Quoting Mastropiero (Thread starter): How are you more comfortable, in a nose down attitude having a good visual of the runway up until flare, or in a nose up attitude? |
Quoting FLY2HMO (Reply 2): But in your everyday airliner or single engine plane, nose high for me. |
Quoting Goldenshield (Reply 5): and if you can't see the runway when you are flaring, |
Quoting Goldenshield (Reply 5): if you can't see the runway when you are flaring, and either you or the aircraft aren't cat III certified, you shouldn't be flying that plane in the first place. |
Quoting 2H4 (Reply 7): I suspect the tailwheel community would take issue with that. |
Quoting Goldenshield (Reply 5): Also, in the west, only the MU-2 (that I can think of) intentionally lands nose first. |
Quoting Mir (Reply 10): Quoting 2H4 (Reply 7): I suspect the tailwheel community would take issue with that. Hell, I've been in that position in a 172 (albeit briefly). One of my smoother landings, I have to admit. -Mir |
Quoting Goldenshield (Reply 12): Let me rephrase that: When you are about to flare, i.e.; you can't see what's ahead of you while still in approach attitude. |
Quoting tb727 (Reply 13): I have heard in the 747 you can't see much of the runway in the flare, |
Quoting Mir (Reply 3): How many single-engine planes fly nose-high on approach, though? |
Quoting Goldenshield (Reply 5): and if you can't see the runway when you are flaring, and either you or the aircraft aren't cat III certified, you shouldn't be flying that plane in the first place. |
Quoting FLY2HMO (Reply 15): I wanna say the older C182RGs tended to have a flat-ish approach, more so than a 172 at least |
Quoting 2H4 (Reply 18): As I recall, some of the older 182s had a flap setting of 40 degrees, which further flattened the deck angle on approach. When flying with an empty cabin, the resulting nose-heavy configuration has combined with unsuspecting pilots to claim many nose gears and firewalls over the years. |
Quoting FLY2HMO (Reply 19): So you either had to land faster, resulting in a long float, or, my preferred method, which was to bump the power right as you flare. |
Quoting Musang (Reply 17): |
Quoting FLY2HMO (Reply 22): Quoting 2H4 (Reply 20): My preferred method was to use 30 degrees of flaps. Pfssh! Where's the skill in that? |
Quoting Goldenshield (Reply 23): How about 90 degrees? |
Quoting Lowrider (Reply 24): What are you looking at, a Helio Courier? A Hawker? What ever it is it sounds very interesting. |
Quoting ThirtyEcho (Reply 26): |
Quoting ThirtyEcho (Reply 26): As for the nose heaviness, drop by and I'll show you where to find the trim wheel. |
Quoting ThirtyEcho (Reply 26): ALL Cessna singles used to have 40 degree flaps and they were wonderful in backwoods or short strips, especially if they were manual. As for the nose heaviness, drop by and I'll show you where to find the trim wheel. |
Quoting 2H4 (Reply 29): Landing is the most accident-prone phase of flight for Cessna 182s and comparison aircraft, with 39 percent and 29 percent, respectively. For the 182, landing hard was the leading transgression. |
Quoting FLY2HMO (Reply 30): I wonder if the new (2000 and later) 182s have better elevator authority? Haven't flown those newer models... |
Quoting Goldenshield (Reply 25): HP-18. No engine, but sporty as hell. |
Quoting bri2k1 (Reply 27): Something about lots of flutter during a cross-controlled approach. Apparently, the flaps blocked so much airflow to the horizontal stab that it kept going in and out of stall. |
Quoting rcair1 (Reply 34): Poll - have you ever slipped your plane to loose altitude? |
