Mastropiero
Normal Law? Direct Law? Can Someone Explain?
Tue Nov 18, 2008 6:26 pm
Hi everyone!
I have come on many ocasions across this, without ever understanding what do you talk about when you refer to either "normal law" or "direct law". I have done some research but, alas, no useful results so far.
Would you mind explaining what do you mean when you refer to it?
I hope it is not something as simple as to make me blush with shame for not being able to figure it out myself....  ashamed
deaphen
RE: Normal Law? Direct Law? Can Someone Explain?
Tue Nov 18, 2008 7:00 pm
In what context do people use it??
Nitin
I want every single airport and airplane in India to be on A.net!
wilco737
Tue Nov 18, 2008 7:09 pm
Quoting Mastropiero (Thread starter):
The "normal law" is the normal way or controlling Airbus Aircrafts. like 320s or 340s. Then the airplane trims on its own and maintains the bank and pitch etc etc. With the "direct law" the Airbus flies like a boeing.
I don't know too much about it, as I am flying MDs. But I am sure the Airbus pilots will explain it to you more detailed.
WILCO737 (MD11F)
 airplane
Mastropiero
Tue Nov 18, 2008 7:40 pm
Quoting Deaphen (Reply 1):
Nitin
Check this topic, reply 68.
Cheers.  Smile
Jetlagged
Tue Nov 18, 2008 8:13 pm
Normal and direct law are levels of control provided by the FBW system
Normal Law provides envelope protection (which prevents stalls, overspeed, excessive g, etc). It also provides autotrim so the aircraft stays in the attitude it was put when the control was released (within limits).
Direct Law provides no envelope protection and the sidestick moves the control surfaces in proportion to the control input. The stabilizer trim has to be moved manually by the pilot, there is no electric trim.
In between these two there is Alternate Law, which provides much reduced protection and speed stability. Pitch trim is automatic, as with Normal Law.
Degredation from Normal to Alternate or Direct Law is automatic, depending on system failures.
A full description can be found at:
http://www.airbusdriver.net/
Look under Airbus Info, Flight Control Laws.
Tristarsteve
Tue Nov 18, 2008 10:51 pm
Quoting Jetlagged (Reply 4):
In 20 years on the A320, I have only once encountered Direct Law in flight. An A320 had a double failure of an elevator posn transmitter, and went into direct law. Saw the words direct law on the PFR.
One and only time.
Tue Nov 18, 2008 11:51 pm
Here is the page at Airbusdriver that details the laws: http://www.airbusdriver.net/airbus_fltlaws.htm
tdscanuck
Wed Nov 19, 2008 2:37 am
Quoting WILCO737 (Reply 2):
That's not true for FBW Boeing's (i.e. the 777). A 777 has normal, secondary (equivalent to Airbus' "alternate"), and direct (same as Airbus' "direct").
Tom.
PGNCS
Wed Nov 19, 2008 2:50 am
Oh, it's not THAT bad, WILCO!  Wink
Jetlagged
Wed Nov 19, 2008 3:12 pm
Quoting TristarSteve (Reply 5):
One and only time.
I suspect most pilots only ever see it in the simulator. My experience of trying Direct Law out in the sim is that it is pretty ugly, certainly worse than hand flying a non FBW aircraft.
Mastropiero
Wed Nov 19, 2008 3:29 pm
All right, thank you all for your replies.
 Smile
Coal
Thu Sep 18, 2014 12:21 pm
Sorry to bring this back from way back, but is it just me or does the whole "law" term sound really creepy? Why do they call it normal law and alternate law? Why not call it normal mode or normal configuration and alternate mode or alternate configuration?
The fact that they call it law really creeps me out. As if the machines have taken over.
Coal
Nxt Flts: SQ SIN-KIX | HD UKB-CTS | NH CTS-NRT | SQ NRT-SIN | AK SIN-DPS-SIN
rcair1
Thu Sep 18, 2014 1:00 pm
Quoting Coal (Reply 11):
Why we have, I mean they have....
I know my computer(s) seem to control my life, my car, my TV, my phone. Sometimes I wonder about my wife.
They reason they call it "law" is because you are talking about the control system 'laws' that dictate the behavior - the relationship between a/c performance, the controls and the control surfaces. In control theory, these relationships/behaviors (typically expressed as equations) are often called 'laws'.
The word 'laws' is used because it is often much more complex than a simple equation (linear or non-linear). It does represent active actions by the control system that goes beyond just relating motion of a stick to motion of a surface (that is what direct law does).
Airbus decided to use this term in their description.
When I was a senior in engineering, oh so many years ago, my senior project was to build an adaptive control system for a plant that represented a something like an antenna that moved according to a model that fit a pattern, but was unknown. I knew the basic 'equation' of the motion, but the values of the coefficients were unknown. My control system was programmed with a desired plant behavior (a different equation with known coefficients). The system had to read the behavior of the plant and based on what it saw the plant doing, adjust its inputs to cause the plant to actually operate like the desired plant.
Just to date myself - I used an analog computer http://en.wikipedia.org/wiki/Analog_computer to act as the plant. The control system was programmed in the firmware of an 8086 processor. The interface between them was some a/d's and d/a's.
Remember the three laws or robotics.....
Same thing.
I wonder if airbus follows them, and if so, when will the revolt be (See "I Robot")
rcair1
PhilBy
Thu Sep 18, 2014 1:21 pm
In this case 'Law' is a specific technical term used in control systems engineering.
BoeingGuy
Thu Sep 18, 2014 6:48 pm
Quoting Tdscanuck (Reply 7):
Tom.
Yes, not correct at all. In the Airbus FBW or Boeing FBW airplanes, when they are in Direct Mode they fly more like any non-FBW airplane.
The Direct mode on the 777 and 787 is basically an analog mode. Whatever input the pilot puts into the Flight Controls, the control surfaces move with no computer processing or envelope protection or anything. That's like a cable driven airplane.
Viscount724
Thu Sep 18, 2014 8:05 pm
How did you find a 6-year-old thread to resurrect it?
wingscrubber
Thu Sep 18, 2014 8:30 pm
A320-
http://www.smartcockpit.com/aircraft...ources/NORMAL_LAW_PROTECTIONS.html
A330-
http://www.smartcockpit.com/aircraft-ressources/A_0-Flight_Laws.html
After AF447 all Airbus pilots should be acutely aware of the meaning of 'alternate law' and the effect that has on stall protection in particular.
Sorry to lower the tone, and please don't flame me... but the flight control laws should be bread and butter of Airbus driving.
Resident TechOps Troll
Users browsing this forum: No registered users and 21 guests
