richm
Opposite To "Positive Climb, Gear Up"?
Wed May 06, 2009 4:27 pm
Hey,
This isn't exactly going to win any awards for being a great topic, but it's just something I've been wondering.
Shortly after rotation, airline pilots usually say "Positive climb, gear up". With that in mind, what do they say/do if there isn't a positive climb at this point? (stall)
- Rich
BMI727
RE: Opposite To "Positive Climb, Gear Up"?
Wed May 06, 2009 4:37 pm
Roll the crash trucks.
IAHFLYR
Wed May 06, 2009 4:43 pm
Probably a few words which will get the famous "expletive" on the accident report when transcribing the CVR..
Mir
Wed May 06, 2009 4:48 pm
Quoting IAHFLYR (Reply 2):
That's probably the smart bet.  thumbsup
-Mir
tistpaa727
Wed May 06, 2009 4:55 pm
Technically, the opposite would be negative decent, gear down. Which would be odd because two negatives make a positive, so the plane is climbing but with its gear down...
Sorry, couldn't resist taking the thread topic literally.
Don't sweat the little things.
Stitch
Wed May 06, 2009 4:57 pm
Quoting TISTPAA727 (Reply 4):
But gear down is not actually a negative, it's just a statement of position. When landing, "gear down" is certainly a statement with positive intonations yet hearing the words "gear up" during taxi would strike me as having negative intonations. Big grin
vikkyvik
Wed May 06, 2009 5:22 pm
negative decent
Wouldn't a "negative descent" actually be a climb?
EDIT:
Wow, way to read the whole post, Vik. Sorry TISTPAAS727, you clearly beat me to that.
~Vik
[Edited 2009-05-06 10:25:22]
David L
Wed May 06, 2009 7:03 pm
... which means that "negative descent" is not the opposite of "positive climb", no matter how literally you look at it.  Smile
I suppose "BRACE, BRACE, BRACE" would be another alternative. But, seriously, if the situation dictates that "positive climb, gear up" isn't appropriate, perhaps instinct and training are just about all you have time for?
tb727
Wed May 06, 2009 8:57 pm
You probably start looking for secondary indicators of a climb(maybe look out the window) and start thinking of what you are going to do. Technically, at least the way my company does it, the PNF is looking inside for abnormalities and should call "positive rate" when you get a positive rate of climb on the VSI and on the altimeter, then the PF says gear up. I think in a lot of cases it ends up being something you just say without actually checking, you'll see that in the sim a lot with new guys on V1 engine failures.
If you truly didn't have positive rate, you would just pitch for V2 and hope she climbs eventually!
Goldenshield
Wed May 06, 2009 9:34 pm
Quoting RichM (Thread starter):
Not to nit-pick, but the phrase is "Positive rate, gear up."
Max Q
Wed May 06, 2009 9:45 pm
Depends on what part of the world you're in G Shield, 'Positive Climb' Gear up is widely used outside the US.
GGg
Goldenshield
Wed May 06, 2009 10:16 pm
Quoting Max Q (Reply 10):
You're right. I didn't notice his Union Jack.
Still, using RATE makes more sense than CLIMB, because RATE is states velocity, while CLIMB inherently states that something is increasing. So "positive climb" is really just "positive positive". Otherwise, you might as call descent as "negative climb."
zappbrannigan
Wed May 06, 2009 11:11 pm
Saying "positive rate" (apart from most likely being a company procedure) is really there as confirmation to yourself and the person in the other seat that you've visually established a RoC before selecting gear up. It doesn't mean you'll be stating something similar but "negative" if you're not climbing (well, you will be stating something to that effect, but it won't be directly related to the "positive rate" call).
There are lots of times, probably more so with light aircraft ops, where it's normal to state something before carrying out an action, simply as confirmation to yourself and others that it's appropriate to carry out the action. For instance, stating "speed below , gear down" (again, light aircraft world here) - simply confirmation to yourself and others that you've checked and confirmed airspeed below max extension speed before gear down.
swiftski
Thu May 07, 2009 10:50 am
Quoting Goldenshield (Reply 11):
I disagree.
