747400sp
Will The 787 And A350 Make The A380 Look Out Dated
Tue Feb 23, 2010 4:48 am
With all the new features in the 787 and A350XWB, like lower cabin pressure and large cabin windows, will the A380 look out dated, compaired to the 787 and A350XWB ?
tdscanuck
RE: Will The 787 And A350 Make The A380 Look Out Dated
Tue Feb 23, 2010 5:05 am
Quoting 747400sp (Thread starter):
I doubt it...all the OEMs keep refreshing their interiors. A 737NG or new E-jet has about the same "architectural era" inside as a 787 or A350XWB mockup. The windows, obviously, will be different (and nice) but I don't think it will make the interiors look dated.
Tom
N49WA
Tue Feb 23, 2010 5:28 am
I agree with tdscanuck as far as the interior goes. As for the exterior...IN MY HUMBLE OPINION (yelled to hopefully prevent a flame fest) the airplane itself already does. Reminds me of the Bristol Brabazon - fat, no streamlining (although the Brabazon had a cool looking nose). It IS a technological acheivment, no doubt, but hardly modern and sleek aesthetically like the 787 and A350 are. Again folks, IMHO.
AutothrustBlue
Tue Feb 23, 2010 6:43 am
The A380's avionics are going to be used as the platform for the A350, only change is in the number of displays. Thus not much difference in that respect. On the other hand, the 787 and A350 have a more futuristic look to them (sharper nose, sleeker cockpit windows) versus aircraft that roam the skies today (A330, 777, etc)
Personally, the 787 makes the 1980s era 767 and A310 seem more outdated when considering all aspects of each aircraft. Same goes for the A330, albeit to a much lesser extent.
Rj111
Tue Feb 23, 2010 10:05 am
The actual pressure difference between 6000ft and 8000ft is only about 8% and most flights are less than 8000ft anyway.
So that'll be sublte. The windows will be nice but subtle as well. You will however likely be 9 across in Y.
If we're discussing looks. Well i think both the A380 and 787 look rubbish. The A380 too stubby, and the 787 - well i hate the droop nose and it looks too meek. Stretches should benefit both. I think i'm getting old.
tdscanuck
Wed Feb 24, 2010 1:00 am
Quoting RJ111 (Reply 4):
The whole reason they picked that particular cabin altitude was a bunch of studies that show a fairly sharp break point in the number of people experiencing adverse symptoms at an altitude between 6000 and 8000'. So, although the magnitude of the pressure different isn't that large, the response isn't linear so you get more than 8% improvement in passenger perceived comfort.
Tom.
astuteman
Thu Feb 25, 2010 9:30 am
Quoting n49wa (Reply 2):
When in fact, appearances notwithstanding, it's actually one of the most "streamlined" shapes out there, from a technical standpoint.
Interestingly, Wiki quotes the A380 cabin pressure as 5 000ft
http://en.wikipedia.org/wiki/Airbus_A380
The A380 produces 50% less cabin noise than currently flying 747 models and has greater cabin air pressure, equivalent to an altitude of 1,520 m (5,000 ft) versus 2,440 m (8,000 ft). Both features are expected to reduce the effects of travel fatigue
Other sources also quote better humidity as well
http://www.businessweek.com/globalbi...tent/oct2007/gb20071015_622639.htm
Other, subtler differences could make flying on the A380 more pleasant than on older planes, though. The A380's engines are noticeably quieter. The cabin pressure will be higher, the air less dry, and the cabin lighting will automatically brighten and dim to mimic changing light outdoors—all of which should make travel less fatiguing. Boeing is promising similar interior improvements on its 787 Dreamliner.
The above reports suggest the A380 falls into the same/similar cabin altitude/humidity category as the 787 and A350.
Maybe it's not as out-of-date as conventional A-net wisdonm would have us believe.......
B777LRF
Mon Mar 08, 2010 10:22 pm
They're all just tubes with low mounted wings where you can hang engines from.
Honestly, there's not much between them apart from the "more electric" architecture of the 787. I'll reserve judgement on the benefits of that until the aircraft has been in airline service for a couple of years. I'll also reserve judgment on the increased humidity level advertised for the 787, whereas the lower cabin altitude will be of undoubted benefit.
max550
Mon Mar 08, 2010 10:51 pm
Quoting AutothrustBlue (Reply 3):
What will the A350 nose look like? I remember the original drawings but I thought Airbus said the nose would look more like the A380. I haven't seen any drawings since then, have they released any?
seabosdca
Tue Mar 09, 2010 1:16 am
It's not so much a matter of outdated or not, it's a matter of ugly or not.
The A388 is just not a pretty airplane IMO. The wings, while beautiful on their own, look too thick and heavy for the rest of the aircraft. The nose is visually horrid, with the big forehead and strangely placed, incongruously shaped cockpit windows. The fuselage is short and stubby. A stretch would help a bit, but not totally fix it.
