Page 1 of 1
AA 707 Cabin Windows
Posted: Wed Mar 03, 2010 11:16 pm
by musang
Good Day All.
American ordered their 707-120s and/or 720s with larger than normal passenger windows.
Anyone know how much bigger they were, and whether any other customer went for this option?
Regards - musang
RE: AA 707 Cabin Windows
Posted: Fri Mar 05, 2010 12:26 pm
by N49WA
Hi,
Last week I looked at a piece of wall art made by MotoArt (Google them, great stuff)...it was a Boeing fuselage panel with 4 or 5 windows. The back, or inside surface clearly showed the structure and support pieces. It made me wonder how airlines could order different sized cabin windows since it seems that it would involve a lot of engineering and modification and would probably not be cost effective.
All this being said, I'm curious as to your source. The only window mods I have seen are on a SAHA 707 that has a elongated window in back, probably used when the airplane was a tanker to observe the refueling process.
I am a 707/720 nut-case so I am really curious about your statement. Where did you get your info?
N49WA
Posted: Fri Mar 05, 2010 12:41 pm
by musang
Hi N49WA.
"Boeing 707/720" by Jim Winchester (Airlife's Classic Airliners series, ISBN1-84037-311-3) page 25.
And I see it answers my own question about the size. 10 x 14 inches vs. the usual 9 x 12.5.
There's a photo which shows that the apertures in the over-wing exits are visibly smaller than the rest.
Regards - musang
Posted: Fri Mar 05, 2010 3:54 pm
by longhauler
This is very interesting.
My first inclination was that it was incorrect, until I pulled out the reference you quoted, and looked at the picture you mentioned, and yes you are absolutely correct. It just goes to show you, it is a bad day one doesn't learn something!
On the same note, one thing I have noticed is that American appears to be the only carrier who has put windows in the forward lavs of their B707/720s. Are you aware of any other airline that has opted for this?
Posted: Fri Mar 05, 2010 9:45 pm
by Viscount724
Quoting longhauler (Reply 3):
AA 707s were also among the very few with only 2 turbocompressors (like 720s). Look at photos of AA 707s and you will note that engine #4 has the same narrow pylon as engine #1, while virtually all other 707s built have the same turbocompressor pylon on engines 2/3/4. AA apparently decided that they didn't need the 3rd turbocompressor as they had no overwater routes when the 707s were ordered and in the event of a pressurization problem they would always be iin close proximity to a diversion airport. (The missing turbompressor on engine #4 is only obvious on -123Bs and -323B/Cs with JT3D turbofans. There wasn't any noticeable difference in the pylon shape on the turbojet JT3C-powered -123s before being re-engined, but #4 still lacks a turbocompressor).
[Edited 2010-03-05 13:51:19]
[Edited 2010-03-05 14:39:11]
Posted: Fri Mar 05, 2010 10:01 pm
by Fly2HMO
Quoting Viscount724 (Reply 4):
Not to hijack the thread, but how did they work? Was there a shaft from the engine to the compressor or did they use exhaust gases like you would in a turbocharger?
Posted: Fri Mar 05, 2010 10:53 pm
by Viscount724
Quoting Fly2HMO (Reply 5):
I can't help with the technical explanation. DC-8s also had turbocompressors (4 if memory correct) but they were in the nose and the air intakes on both sides behind the radome. They were removed on the -70 series DC-8s re-engined with CFM56s.
Photo © Bruce Leibowitz
This thread has more explanation (also refers to the 707):
Question On Nose Intakes On Douglas DC-8 (by LTU932 Mar 28 2007 in Tech Ops)
[Edited 2010-03-05 14:54:39]
Posted: Sat Mar 06, 2010 2:22 am
by Viscount724
Quoting Musang (Reply 2):
Be careful with that photo. Note the overwing exit windows lack the approximate 1 inch wide frame around the actual window area in the other windows. If you add that I don't think you would notice any significant difference in the actual glass area.
I also have that book and was very curious about the reference to the larger AA windows as I have never seen that mentioned anywhere else.
If corrrect, the 1-inch wider AA windows would mean that the structural metal gap between adjacent windows would have to be 2 inches narrower on AA 707s than on all other 707s, and when I look at 707 photos closely in p hotos I just can't see that difference which I think would be obvious to the naked eye. And if Boeing offered two different window size options on 707s, why didn't any of the many other carriers choose the larger windows? It would seem like an attractive option to me. Or why didn't Boeing make the larger windows standard to simplify construction and reduce the number of parts? And why didn't later Boeing models such as the 727/737 offer the larger window option, or did they? I can't recall ever seeing any references to AA 727s having larger than standard windows? Wouldn't AA have wanted to avoid two different replacement windows for 707s and 727s?
I hope one of the Boeing experts can confirm one way or the other whether the AA window reference in that book is correct.
Posted: Sat Mar 06, 2010 2:24 am
by 113312
Turbocompressors use a small amount of engine bleed air through a small turbine to spin a compressor on the same shaft for use in cabin airconditioning and pressurization. The next generation of jet transports, the B727 and DC-9 etc. used engine bleed air directly for that purpose. With the first generation of jetliners, the engines had marginal thrust and using bleed air for pressurization would have taken too much power and efficiency. In addition, there was initial concern that bleed air, taken from the engine compressor, might carry contamination from lubrication oil and clean air taken in by the turbocompressor would less likely be contaminated and more easily isolated.
Posted: Sat Mar 06, 2010 4:33 am
by jetmech
Quoting 113312 (Reply 8):
As others have said, the turbo compressor was driven by gases bled off the main engine. It's been a very long time since I've seen a JT3D, but I suspect that the pipe circled in red in the following picture may be the turbo compressor bleed off take.
http://www.380aew.afcent.af.mil/shar...todb/photos/081217-F-2753C-070.jpg
Do you know the exact off take point for the turbo compressor bleed? Is it compressor discharge or combustion chamber discharge?
Quoting Viscount724 (Reply 7):
I'd say the actual frame spacing was the same. I suspect Boeing my have used unique window frame forgings to accommodate the different window sizes. First I’ve heard of it too!
Regards, JetMech
Posted: Sun Mar 07, 2010 2:02 am
by 411A
Quoting jEtMeCh (Reply 9):
Compressor bleed air...9th stage, if I recall correctly.
Keep in mind that many B707's also had direct compressor bleed air for cabin pressurization, as an option, in addition to turbocompressors.
