blades had a radial pin at their tips to transmit torque, a cylindrical shaped ceramic insulator could be made to fit over it. The outside of the cylindrical shaped insulator then fits into a corresponding radial hole on the inside surface of the annular fan disc. This gives the radial freedom required to prevent transmission of centrifugal loads to the turbine blades, and ensures that the ceramic insulators are loaded in compression only when transmitting torque. If the subsequent conductive heat transmission is low enough, the fan blades could then be made of a material with a very high strength to weight ratio such as advanced composites. This would leave the problem of accurately placing the axis of rotation of the turbine assembly concentric with that of the annular fan disc and fan blades. For this, I propose two sets of concentric bearings. One set would support the turbine spool, and would be similar to the arrangement already used in jet engines. The bearings for the annular fan disk would be large, ring like assemblies of the same diameter as the annular fan disc, similar to the bearings used on the rear hot stream nozzles of the RR Pegasus engine (Harrier). This second set of bearings would mount to the front and rear edges of the annular disc, and the outer parts of the LP turbine casing. The annular fan disc bearings could also be designed to seal the gas path. The casing structure around the LP turbine and annular fan disc would then be designed to support both sets of bearings, thus ensuring that the spin axes of the various rotating turbo-machinery components are concentric. The remaining problem would then be issues with annular fan disk growth due to tensile straining, and somehow allowing for this in the bearing design without compromising concentricity. Regards, JetMech |
Quoting JetMech (Reply 2): The LP turbine blades of a shaft-less version would need to be incredibly beefy to withstand this force, and such a shape may be very aerodynamically in-efficent. |
Quoting Tb727 (Reply 10): There actually is another engine with an aft fan, the CF-700 series engine by GE. It is the original powerplant for Falcon 20's and most Saberliners |
Quoting SEPilot (Reply 9): Of course you could go back to tail-mounted or overwing engines, but those arrangements have their own problems. |
Quoting Jetstar (Reply 11): Later Sabreliners used the Garrett TFE 731 engine. |
Quoting Tb727 (Reply 14): Now that is an awesome engine. We have 1 FA20-5 as they are designated after the conversion. What a huge difference in fuel savings |