The 787 and A350, on the other hand, will both have near-perfect proportions. I think the 787 is about as beautiful as airliners get, and the A350 is shaping up that way as well except for its use of the old-looking A380 cockpit section. They have long, slender, elegant wings, aren't too fat, and have graceful empennages and stabilizers. And the 787 has a slicker nose than anything produced to date.
cpd
Tue Mar 09, 2010 1:28 am
Quoting astuteman (Reply 6):
It is very quiet too.
Good for travellers on board it, and great for the people on the ground underneath it. Case in point - I walked outside my house on the weekend, and by chance, noticed the SQ A380 going to Singapore flying overheard, departing Sydney. It was still quite low - but if I didn't look up, I wouldn't have know it was there - because it was near silent.
In comparison, you really know when the BA 747-436 or a QF 747-438 RR goes overhead. Those RR engines scream.
[Edited 2010-03-08 17:29:44]
afterburner
Tue Mar 09, 2010 4:20 am
Quoting seabosdca (Reply 9):
Please, we've had enough negative comments of A380's shape. We don't need people to repeat the similar comments again and again and again.
astuteman
Tue Mar 09, 2010 5:54 am
Beauty is in the eye of the beholder, of course. I don't think the A380 is an ugly plane personally, but there you go.
And of course, ugly and outdated aren't the same thing.
The OP specifically mentions some key product characteristics, which didn't include ugly, of course...
And by which measures the A380 is a) clearly not outdated, and b) quite possibly makes most preceding aircraft look outdated.
But I've long since learned that the A380 will always be considered "old-tech" by those detractors who can't be bothered to actually learn what is underneath the aircraft's skin
Their loss
seabosdca
Tue Mar 09, 2010 7:14 pm
Quoting astuteman (Reply 12):
Quite -- I did not mean to question the technical excellence of the A380, just to express an aesthetic view...
I do wonder how the A388 will compare on CASM to the "holy grail" which I keep holding out hope for, possibly foolishly: the "simple stretch" 787-10. I think if Boeing would just decide to build that plane, it could do to the 5000-6000 nm market exactly what the A333 did to the 4000 nm market.
747400sp
Tue Mar 09, 2010 9:29 pm
You right beauty is in the eye of the beholder, and for some time I thought the A380 not good looking, but their was a photo of an EK A380 at AKL in the sun set, posted on A-net not to long ago. In the photo I realize that the A380 funny shape help it fly so smooth, and that giant tail make it look some what nice.
Quoting cpd (Reply 10):
Ah, I like it like that!  You think the RR on 744 is loud, try the RR 747-200, those NZ 742 flying on the LAX-AKL route non stop, used to be almost as loud as a DC-8 63.
baroque
Wed Mar 10, 2010 5:32 am
Quoting seabosdca (Reply 13):
If it is like the A3510, one might essay, about half way, which is always a difficult place to be???
DocLightning
Wed Mar 10, 2010 7:45 am
I thought you couldn't do that with a metal frame out of corrosion concerns.
baroque
Wed Mar 10, 2010 2:37 pm
Quoting DocLightning (Reply 16):
Well Doc, how much humidity the 787s and 350s actually have is an interesting question. Takes a lot of water to get the near zero RH air up to whatever it is supposed to be at what 22 C. The pax are supposed to supply quite a bit of it, but every time I do the calculations, I fail to see how 300 pax can supply the tonnage!! Although it all depends on how many times you send the water round and round with recirc.
A prize to the first person to take a hygrometer aboard a 787 service to tell us the real RH.
AutothrustBlue
Wed Mar 10, 2010 8:42 pm
Quoting Max550 (Reply 8):
The A350's nose kind of resembles that of the 787 (this is a judgment call since I am having trouble finding pictures to fairly compare), but it is definitely a departure from the traditional nose and cockpit windows Airbus used on their widebodies since the A300. Not sure if the A350 will inherit some manipulated form of the A380's nose
https://www.airliners.net/photo/TAM/Airbus-A330-223/1635574/M/
[Edited 2010-03-10 12:42:58]
GST
Thu Mar 11, 2010 1:46 pm
Quoting Baroque (Reply 17):
Is this expected before or after some kid goes after the dimming windows with magnets? I'm sure the Boeing folks, or whoever was contracted to research them has thought of a way to stop this from damaging anything, because if they haven't it will be rather embarrassing!
tdscanuck
Fri Mar 12, 2010 2:34 am
Quoting GST (Reply 19):
The windows are electrochromic...even if you could flail your magnet around enough to get some voltage to influence the window, it would just go back to normal as soon as the magnet backed off and the window voltage was applied. Other than smashing it with the magnet, I'm not sure how you'd damage it.
Tom.
Users browsing this forum: FARmd90, kalvado and 11 guests
