Quoting LHR27C (Thread starter): I'm doing some research into engine lifes and wondered if anyone could help me with the following question: how long, on average, do engines physically last before they're scrapped? |
Quoting MarkC (Reply 2): An engine really does not have a life. |
Quoting EcuadorianMD11 (Reply 5): Is there a specific jet engine that is considerably more durable than the others? |
Quoting EcuadorianMD11 (Reply 5): I mean GE compared to RR for instance, on modern jet liners? |
Quoting Tdscanuck (Reply 1): There's essentially no limit. It's an economic problem, not a physical one, since very part is replaceable. I've heard tell of JT-8 engines where the only original part is the data plate. |
Quoting Pellegrine (Reply 7): What about the shafts? After how long do they get replaced? |
Quoting GrandTheftAero (Reply 9): A good example is the CFM56 family of engines. Designed for short/medium haul routes, longer time-on-wing and higher durability are usually more desirable than cruise performance in these engines. |
Quoting Planemaker (Reply 10): The previous record of 19,841 cycles was held by a CFM56-3 engine in service with Southwest Airlines. |
Quoting Boeing767mech (Reply 11): American Airlines has set a time on wing record for a GE CF6-80C2 engine - logging more than 40,000 flight hours and nearly 10 years of continuous on-wing operation on a Boeing 767 aircraft. |
Quoting GrandTheftAero (Reply 12): In a CF6, the process of going from ground idle to full power back to ground idle may only occur once a day, but these engines spend most of their operating time at cruise. Here it makes more sense to keep track of hours. |
Quoting Tdscanuck (Reply 12): Both engines track hours and cycles all the time |