For airfields where the ground sweeps away at the end of the runway, rad alt isn't as reliable as pressure alt, as rad alt may show rate increasing due to lowering terrain, not due to a climb.
$.02
Thu May 07, 2009 10:58 am
Really? I'm having fun now.  Smile
Goldenshield
Thu May 07, 2009 11:08 am
Quoting Swiftski (Reply 13):
Last I checked, the VSI in conjunction with the altimeter was used to verify a positive rate of climb. I mean that IS their job after all (along with verifying descent rate.)
I'm not sure where you got the Rad Alt. I never mentioned it in my post.
[Edited 2009-05-07 04:16:20]
peterpuck
Thu May 07, 2009 2:35 pm
As well, due to the position of the rad alt antenna and large size of transport category aircraft, the rad alt can show a climb with the wheels still on the ground. A cross check between the baro and rad alt's confirm a "positive climb"
readytotaxi
Thu May 07, 2009 3:20 pm
Quoting Starlionblue (Reply 14):
So does that mean we can have a "Positive Stall" ?
Growing older, but not up.
sq_ek_freak
Thu May 07, 2009 3:38 pm
Well there are a couple of (former) Emirates pilots who might be able to answer your question...  duck
Keep Discovering
Jetlagged
Thu May 07, 2009 4:09 pm
If there wasn't positive rate of climb they wouldn't say anything (about the gear anyway).
As has been pointed out above, it's not one phrase but two.
PNF: "positive rate"
PF: "gear up"
(PNF then selects gear up)
"Positve rate" and "positive climb" are different abrievations of the same thing in full "positive rate of climb".
ThrottleHold
Thu May 07, 2009 5:01 pm
Quoting Jetlagged (Reply 19):
PF: "gear up"
Depends on the company. In our SOP's, the PF calls "Positive climb, gear up".
pilotpip
Thu May 07, 2009 5:02 pm
Quoting Goldenshield (Reply 9):
Not to nit-pick, but my first regional gig used "positive climb". I know of at least a couple US airlines that use that versus "positive rate".
DMI
Goldenshield
Thu May 07, 2009 5:15 pm
Quoting ThrottleHold (Reply 20):
PF: "gear up"
Quoting Pilotpip (Reply 21):
It's pretty sad when we all start arguing over the proper way to convey the exact same message, but what would hanger flying be without it?  airplane  Of course, I think we've strayed far too off-topic now. Big grin
As far as the original question, I'd have to agree with IAHFLYR (reply 2). In fact, there's an interesting case study on that, being TWA 843, which aborted takeoff AFTER rotation.
pilotpip
Thu May 07, 2009 5:24 pm
Quoting Goldenshield (Reply 22):
It's pretty sad when we all start arguing over the proper way to convey the exact same message, but what would hanger flying be without it?    Of course, I think we've strayed far too off-topic now.
Agree 100%. I just hate it when people get on here and act like the final authority on this. There are many ways to accomplish the same thing in aviation.
DMI
tb727
Thu May 07, 2009 11:31 pm
Quoting Pilotpip (Reply 23):
I vote we should just yell "Giddy-up!" instead. lol
Phoenix9
Thu May 07, 2009 11:43 pm
Either "Geronimo" or "Wheeeeeeeee"
Life only makes sense when you look at it backwards.
kimberlyRJ
Fri May 08, 2009 9:18 am
I think a command for ‘Brace’ would be given to the cabin – that I know for sure (if the aircraft was going to make contact with the ground)
Kimberly RJ
zappbrannigan
Fri May 08, 2009 9:51 am
Quoting Kimberlyrj (Reply 26):
They'd want to be quick if they hadn't established a rate of climb at the normal gear retraction point  Smile
donniecs
Fri May 08, 2009 3:27 pm
Quoting Tb727 (Reply 8):
+1 and confirm flap position if you get a chance.
Charlie - Gulfstream flight mechanic
DocLightning
Fri May 08, 2009 9:30 pm
Well, this thread brought out the pedant in all of us, huh?
"Positive climb" means "yes, we're climbing." "Negative climb" could either mean "we're descending" or it could mean "No, we're not climbing."
