Quoting Chrisrad (Thread starter): Could someone please provide the climb out rates for B763, 77W, 744, vs. A330, 345/346, A380. |
Quoting Chrisrad (Thread starter): Just trying to prove a point that not all airbus aircraft climb slowly versus their Being counterparts. |
Quoting Chrisrad (Thread starter): At what weight, with which engine, and at what thrust? It's an extremely variable question. |
Quoting ArniePie (Reply 2): However on a related note I seem to remember that Boeing aircraft are usually certified to fly at higher altitudes than their Airbus counterparts. |
Quoting Chrisrad (Reply 3): I just have someone carrying on that the A345/6 climbs worse than equivalent Boeing counterparts. |
Quoting Chrisrad (Reply 7): , but this idiot just wrote on one of my Youtube videos |
Quoting Chrisrad (Reply 7): Sorry to be so vauge, but this idiot just wrote on one of my Youtube videos, that all Airbus aircraft have pathetic climb rate compared to Boeing. I just want some comparisons like the A346 will climb faster to X alltitude than B744 etc |
Quoting Mir (Reply 12): But consider this: should either of them lose an engine, the situation will be reversed, and the 346 will be outclimbing the 77W. |
Quoting DH106 (Reply 13): Is that actually the case - wouldn't they both be at around the same min. acceptable performance level with each having an engine out? |
Quoting Vikkyvik (Reply 14): I don't think so. Far as I remember (and from what I found), the minimum engine-out climb gradients are steeper for a 3-engine, and even steeper for a 4-engine aircraft |
Quoting R12055p (Reply 9): I think your best bet is to look at thrust to weight ratio. |
Quoting ArniePie (Reply 2): -A380 up until FL430 vs 747 at FL450 |
Quoting Tdscanuck (Reply 1): Airbus and Boeing have to design to the same regulations with respect to minimum climb gradient. The 744 climbs just as badly as the A340, when loaded for an equivalent mission. |
Quoting Astuteman (Reply 17): A 1 235 000 lb A380 with 4 x 70 000lb engines has a thrust/weight ratio of 0.227 A 875 000lb 744 with 4 x 60 000lb engines has a thrust/weight ratio of 0.274 - nearly 21% more thust per lb weight than the A380. |
Quoting DocLightning (Reply 20): Hopefully, they fixed that on the new 748 wing. |
Quoting ArniePie (Reply 2): However on a related note I seem to remember that Boeing aircraft are usually certified to fly at higher altitudes than their Airbus counterparts. -A319-21 up until FL393 vs 737 up until FL410. -A330/340 up until FL410 vs 767/777 at FL430 -A380 up until FL430 vs 747 at FL450 |
Quoting Pygmalion (Reply 23): Service ceiling is a technical definition set by regulation. So the criteria are the same for both Airbus and Boeing. It is not a marketing thing. |
Quoting Starlionblue (Reply 24): Quite. As I understand it service ceiling is the lowest of the following two: - A height at which the aircraft is unable to climb faster than a certain value. |
Quoting link][/quote]
[quote=Kimberlyrj (Reply 22): Having worked on the Boeing 747, Boeing 767 & Boeing 777 for more years then I care to think about and I have never gone above FL410 on any of them, so maybe Airbus is more realistic on their service ceilings? KimberlyRJ |
Quote: The cockpit voice recording, released by the National Transportation Safety Board at the start of a three-day hearing into the Oct. 14, 2004 accident, revealed how the pilots cracked jokes and decided to "have a little fun" and fly to 41,000 feet _ the maximum altitude for their plane. Most commuter jets fly at lower altitudes. "Man, we can do it, 41-it," said Cesarz at 9:48 p.m. A minute later, Rhodes said, "40 thousand, baby." Two minutes later, "There's 41-0, my man," Cesarz said. "Made it, man." At 9:52 p.m., one of the pilots popped a can of Pepsi and they joked about drinking beer. A minute later, Cesarz said, "This is the greatest thing, no way." But at 10:03 p.m., the pilots reported their engine had failed. Five minutes later, they said both engines had failed and they wanted a direct route to any airport. The transcript recounts their increasingly desperate efforts to restart the engines and regain altitude. They tried to land at the Jefferson City, Mo., airport but by 10:14 p.m., it was obvious they wouldn't reach it. "We're not going to make it, man. We're not going to make it," Cesarz said. The plane crashed in a residential neighborhood of Jefferson City. No one was injured on the ground. |
Quoting ArniePie (Reply 26): "Man, we can do it, 41-it," said Cesarz at 9:48 p.m. A minute later, Rhodes said, "40 thousand, baby." Two minutes later, "There's 41-0, my man," Cesarz said. "Made it, man." |
Quoting EcuadorianMD11 (Reply 27): That´s a shocker......the pilots didn´t do anything wrong really since they stayed in the plane´s envelope..........but still, a heavy prize to pay for an experiment. Some kind of "mythbusters" for real. |
Quoting EcuadorianMD11 (Reply 27): I wonder about ATC, didn´t they object or raise questions? |
Quoting Vikkyvik (Reply 28): Yes they did many things wrong - they got up to altitude, but they got up there dangerously low on energy. By the time they got up there, they were already at a low speed and high angle-of-attack (basically, they were in unsustainable flight - something had to give). They ignored the stick shaker (twice, if memory serves) and tried to stay at altitude. |
Quoting Vikkyvik (Reply 28): But what exactly was she supposed to do? The pilot is responsible for the flight. |
Quoting Francoflier (Reply 6): A340-300: 7.9 A330-300: 15.4 B777 (worst of -200, -300 & -300ER): 13.2 B747-200F: 7.7 B747-400: 9.4 |
Quoting EcuadorianMD11 (Reply 29): What I was getting at was whether they had permission to do so or did they just go on a jolly as they pleased.......... By no means did I put responsibility on her.......... |
Quoting Starlionblue (Reply 11): I would remind you not to argue with an idiot. He will drag you down to his level and beat you with experience. |
Quoting Starlionblue (Reply 34): I would really like to take credit but I stole it from someone a long time ago. |
Quoting Starlionblue (Reply 34): Tact Is For People Who Aren't Witty Enough To Be Sarcastic |
