Quoting Kimon (Reply 3): Sounds like a good idea! Why are not not all aircraft equiped with it? |
Quoting Tdscanuck (Reply 4): You can get rollout guidance from a localizer display, the PFD, the HUD, |
Quoting TristarSteve (Reply 8): I believe the main reason for the PVD on the Trident was low visibility take offs. It was much more sensitive than a localiser display, and being on the glareshield you could see it while looking fwd. |
Quoting Fabo (Reply 20): What the hell are you trolling about here, now via PMs too? |
Quoting TristarSteve (Reply 2): It was introduced on the Hs Trident for BEA for Cat3B autolands and lo viz takeoffs. |
Quoting kimon (Reply 18): Since all BA aircraft are equipped with PVD,the RVR minimum is 75 meters as opposed to others (non-PVD) which is 125 metres. |
Quoting kimon (Reply 22): If it were so useless,why did the above-mentioned bother having it? |
Quoting kimon (Reply 22): The four airlines which are PVD equipped are:BA,LH,SQ and QF. |
Quoting kimon (Reply 24): Just one burning question:which aircraft have HUD which would finally supplant PVD once and for all? |
Quoting kimon (Reply 24): Excellent research! |
Quoting tdscanuck (Reply 25): I have no idea about HUD on Airbii. |
Quoting tdscanuck (Reply 25): HUD doesn't necessarily supplant PVD...it all depends on what functions are implemented on the HUD. |
Quoting kimon (Reply 28): Are you with VT or BA? |
Quoting kimon (Reply 31): All BA 744 and 773 are PVD equipped. |
Quoting kimon (Reply 35): Have you actually used PVD? |
Quoting kimon (Reply 35): Just one point:my BA 773 captain confirims that PVD is on both sides on BA 773. |
Quoting kimon (Reply 37): Excellent!Wow most impressed with your customised PVD! This is what they should have updated it to include a vertical indicator! |
Quoting kimon (Reply 37): BA are the greatest fans of PVD as well as being the first to ever have them. Have you noticed that there are absolutely no photos of BA 744 FDs nor 773? I get a feeling that BA are strict with tresspassers! Did Concorde have PVD as well as on AF? |
Quoting kimon (Reply 40): Sorry,I could not find any BA 773 FD photos. |
Quoting kimon (Reply 43): This is simply because of their slavish grovelling to RR and will only want RR-power out of nationalistic pride over technological advancement. |
Quoting kimon (Reply 43): No self-respecting fleet can be without 773! |
Quoting kimon (Reply 43): Ok,does the 772LR have GMCS? |
Quoting kimon (Reply 45): I think one day BA will disappear as the vultures are already circling. |
Quoting kimon (Reply 45): It is a pity that the UK killed off all their aviation manufacturing. |
Quoting kimon (Reply 45): You can sense that AF reflects France more than BA does for UK. |
Quoting tdscanuck (Reply 46): I don't think so...why would it need it? It's not that long. |
