Quoting UAL747 (Thread starter): Why does aircraft design have to change so drastically from flying at Mach .86 to only go up .14 mach? It's like flying becomes a totally different being. I'm seriously no physics expert, and would like to know. |
Quoting UAL747 (Thread starter): Mach 1 is 661.7 knots... |
Quoting Wingscrubber (Reply 8): cptspeaking is right, all jet powered aircraft designed to cruise above Mach 1 usually have a variable geometry intake in the form of a moving ramp or cone which creates a shockwave to 'slow' the air. (its not quite that simple, but basically...) a traditional air breathing turbojet can only process subsonic air, hence the need to slow it. Engines such as that used on the SR-71 get into ramjet territory, and then beyond those are the pure ramjets and scramjets. |
