gospelle
777 Crash At LHR. Auto Exit?
Thu Jan 17, 2008 5:46 pm
Here is a snip from an eye witness of today's crash landing of a 777 in London:
And then [the plane] belly-flopped into the runway where the undercarriage collapsed and it careered skidding down the runway.
[It] appeared to be on a straight line, the doors appeared to open on impact.
Is this a feature on the 777 or must it have been fast acting passengers?
2H4
RE: 777 Crash At LHR. Auto Exit?
Thu Jan 17, 2008 5:55 pm
Quoting Gospelle (Thread starter):
Doors opening on impact? Sounds more like a confused eyewitness.
2H4
Intentionally Left Blank
A10WARTHOG
Thu Jan 17, 2008 5:56 pm
Door are not to open automatically. They will open quicker because of the assist bottle, but you do not want them to open automatically due to water landing, fire, etc.
DH8PU
Thu Jan 17, 2008 6:37 pm
Just a very orginzied crew doing their job to the best of their ability.
Cabin secure and doors checked
gospelle
Thu Jan 17, 2008 6:38 pm
Quoting A10WARTHOG (Reply 2):
Understood. I was wondering more along the lines of a "button" the pilot had up front. But even then, I guess he wouldn't know which exits were blocked by fire or not. Must have just been fast passengers. It's great they exited such a large plane so quickly and without serious injury.
I did notice in one photo: http://news.bbc.co.uk/2/hi/in_pictures/7194201.stm (Picture #10) where the wind had "flipped up" the exit slide. This could be a serious problem in the right conditions. Is this a design flaw?
kaddyuk
Thu Jan 17, 2008 6:39 pm
Quoting DH8PU (Reply 3):
Exactly...
Markhkg
Thu Jan 17, 2008 6:49 pm
Quoting Gospelle (Reply 4):
Wind has always been a problem for evacuation slides. I remember a similar photo of a Pan Am Boeing 747 overwing exit back in the day flip up like that. A major problem in the past is the slide deploying under the fuselage due to heavy winds.
However, the slides are now designed to deploy in up to 25 knot winds. This is done by having the slide deploy in "stages" with a clip that holds the end of the slide to the body until sufficient inflation is achieved. Other photos show the BA 777 exit has deployed properly; a person probably just needs to hold it down and it'll be fine.
airfoilsguy
Thu Jan 17, 2008 6:56 pm
Untrained eyewitnesses are worthless. You can have 12 eyewitnesses and all 12 will tell a different story. Anything they say can be taken with a grain of salt. The news media loves them because they tend to be emotional but investigators put little credence on what they say.
It's not a near miss it's a near hit!!
tdscanuck
Thu Jan 17, 2008 7:02 pm
It's not really a design flaw, more of a known issue with large light objects hanging out in the wind. It's part of the reason why the evacuation test has to be done with only half the exits.
Tom.
Tristarsteve
Thu Jan 17, 2008 8:19 pm
The slides are not completely airtight. They are designed to inflate, and stay inflated for the 90secs it takes to evacuate. Then they will slowly leak down, and get blown by the wind.
there is no master control. Each door will only open when the handle is turned. Also on the B777 there are "flight locks" on every door to stop it opening. They are deactivated at 80kts.
gospelle
Thu Jan 17, 2008 10:20 pm
Quoting TristarSteve (Reply 9):
80kts as measured by what?
the wheels? (if so, what happens in a skid, or when the wheels break off or do not deploy)
air speed? (if so, what happens on a very windy day?)
something else?
Tristarsteve
Fri Jan 18, 2008 8:05 am
Quoting Gospelle (Reply 10):
The IRS.
Fri Jan 18, 2008 8:37 am
its probably the Crew aware of the situation & manually opening them.
Eyewitness if not aware of Aircraft details can be misleading most times.
regds
MEL
flymatt2bermud
Fri Jan 18, 2008 1:39 pm
Has anyone heard any theories on why the 777 landed short?
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward" Leonardo Da Vinci
gospelle
Fri Jan 18, 2008 6:04 pm
Quoting TristarSteve (Reply 11):
The IRS.
The what??
KELPkid
Fri Jan 18, 2008 6:17 pm
Quoting FlyMatt2Bermud (Reply 13):
Too many. I suggest you read the four threads in civ/av...
wjcandee
Fri Jan 18, 2008 6:29 pm
Quoting Gospelle (Reply 14):
The IRS.
The what??
