FlyingDove
Etops Label In Landing Gear Area?
Thu Jun 04, 2009 2:48 am
Good day everyone,
I was wondering why many planes have the ETOPS label on the area near their landing gear. Who is supposed to use this information, and how?
Thanks for any information!
[Edited 2009-06-03 19:49:09]
OffshoreAir
RE: Etops Label In Landing Gear Area?
Thu Jun 04, 2009 9:47 am
I've seen it on a number of Delta birds. I've always deemed it as more of a badge of courage. Like Delta showing the public they have aircraft that are rated to the strict standards that ETOPS required.
OffshoreAir
Tristarsteve
Thu Jun 04, 2009 10:50 am
We have B763 that are ETOPS, and some that are not. It is a reminder that I am going to work on an ETOPS aircraft, where the procedures are different.
Transpac787
Thu Jun 04, 2009 11:37 am
United uses the ETOPS labels also.
On the 757 fleet, I think only 13 of their 97 birds are ETOPS rated, and they carry the label near the nose gear doors.
The current 767-300 fleet is 100% ETOPS rated, 35 of 35 birds. However, just a few years ago when UA still had the 767-200's, only a few of those were ETOPS rated as they were all the 767-200A models - the rest were domestic only. So, it was important to differentiate between those with and without ETOPS, at the time.
The 777 fleet is also 100% ETOPS, both 772A and 772ER. So I'm not sure why they label all these planes with ETOPS. Maybe just to keep a common practice, I would assume.
dispatchguy
Thu Jun 04, 2009 2:31 pm
Quoting OffshoreAir (Reply 1):
One reason for the ETOPS label is to, like another poster stated, is to remind all who will work on her (like MX) that the aircraft is an ETOPS aircraft, and that specific policies and restrictions apply.
For example, if the same mech services both engine oils, the aircraft is removed from ETOPS operatons. So if an ETOPS bird is in your station and the crew writes up the engine oils and that they need a service, and the same mech does both - the aircraft can NOT depart on an ETOPS operation until 2 mechs verify that the engine oils were done correctly. The UNQ mechanic will sign it off as engine oils serviced to clear the logbook item, but the aircraft can not operate a subsequent ETOPS operation.
Usually, this doesnt cause a problem. I see notices that ship XXX has been removed from ETOPS operations daily. If its operating a domestic operation, its not that big of a deal. However, before any ETOPS departure, an ETOPS predeparture check is performed, by 2 or more ETOPS qual mechanics, and the ETOPS PDC will clear any of those ETOPS UNQ MECH items, and return the aircraft to ETOPS status.
If an ETOPS aircraft, while operating an ETOPS operation, diverts somewhere, and the reason was a mechanical reason, an ETOPS PDC will need to be performed so that the aircraft can continue ETOPS. However, if a set of ETOPS Mechs arent available where the aircraft diverted, and the decision is made to continue, it must operate under non-ETOPS (the old 60 minute rule), until a full ETOPS PDC can be accomplished. However, if the aircraft diverted for a non-mech reason, say an unruly passenger, or a medical, and there are no mechnical issues, the aircraft may continue ETOPS.
It's not a badge of courage, for my guess is that less than 1% of the pax in any gate house even knows what it means - its a reminder that special rules apply to working on this aircraft.
Nobody screws you better than an airline job!
OffshoreAir
Thu Jun 04, 2009 2:43 pm
Quoting Dispatchguy (Reply 4):
Thanks for the clarification. I always knew what it meant, but you are right, most passengers have no idea what ETOPS means.
OffshoreAir
d-aiqc
Tue Jun 09, 2009 6:22 pm
Is there a source where I can see all relevant ETOPS requriements?
thx
d-aiqc
airbuske
Tue Jun 09, 2009 9:02 pm
Quoting D-aiqc (Reply 6):
Go to the following webpage and download the "Getting to grips with ETOPS" document.
http://www.smartcockpit.com/flightops
It gives a fair amount of insight on what the program is about, why it is there and what the airframe manufacturer and operator must do in order to get/keep ETOPS.
DescendVia
Wed Jun 10, 2009 1:22 am
Quoting Transpac787 (Reply 3):
All ETOPS planes (757, 767, and 777) have the ETOPS stickers on the sides right above the nose numbers. Nothing is on the gear doors itself other then the red lines to make were the doors are at. They old do have 767-322 or 747-444 across the front of the nose gear doors but that is about it.
I personally have only seen CO planes have the ETOPS stickers on the gear doors.
One thing that is note worthy is that the 777-200A is only rated to 180 while the -200B can go up to 207 when on the PACOTS.
[Edited 2009-06-09 18:28:14]
fr8mech
Wed Jun 10, 2009 1:30 am
Quoting DescendVia (Reply 8):
Ah, absolutes in aviation...never use them.
Our B767 aircraft do not have ETOPS stenciled anywhere on the airframe. I imagine that carriers that have a mixed fleet (i.e. non-ETOPS B767 & ETOPS B767) use the stencil to clearly identify an ETOPS aircraft to its maintenance (and other interested) folks. And then again, the carrier may want to stencil it on the nose regardless of the status of its fleet.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
DescendVia
Wed Jun 10, 2009 1:44 am
Quoting Fr8Mech (Reply 9):
That was a reference to United.........
They old do have
Should read: "They all have"
[Edited 2009-06-09 19:12:19]
FlyingColours
Thu Jun 11, 2009 4:29 pm
Having ETOPS on the nose gear doors also helps us cabin crew out as some specific aircraft that are ETOPS certified have additional equipment in the cabin which we need to check. This was the case at Air 2000 on the 757 fleet, I personally prefered working on those aircraft, especially when on longer over water sectors.
My last airline, XL had ETOPS labels on the nosegear doors on some 737-800s, which at first I thought was odd but apparently those were indeed certified providing they were carrying the additional life rafts in the cabin (Which only happened once on my flight), so they were not technically ETOPS on those occasions.
All of the 767s though (G-BOPB 762 & G-VKNG/NI 763) were Etops 180.
Wow I never knew that, I'm glad to be back online again and learning new things on the tech/ops board  Smile
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
Tristarsteve
Thu Jun 11, 2009 7:14 pm
Quoting FlyingColours (Reply 11):
Note that is for his airline. It is not universal.
We have an unlicensed mech to service both engines, then I check the caps are secure. This solves the ETOPS requirement, with only one licensed engineer on duty (which is not unusual on a small line station.)
In fact we were unable to bid for the Continental contract here, because they required two licensed engineers, but would not pay for it!
Users browsing this forum: No registered users and 39 guests
