Quoting Blackbird (Reply 2): So a supersonic compressor can be shorter for the same pressure ratio? |
Quoting Lehpron (Reply 1): What velocity was it capable of at seal level? |
Quote: These shock waves are positioned within an inlet duct by moving the inlet spike (for example a English Electric lightning, SR71 Blackbird, various MIG fighters), or inlet duct "ramp doors" as found on Concorde. Spikes move forward and backwards, and doors move up and down, which set up multiple shock waves within the inlet. Every time delivery air passes through these shock waves it is slowed to a final velocity of around 0.86 mach which I think is the optimum speed for air to be delivered to a compressor. In the Concorde, there were three shock waves present, which means the air was slowed three times before meeting the first stage of compressor blades. |
Quote: Supersonic and transonic compressors most certainly do exist. In fact they seem to be commonplace, at least for military engines. Allowing the airflow in the compressor to become transonic allows a higher stage loading and so smaller and lighter compressors. I found these course notes while googling supersonic compressors. http://www.adl.gatech.edu/classes/propulsion/prop12.html This is a bit different from allowing the airflow into the compressor to be supersonic, but when you add in the rotational velocity of the blades it is easy to get local flows above M=1 in the first and subsequent stages. |
Quote: At high supersonic speed (as with the MiG-25) the compressor can be quite a modest pressure ratio (4.5:1 as mentioned in the OP) because most of the compression is from ram recovery. |
Quoting Starglider (Reply 9): Rotor and Supersonic Counter Rotating Diffuser |
Quoting Starglider (Reply 9): The website states: "Do not release on a public Web site. See NPR 2810.1A "Security of Information Technology" for details." This NPR 2810.1A document does not expire until May 16, 2011. |
Quoting Blackbird (Reply 8): Okay, so you often get supersonic flows when you combine incoming velocity (subsonic) with the rotational velocity? Across the whole stage (blade)? Or on the tips? |
Quoting Blackbird (Reply 8): Yeah, but wouldn't an engine with a pressure-ratio of 9-to-1 at the same mach-number and airspeed produce more thrust than an engine with a pressure-ratio of 4.5-to-1 as the same ram-recovery is produced in either case with a better compressor? The problems will probably be easier to deal with if it was, rather than having a mixed flow. Is it normal for an engine with a pressure ratio of 4.5 to 1 producing 27,000 or so at sea-level producing 40,000 lbf to 44,000 lbf at altitude at Mach 2.5 or so? |
Quoting Jetlagged (Reply 13): High bypass turbofans deal with supersonic air on takeoff every day. |
Quote: I have no idea, but I imagine on a low aspect ratio blade the flow will be supersonic root to tip.[/i] Wow, so even with subsonic flow, the rotational velocity would kick the speed supersonic across the whole diameter of the blade? [quote]At Mach 2.5 the adiabatic ram recovery ratio is just over 17:1. Factor in the 4.5:1 compressor pressure ratio and that is a mighty 76:1 overall ratio. More than plenty I would have thought |
Quote: The Olympus Tubo Jets Fan Blades are Super Sonic but to operate it requires Subsonic Air at the Face of the Engine. |
Quote: If Supersonic Intakes go wrong as has Happened on a Prototype Concorde the resulting Pressure inside the Ducting Caused at least one Intake Ramp to Be SPAT OUT of the Intake which is not a good thing as the Intake Ramps are rather Heavy and Quite Large. |
Quoting Blackbird (Reply 15): I didn't think you could just multiply the inlet compression by the pressure-ratio. I kind of figured that past a point when you'd build air up past a certain pressure you'd get a point of diminishing returns thing where the compressor couldn't compress the air as proportionately and (ultimately, although well above pressures ever encountered in any jet-engine) eventually the pressure would get so high that it simply couldn't compress anymore ultimately... |
Quoting Blackbird (Reply 15): While we are at it though, what is the adiabatic ram-recovery ratios for the following... |
Quoting Blackbird (Reply 15): 1.) Not designed to have supersonic or transonic flow and it is exposed to full supersonic flow, what happens then? |
Quoting Blackbird (Reply 17): How do you determine static pressure? |
Quoting Blackbird (Reply 17): None of the calculators I got can multiply something to the 3.5th power... |
Quoting Blackbird (Reply 17): How do you determine static pressure? None of the calculators I got can multiply something to the 3.5th power... |
Quote: Static pressure = ambient pressure Even the windows calculator can do it in scientific view (x^y button) |
Quoting Blackbird (Reply 23): How did I end up 42 atmospheres off? |
Quoting Blackbird (Reply 23): Step 2: (1 + 0.2 * (2.5)^2)^3.5 Step 3: (1 + 0.2 * (6.25)^3.5) |
