It would be really appreciated if some folks here could help me with the few remaining (so far) questions I can't get clarity on.
1. Autoland Usage
- I've read that most pilots will flip off the autopilot as an autoland does not count as a landing in the logbook?
If so, how far before the threshold would one typically kill the autopilot? OM? MM?
If not so, what goes into the decision to use autoland or not?
2. SIDS/STARS
When do you learn what SID/STAR is in effect along with the active runway?
For a SID, I would imagine it's initially in the plan, and then confirmed by ground or clearance?
For the STAR - do you avoid putting it in the FMC until you hear from ATC the approach clearance or is the STAR determined long before that and usually correct.
The first point on the transition - is it always in the flight plan, or do you have to fly direct off your flight plan to the transition?
3. Shutting down the aircraft:
- Is it *parking brake * seat belt sign * fuel cutoff * beacon
- How do you know if you're getting external power or you'll need the APU (I can guess it's probably obvious... but)
- For short turn, do you leave the IRS switches in NAV mode?
4. 250 kts below 10,000ft
- Do you typically plan 240kits in case wind shift throw you over 250? Is it a big deal if you hit 251 or 252 for a brief second or two?
- For aircraft that need more than 250 below 10,000ft, it it understood by ATC by the aircraft type, or does someone need to be notifed?
5. Reading Material
Are there any books out there that really walk someone through all the steps a real pilot takes from the time they pick up their paperwork to the time they turn it back in? I'd love to see a book that explains all the little things like nav/beacon/landing/taxi light procedures, taxi restrictions, and smiling for the passengers.
Appreciate any little bit of information to help me simulate real operations on my PC flight sim. It's as close as I'll ever get to flying a real plane, but I want to do it as real as possible.
Thanks so much.
Bob
KMEM
