Max777geek
A380 Belly Doors
Thu Feb 05, 2009 12:29 pm
What might those be for ? maybe 2 ram air turbines ?
Im talking about the bigger ones, simmetric on the external side of the belly,
the ones who looks opening via a inside backward sliding panel.
Photo © Freight-Dawg - Airside Photography
RE: A380 Belly Doors
Thu Feb 05, 2009 1:18 pm
IIRC the Ram Air Turbine on the 380 is mounted in one of the flap trap fairings (canoes).
Thu Feb 05, 2009 2:56 pm
Are you talking about the Ram Air Inlet to the AC packs?
regds
MEL.
LY744
Thu Feb 05, 2009 3:15 pm
Quoting HAWK21M (Reply 2):
Sure looks like it.
LY744.
ANITIX87
Thu Feb 05, 2009 7:22 pm
I'm curious what all the openings are, from the top of the image down...
1) The large hole slightly left of center.
2) The two openings further aft that open with hinged doors (one right of center, and one left).
3) The small black circular hole at the right of the aircraft.
4) The large embedded doors at the beginning of the wing-body fairing that seem to, as the OP said, open with retracting doors.
5) The triangular openings at the rear of the fairing on either side of center.
TIS
A10WARTHOG
Thu Feb 05, 2009 8:54 pm
Quoting ANITIX87 (Reply 4):
Looks like a taxi camera to me
Maybe a cooling overboard or equipment cooling vents (that is my bet). Maybe outflow valves, I do not know the style and where Airbus installs them.
Cooling vent or it looks a lot like what the 777 has for the vacuum waste system. Again do not know Airbus aircraft
Ram air inlet for the packs
NACA inlet. It appears to be about where the A/C bays are.
jetmech
Fri Feb 06, 2009 1:32 am
Quoting A10WARTHOG (Reply 5):
I think the A380 has its PACK's in the inboard part of the leading edge. The outlets for the PACK's are the sunken rectangular areas (comprised of two squares).
Photo © Stuart Isett
Photo © Fishair
Regards, JetMech
nmeier23
Fri Feb 06, 2009 11:18 am
The fixed NACA inlets might be for pack bay ventilation.
NM
A10WARTHOG
Fri Feb 06, 2009 2:51 pm
Quoting Nmeier23 (Reply 7):
That is what I was thinking, I have worked on a plane that had that design on the A/C pack access panel
Quoting JetMech (Reply 6):
Very well could be
Finkenwerder
Fri Feb 06, 2009 8:51 pm
You are looking at....
4 x Air Generation Unit Ram Air OUTLET doors, motorised, these are the darker rectangular doors on the lower area adjacent to the wing roots, they are actually in pairs.
Then moving forward and inboard you are looking at the AGU Ram air INLET doors again motorised and opened when the packs are switched on.
The larger 2 of the centerline openings are 2 of the 4 Pressurisation outflow valves.
The smallest and nearest opening is the avionics cooling outflow valve.
Hope this helps...
 Smile
474218
Fri Feb 06, 2009 10:11 pm
The only "doors" in the belly of the picture of the A380 are the outflow valves. The other "doors" are in the fuselage to wing fairing.
Users browsing this forum: nws2002 and 34 guests
