Quoting Tonystan (Thread starter): Has jet design reached its limits in efficiency and practicality? |
Quoting Tonystan (Thread starter): We are beginning to see new aircraft rolling off the production line which look no different to the next. |
Quoting Tonystan (Thread starter): No more t-tails or rear mounted engines. |
Quoting Tonystan (Thread starter): No more attempts at delta wings or cone noses. |
Quoting Tonystan (Thread starter): No more wing blended engines etc etc. |
Quoting Tonystan (Thread starter): The Dreamliner is perhaps the only aircraft of any note but it too only looks different from the nose, the rest is pretty standard in respects of the underwing engines, fuselage shape etc etc. |
Quoting Tonystan (Thread starter): Have we reached the pinnacle of aircraft design? |
Quoting Tonystan (Thread starter): Has computer aided technology thought us all we need to know with regards the most efficient shape of an aircraft? |
Quoting Tonystan (Thread starter): Will we need to wait for a significant leap in technology before we can expect something truly different? |
Quoting Tonystan (Reply 3): What amazes me is that the basic model of current aircraft design has been around since the first generation jet airliners first built 50 years ago. This is half the period since the wright brothers first flew. Yes the design has been refined and perfected over the years but a shame that we still seem to be no closer to a truly revolutionary design. |
Quoting RayChuang (Reply 10): combined with large-diameter front fan geared turbofans, both of which could happen within the next 15-20 years. |
Quoting Tdscanuck (Reply 2): No. It's perpetually butting up against the technology limit of the day. As technology advances, so will jet design. |
Quoting RayChuang (Reply 10): I think the next step forward will be the blended-wing body jet |
Quoting Tonystan (Thread starter): No more attempts at delta wings |
Quoting Flexo (Reply 6): What ever happened to supersonic business jets? Weren't there a couple of projects going on in that direction? |
Quoting Jbernie (Reply 8): We would probably need a major leap forward in engines before much else dramatic happens. Something along the lines of the F/A-22 Raptor which is the first jet to do non afterburning supersonic speeds. |
Quoting Art (Reply 13): A step further, it is anticipated that open rotor will improve significantly on GTF. |
Quoting Cpd (Reply 17): Concorde prototypes, |
Quoting Hmmmm... (Reply 16): Altitude wise, no improvement. |
Quoting Caspritz78 (Reply 7): Design studies for a delta wing plane are already underway. |
Quoting Jbernie (Reply 8): Something along the lines of the F/A-22 Raptor which is the first jet to do non afterburning supersonic speeds. |
Quoting Aviateur (Reply 12): The minute a new and affordable propulsion system is developed, this all changes, I think. |
Quoting Zudnic (Reply 15): The promise of ramjet technology has seemed to stagnate recently, but the same principles apply - there's just too much risk involved in the design to make it commercially viable. |
Quoting Hmmmm... (Reply 16): With the exception of fuel efficiency, there has been little change in the last 50 years. The first 50 years of aviation saw a paradigm change every 10 years. The last 50 years have seen none. |
Quoting Hmmmm... (Reply 16): If you were to ride in a 707 in 1958 and a 777 today, with the exception of the cabin furnishings, you would notice very little difference. |
Quoting Hmmmm... (Reply 16): Speed wise, there has been no improvement. |
Quoting Hmmmm... (Reply 16): Comfort wise, again virtually no improvement. |
Quoting Hmmmm... (Reply 16): Even the navigation system used is the same one used in 1958. |
Quoting Hmmmm... (Reply 16): We are still using the same basic turbine propulsion technology of 50 years ago. |
Quoting Lightsaber (Reply 18): Concorde required afterburners ('augmentors') for supersonic speed. |
Quoting Lightsaber (Reply 18): Quoting Cpd (Reply 17): Concorde prototypes, Concorde required afterburners ('augmentors') for supersonic speed. |
Quoting Cpd (Reply 17): The Concorde shape probably won't be radically altered for future supersonic airliners - but I do think there will be small improvements and refinements. I also doubt that "virtual" windscreens will be the replacement for variable geometry nose configurations, I suspect those will remain - if only because they are more trustworthy (and because they work well). |
Quoting Wingscrubber (Reply 27): The next paradigm shift is aerospace will be to bridge the gap between rocketry and winged flight. Imagine being able to take off like a conventional aircraft, ascend to 60,000ft, accelerate into orbit, complete one revolution around the earth, and then re-enter at your destination. |