IRS = Inertial Reference System.
tdscanuck
Fri Jan 18, 2008 6:37 pm
Loss of engine power on short final is the leading contender so far. Speculation as to why they lost engine power is wide open.
Tom.
Fri Jan 18, 2008 7:41 pm
Zkpilot
Sat Jan 19, 2008 2:29 am
Not completely (thats pretty hard to do) but they are airtight.... hence why they are called sliderafts.... ie in a ditching the slide becomes a raft.... wouldn't be much use if it deflated after 90 seconds!! They do have ways of manually keeping them inflated of course but they are designed to remain inflated for many hours if not days.
64 types. 45 countries. 24 airlines.
Markhkg
Sat Jan 19, 2008 4:17 am
Quoting Zkpilot (Reply 19):
sliderafts
Not all evacuation slides are slide/rafts. Some are only "flotation devices" rather than an actual raft. Slide/rafts are typically designed to be wider, have a means to enter the raft with a ladder, and have an external canopy that can be erected.
But, regardless, they do stay inflated for a long time, so long as there isn't extremes in heat and cold. In a raft situation they do have a pump to top up the air.
redflyer
Sat Jan 19, 2008 4:41 am
Quoting KELPkid (Reply 15):
Try five. Soon to be six at the rate it's going.
A government big enough to take away a constitutionally guaranteed right is a government big enough to take away any guaranteed right. A government big enough to give you everything you need is a government big enough to take away everything you have.
KELPkid
Sat Jan 19, 2008 5:27 am
Quoting RedFlyer (Reply 21):
It was four when I posted that  Wink
scbriml
Sat Jan 19, 2008 2:32 pm
Quoting Airfoilsguy (Reply 7):
Indeed. The astonishing thing for this frequent flyer was how many of the pax we saw interviewed on TV said they were unaware it was a crash landing!  Wow!
airfoilsguy
Sat Jan 19, 2008 3:56 pm
Quoting Scbriml (Reply 23):
But they did think it was the fastest and most efficient plane de-boarding they ever experienced, though the distance that the plane parked from the gate left much to be desired.
gospelle
Sun Jan 20, 2008 12:00 am
Quoting Airfoilsguy (Reply 24):
And they're still waiting for their luggage!
iwok
Sun Jan 20, 2008 7:00 am
Having grown up in the colonies, I learned to love the English stiff upper lip.
"Ahh, a crash you say? By jove, and all I though was that we had hit a wee bit of turbulence on the way down. Splendid. Tee off at five. Ta ta old boy"
 Smile
iwok
avioniker
Sun Jan 20, 2008 11:49 am
Anybody besides me notice that the fan is only slightly fractured on the #1 engine and the #2 appears intact?
If there was fuel available I'd like to forward the speculation of a FADEC failure causing uncommanded shutdown. Anyone else?
 Silly
avioniker
Sun Jan 20, 2008 9:50 pm
Sorry
I moved my two cents over to the other thread on the subject.
[Edited 2008-01-20 14:05:41]
KELPkid
Sun Jan 20, 2008 10:16 pm
Quoting Avioniker (Reply 27):
Well, in a recip bird, a lack of engine/prop damage usually signifies that the engines weren't under power at the time of the accident...wonder if there's any correlation here?
Zkpilot
Tue Jan 22, 2008 12:53 am
Quoting MarkHKG (Reply 20):
On 777 they all are...
Tue Jan 22, 2008 4:41 pm
How many of these were 1st timers  Smile
Looking at the wreckage they ought to have known.
regds
MEL
Thrust
Tue Jan 22, 2008 5:58 pm
Agreed. A classic example of this is TWA Flight 800. What people thought may have been a missle heading for the plane was likely either the plane's nose falling off or the vapor trails the engines left I guess as the wings bled out fuel after the first explosion and subsequent break-up of the 747.
Fly one thing; Fly it well
litz
Tue Jan 22, 2008 6:32 pm
up to seven now (and 100+ posts into #7 at that) ...
- litz
avioniker
Thu Jan 24, 2008 6:05 pm
I stand (sort of) corrected. . .
BA38 #2
BA38#1
[Edited 2008-01-24 10:08:00]
KELPkid
Thu Jan 24, 2008 8:04 pm
Quoting Avioniker (Reply 34):
Wonder if mud injestion tests are performed for certification or by the manufacturer  bigthumbsup
Tristarsteve
Thu Jan 24, 2008 8:40 pm
I really think this a red herring. One of the engines has ingested some landing lights, and one hasn't.
Doesn't prove that one was running and one not.
Users browsing this forum: No registered users and 42 guests
