threefourthree
Wings Flex Up Or Down. Which Is Better?
Sun Jul 20, 2008 1:59 am
I'm doing an assignment on paper planes about distance, ailerons, winglets and wings up or down. I remember reading somewhere that when the wings flex up they give better lift?
Is that true? and if possible can you explain why or direct me somewhere.
Mir
RE: Wings Flex Up Or Down. Which Is Better?
Sun Jul 20, 2008 2:06 am
Wings flex because of the weight of the fuselage, and the flex will always be up.
You're probably referring to dihedral (wings sit at an upwards angle) vs. anhedral (wings sit at a downward angle). This has to do with stability,and in a paper airplane that isn't all that stable to begin with, dihedral is going to be preferable.
-Mir
Sun Jul 20, 2008 4:00 am
What Mir is saying is that "flex" refers to the bending, while anhedral/dihedral refer to the mounting angle.
MD-90
Sun Jul 20, 2008 6:45 am
Quoting Mir (Reply 1):
Well, unless a thunderstorm flips your airliner inverted.
Mir
Mon Jul 21, 2008 2:05 am
Quoting MD-90 (Reply 3):
In which case I'd say you have more pressing problems than your wings flexing the wrong way.  scared
-Mir
AA737-823
Tue Jul 22, 2008 12:36 am
Dihedral increases stability, as the lift vector points more toward the Center of Lift (and typically on a low-wing airplane, the CG as well). This has an affect of "centering" the airplane.
LY744
Tue Jul 22, 2008 2:00 am
Quoting AA737-823 (Reply 5):
The lift vector points the same direction regardless of dihedral/anhedral. What does change is the aircraft's behaviour in a roll-induced sideslip: with a dihedral the dipped wing is going to have the higher AOA and therefore more lift, acting to oppose the roll.
LY744.
atlturbine
Tue Aug 26, 2008 2:55 am
Modern aircraft certified in transport & normal catagories are designed to withstand approximately 3.5 positive (wings bend up) & 1.5 negitive (wings bend down) G forces. If you are in a non aerobatic airplane wings bending down would be a very bad situation.
During the certfication process on the 777 Boeing demonstrated an approximate wing bend of 19 feet in the up direction at the tip. That was over 150% of the design load limit.
To the World you might be One Person but to One Person you might be the World
411A
Tue Aug 26, 2008 4:56 am
Maximum allowed wing flex (as measured at the tip), up/down, in feet, prior to skin deformation.
DC-6B ..... 6 up / 6 down
B707 ..... 12 up / 10 down.
atlturbine
Tue Aug 26, 2008 11:59 am
Video of the 777 static wing test. Listen to that Boom when they FINALLY give!!
http://www.youtube.com/watch?v=pe9PVaFGl3o
SlamClick
Tue Aug 26, 2008 4:07 pm
Under positive G-load flexing up is preferred.
Under negative G-load, flexing down seems to work better.
Since we haven't heard from the o/p since July 19 can we infer that the subject is of no further interest to him?
threefourthree
Wed Aug 27, 2008 8:13 am
I'm still checking back, I was surprised someone replied a month after. Finished the assignment, got 20/22. Just the concept of it is a bit silly. People were doing things like which battery lasted longer, do plants grow better with music, etc etc.
Thanks for the replies  Smile
Users browsing this forum: 737tanker, BubbleFrog and 11 guests
