propilot83
Wing Flexation
Mon Sep 28, 2009 7:39 am
I've noticed that on the Boeing 747-400 during take-off the wing of the 747 seems to flex upward towards the outer wingtip area. I know that wings and other parts of an airplane are designed to "flex" up and down due to the stress imposed on the plane as it expands and contracts like a balloon. However if you ever notice a 747-400 on the ground, the wings seem to be like an "arch" almost, and then when it becomes airborne, it tends to bend and flex like a "u" shape. I believed that this occurs because of stress as the plane becomes airborne, or is this also because fuel inside the wings move around and causes the wings to flex upwards towards the outer wingtip area? This wing bending is very noticeable on larger aircraft like the 747 and MD-11, I've seen it on the 737 also.
FlyDeltaJets
RE: Wing Flexation
Mon Sep 28, 2009 8:18 am
That flex is caused by the lift generated by the wings. The air is literally picking the plane up by the wings. The fuel in the wings somewhat attempt to prevent the wing from flexing too much. Most wings will flex some more than others.
The only valid opinions are those based in facts
RE: Wing Flexation
Mon Sep 28, 2009 9:15 am
On a 747 or 380, the wings droop noticeable while on the ground if they are full of fuel. As the wings start producing lift on the take-off roll, they bend up into the "flight" position. The wings are lifting themselves first if you will. The reason for the U shape is that the fuse is sitting in the middle.
You can model it with a long steel ruler. Get two bricks and suspend the ruler between the bricks with only the ends supported. Then get a weight and put in on top of the middle of the ruler. The bricks represent lift and the weight is your fuselage. (The ruler, obviously, is the wing). The ruler will bend into a U shape,
Quads tend to have more wing flex since the outer engines allow a weaker wing by counter-acting flex.
AirframeAS
RE: Wing Flexation
Mon Sep 28, 2009 7:57 pm
The 777's have a really nice wing flex that is very much noticeable.... and it looks sexy, too!!!
ATA L1011
RE: Wing Flexation
Wed Sep 30, 2009 5:40 pm
747-400's, 767's,777's, A330 and 340's all have nice wing flex on takeoff and at cruise. The MD-11 does not have nearly as much flex as the above as its wing is sorta designed downwards as you get toward the wingtips, the rest are angled upwards toward you get toward the tips.
Treat others as you expect to be treated!
CosmicCruiser
RE: Wing Flexation
Wed Sep 30, 2009 6:26 pm
Checkout any old pics of a B-52
411A
RE: Wing Flexation
Thu Oct 01, 2009 1:56 am
Maximum designed wing flex (at the tip) for the B707....12 feet UP, 11 feet DOWN....prior to wing skin deformation, while airbourne.
ArmitageShanks
RE: Wing Flexation
Thu Oct 01, 2009 2:01 am
Quoting ATA L1011 (Reply 4):
I always thought it had more.
ATA L1011
RE: Wing Flexation
Thu Oct 01, 2009 2:04 am
Quoting ArmitageShanks (Reply 7):
Go look at photo's of the for mentioned vs the MD-11 on takeoff and at cruise and you will clearly see that its wings do not flex nearly as much.
RE: Wing Flexation
Thu Oct 01, 2009 7:49 am
Quoting 411A (Reply 6):
Wobble. Big grin I'm sure Boeing learned a lot from the B-47 and B-52 wings.
AirframeAS
RE: Wing Flexation
Thu Oct 01, 2009 9:23 am
Don't forget the 737NG's have beautiful wingflex, too!
411A
RE: Wing Flexation
Thu Oct 01, 2009 12:27 pm
They may well have, however....early aircraft suffered terribly from wing skin cracking, and many required extensive re-skining, to remain in extended revenue service.
Fuselage crown skin cracking was a very big issue, as well.
2H4
RE: Wing Flexation
Thu Oct 01, 2009 4:50 pm
At one point, they were planning on using the very same configuration on the 707:
Big version: Width: 800 Height: 600 File size: 276kb
2H4
[Edited 2009-10-01 09:53:31]
Intentionally Left Blank
ATA L1011
RE: Wing Flexation
Thu Oct 01, 2009 8:18 pm
Quoting AirframeAS (Reply 10):
They do, but I was just referring to the big guys! For a smaller guy it's definately at the top of that league for flex!
MD11Engineer
RE: Wing Flexation
Thu Oct 01, 2009 9:01 pm
A 737 wing is very "springy". If you walk on it towards the tip, you´ll feel it moving beneath you.
The biggest wing flex I have seen on older Tupolev aircraft. On ground the wings have a pronounced anhedral, while once airborne, the wings flex up into a dihedral configuration.
Jan