In all reality, it would probably be...
...followed, unfortunately, but a loud noise and then silence.
-Doc Lightning-
-Carl Sagan
Mastropiero
Fri May 08, 2009 11:02 pm
Quoting Phoenix9 (Reply 25):
Lol.... This just made my night....  laughing
Markhkg
Sun May 10, 2009 5:35 am
The "third pilot" might be shouting,
"WHOOP WHOOP PULL UP"
or
"DON'T SINK"
 Smile
brons2
Sun May 10, 2009 9:01 am
Quoting Tb727 (Reply 24):
how about yee haw!!
Firings, if well done, are good for employee morale.
DingDong
Sun May 10, 2009 11:49 am
Quoting Markhkg (Reply 31):
or
"DON'T SINK"
 Smile
There's a secret annunciation mode... if a positive rate of climb is not established, it will call out 'RETARD RETARD', and in this particular situation, it's not talking about the throttles, either. Big grin
OK, I'm just kidding. Yeah, if that situation (not climbing past rotation) happened, it would be some pretty intense and quick troubleshooting on the spot, for obvious reasons.
DingDong, honey, please answer the doorbell!
Max777geek
Mon May 11, 2009 2:15 pm
their last two words, probably. The first is "Holy".
SEPilot
Mon May 11, 2009 3:38 pm
There is a novel, "Left Seat", by Robert Serling that told a story about how this requirement came about. I don't know if it is true or not, but it does sound authentic. It seems that the DC-7 was notoriously lethargic when trying to do a go-around, and one once tried it and clipped the prop tips before finally getting enough airspeed to climb. The CAB investigating this incident decided to add the requirement to verify positive rate of climb before raising the gear.
borism
Thu May 21, 2009 8:37 pm
Quoting DocLightning (Reply 29):
What if aircraft does lift off the ground but rate of climb 0 is maintained afterwards? Granted there are no terrain, plant or artificial obstacles in the flight path, there's no reason it should crash (well, besides birds). It will continue to fly on ground effect and gain speed and gear retraction is fully justified. It isn't standard operating procedure, but it is totally considerable scenario.
SEPilot brings great piece of history into this discussion, in that positive rate of climb is important to the slow-climbing low wing prop aircraft that might clip props to the ground after gear retraction if it's not established.
Mastropiero
Thu May 21, 2009 9:55 pm
Quoting Borism (Reply 36):
Something like this, perhaps?
tb727
Fri May 22, 2009 12:47 am
Quoting Mastropiero (Reply 37):
I've seen better  Wink
calpilot
Fri May 22, 2009 9:25 pm
Richm, don't know if you still are looking for the answer after 38 replies of BS, but
The callout is;
"don't sink"
draigonair
Fri May 22, 2009 10:21 pm
KLM SOP's: PNF: postive rate of climb PF: gear up.
Offcourse with a sink you dont raise the gear! If after take off you do get a sink (maybe windshear) i would suggest max thrust!
cheers!
Nick
cheers
metroliner
Sun May 24, 2009 6:37 pm
Quoting DRAIGONAIR (Reply 40):
I've never heard or used 'positive rate / climb, gear up'. It's always been 'Positive rate of climb, gear up'...
Brevity is wit!  Smile
Set the controls for the heart of the Sun
cptspeaking
Mon May 25, 2009 4:51 am
Nothing. You wait until there is a positive rate of climb!  Smile Otherwise: aviate, navigate, communicate!
...and don't call me Shirley!!
flaps30
Mon May 25, 2009 5:51 am
a few Hail Mary's
SEPilot
Mon May 25, 2009 2:55 pm
Quoting Flaps30 (Reply 43):
a few Hail Mary's
Another book I read some time ago by an airline pilot said that the most frequent last words on cockpit voice recorders is "Oh, sh*t!" This might be an appropriate place for that.
YYZYYT
Mon May 25, 2009 5:53 pm
I am assuming that the thread was prompted by the recent BA / JNB incident...
I just skimmed that thread again, and can see no mention of whether the pilots put the gear up while they flew level and accelerated. Does anyone recall?
