Quoting Goldenshield (Reply 2): Turboprops also have an auto-feather system, and that needs to be tested, among other things, and that may be what you are thinking of as the "warmup." When they test them, the RPMs drop, and then rise again, they will sound akin to testing of the magnetos on a 4-stroke airplane engine, but it is not the engine; rather, it is the props taking a bigger bite of air, and dropping in RPM. |
Quoting Max Q (Reply 1): Well, they do, most jet engines need a few minutes to stabilise and for the oil temperature to be 'in the green' |
Quoting DashTrash (Reply 5): In the Dash you had to let the oil temp rise to a certain temp (don't remember the value) before you could take the props out of feather. It might take a minute or two to get there if it's real cold, but turbines make a lot of heat fast. |
Quoting TheGreatChecko (Reply 7): Okay, so I forgot about the days when the temperature is at 40 below. Those days are no fun. cold |
Quoting TheGreatChecko (Reply 7): Okay, so I forgot about the days when the temperature is at 40 below. |
Quoting Flighty (Reply 10): How about extreme cold? Airline ops never seem to cancel due to subzero temps in Moscow or Fargo. Is any warmup time required there, or can turbines just shake it off relatively fast, on the way to the runway? |
Quoting William (Thread starter): We all know the first flight out on a turboprop they go out onto the apron and do the obligatory 5-10 minute warmup. SInce a turboprop is a jet geared down why do jets (737,A320 et al) not have to warmup first flight out ? |
Quoting CanadianNorth (Reply 12): As far as I know every aircraft has a minimum temperature which it can operate it. Some airplanes (I've been told on the CRJ for example) it's around -40, |
Quoting DocLightning (Reply 17): But the temperature at cruise can be far colder than that... |
Quoting Goldenshield (Reply 18): Yes, it can; however, the crew cannot take the plane to temperatures colder than allowed by the manufacturer, which generally means a lower cruising altitude |
Quoting 747classic (Reply 19): Boys, this thread, we are still on the ground ( and starting our engines). |
Quoting 747classic (Reply 19): And if you have to start immediately your engines at cruising altitude, you don't mind the extra engine wear. |
Quoting DashTrash (Reply 5): In the Dash you had to let the oil temp rise to a certain temp [quote=747classic,reply=19] Boys, this thread, we are still on the ground ( and starting our engines). At cruising altitude there is no temperature limitation for the engine start, so far I know. And if you have to start immediately your engines at cruising altitude, you don't mind the extra engine wear. The only altitude limitation for engine operation is the fuel temperature. |
Quoting T prop (Reply 24): On a turboprop like Dash 8 there is a specific warning about shutting an engine down in flight for longer than 10 minutes (pilot training) and then restarting when ambient is lower than -40c. |
Quoting Viscount724 (Reply 23): Two years ago, in January 2008, AC had to cancel all their flights to/from Yellowknife (YZF) , capital of Canada's Northwest Territories, for several days when temperatures dropped below -40C which is apparently the lowest ground temperature the CRJ used on those routes is certified for. I think it's related to the lowest oil temperature for engine starts. |
Quoting Malmi18 (Reply 27): Why? Makes passengers scared that something may not be alright or what? I'd be more scared if I suspected that the plane has NOT been checked. |
Quoting DocLightning (Reply 26): So cars have this issue, too. This is why in places like Minnesota and Alaska, cars often come equipped with engine block warmers to keep the oil and coolant from freezing. Why couldn't this be included as an option for aircraft that are expected to cold soak? |
Quoting Rwessel (Reply 29): Probably because even in places like Yellowknife, -40C (or -40F, for that matter) days are pretty rare. And it's probably just a matter of demand not being high enough to certify to lower temps (or to make the required mods). Also, it's not just the engines that are an issue. |
Quoting William (Reply 30): Thanks for the replies folks. So please explain in laymen terms just what is being accomplished when on the first flight out one goes to the farthest part of the tarmac and runup begins? How does running up the props test the autofeathering? |
Quoting Northwest727 (Reply 33): I am also making a guess, that because the propellers on turboprops (or most other constant speed props, including piston powered aircraft) need oil-usually engine oil, to change the pitch of the blades, its a good idea to use warm oil which is better flowing, but also helps extend the life of the seals inside the hub assembly. |
