747400sp
Could An Eight Wheel Jetliner Work?
Sun Mar 21, 2010 2:51 am
I have notest that most narrow body jetliners has only six wheels. Now some of the larger narrow bodies has ten wheels, so now I wonder, could useing an eight wheel landing gear design work? Both Airbus and Boeing has said that the A32X and 737 family would be replaced by wider jetliners. So I am thinking, maybe they could design the a/c's with two nose gear like normal, but have a six wheels main gear. It would be three two wheels bogies across, so could this work?
BMI727
RE: Could An Eight Wheel Jetliner Work?
Sun Mar 21, 2010 2:59 am
Quoting 747400sp (Thread starter):
That would add a lot of weight and complexity since it would mean that the plane would have a third main gear.
Sun Mar 21, 2010 3:01 am
You can ALWAYS add more weight and complexity.
Photo © Christian Waser
FX772LRF
Sun Mar 21, 2010 3:20 am
Could it work? Sure.
Would it be feasible? Most likely not. Or else someone would have probably done it already.
-Noah
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
vikkyvik
Sun Mar 21, 2010 4:42 am
If I had to guess, I'd say it would probably be lighter and simpler to go with the SR-71's main gear config:
Photo © Tony Printezis
Two 3-wheel bogies instead of three 2-wheel bogies.
Quoting FX772LRF (Reply 3):
Though who knows, someone may find a way to do it feasibly....
bohica
Sun Mar 21, 2010 7:12 am
Quoting vikkyvik (Reply 4):
I was thinking of a main gear arrangement similar to the C-17 which is a 2+1 configuration per gear.
Another idea is to have four main landing gears with two wheels each like a B-52. Ground clearance might be a problem though.
BMI727
Sun Mar 21, 2010 7:35 am
Quoting bohica (Reply 5):
Again, that would add weight and complexity with the extra leg.
vikkyvik
Sun Mar 21, 2010 8:15 am
Being a heavy bomber, the B-52 had a whole other set of issues to deal with. You want the bombs as close to the CG as possible, so you don't have a giant weight with a huge moment-arm from the CG. But of course, on a high-wing plane like the B-52, that's typically where the main landing gear goes (a bit aft of CG). So instead, you give it two sets of main gear, and no real nose gear.
That brings in the issue of rotation on takeoff. The aft gears are too far back for the B-52 to rotate around them. I haven't seen it myself, but I've heard that the -52 actually lifts up the rear gear first, and has a nose-down initial climbout angle. You can see it here:
Photo © Keith Blincow
That could work, although on the C-17, I'd bet the inner gear is actually on a separate pylon. If I'm not mistaken, the inner gear on the -17 is actually higher than the outer gear, and only starts bearing weight at some certain weight. At least that's how I assumed it works. Possibly they do all touch the ground at all weights, but the outer gear just bears more load. See here:
Photo © Carlton Ho
That's actually similar to the center gear on the A340 (I think....can't remember if it's the A340 or the MD-11) - it can be off the ground at lighter weights. Or maybe it is the MD-11, because I found this shot....the full weight of the airplane is likely not on the gear yet, but the outer gear is touching the ground, and the center gear isn't yet:
Photo © Florian Kondziela
zanl188
Sun Mar 21, 2010 12:51 pm
Quoting vikkyvik (Reply 7):
The -52 lifts off flat. This is due to the wings angle of incidence being fairly high. Nose will go down after liftoff to keep climb rate under control. Looks awkward (it taxies sidewise too) but its worked for 50 years.....
lowrider
Sun Mar 21, 2010 2:30 pm
They may be wider, but with the emphasis in keeping weight down, they may not be significantly heavier, so the extra foot print area might not be needed.
Proud OOTSK member
Spacepope
Sun Mar 21, 2010 2:52 pm
Quoting ZANL188 (Reply 8):
Add the fact that the B-52 is also a 10-wheel aircraft, not 8. Those outriggers are used from time to time.
474218
Sun Mar 21, 2010 3:13 pm
It already been done:
Photo © David Lednicer
Sun Mar 21, 2010 3:52 pm
My guess is that the Hustler had the same problem as the Tu-144: limited space in the gear bays.
474218
Sun Mar 21, 2010 3:56 pm
Quoting Starlionblue (Reply 12):
Very thin wings. By using 16 small main wheels they kept the pavement loading low and fit the wheels in the gear bay.
OldAeroGuy
Sun Mar 21, 2010 4:01 pm
If you really need more wheels, the Trident had four main gear wheels on each of the two main gear posts.
https://www.airliners.net/photo/CAAC/...d=ea5ce3ddb0207d428cf38141941cf7ac
The Trident nose gear was also unusual. It was not mounted on the airplane centerline and retracted sideways.
Viscount724
Sun Mar 21, 2010 6:51 pm
That reminded me of the following recent (June 2009) video of a B-52 alert scramble at Minot AFB, North Dakota, with 15 B-52s taking off about 30 seconds apart.
http://www.youtube.com/watch?v=wJ7niLYSVFo
tdscanuck
Sun Mar 21, 2010 6:58 pm
Nope...it's cantilevered off the pair in a really bizarre arrangement. You can see the support beam in this photo:
http://www.google.com/imgres?imgurl=...&resnum=5&ct=image&ved=0CBEQ9QEwBA
Tom.
vikkyvik
Sun Mar 21, 2010 10:37 pm
Gotcha, thanks.
Quoting tdscanuck (Reply 16):
http://www.google.com/imgres?imgurl=...QEwBA
Wow, that is bizarre! Thanks for the link.
Jetlagged
Wed Mar 24, 2010 12:31 pm
No one has yet mentioned the most widespread example of this layout, the Tu-154.
Photo © Jose Muñoz - Iberian Spotters
Wed Mar 24, 2010 1:42 pm
IIRC, the Tu-154 gear sits entirely in pods in the wings, as opposed to most airliners where the struts are in the wings but the wheels end up in the fuselage. Thus there are severe space restrictions.
Jetlagged
Wed Mar 24, 2010 2:20 pm
Quoting Starlionblue (Reply 19):
True, as does the Tu-134 (but with four wheel bogies). So the podded undercarriage is as much part of Tupolev's design style of the time as anything else. If six wheel bogies were necessary to spread the weight of a new airliner it probably is not beyond the wit of man to find the space for them in the fuselage centre section. Boeing managed it with the 777.
Wed Mar 24, 2010 2:58 pm
It might have been beyond the wit of Soviet Man.
Seriously though, those pods probably have an area rule function anyway. Also they allow short struts.
Jetlagged
Wed Mar 24, 2010 3:43 pm
Quoting Starlionblue (Reply 21):
They certainly could have an area rule function, and the 154 had a very high maximum cruise speed (Mach 0.92 ish). It s a neat solution to stowing the bulky undercarriage in a thin wing. The wing anhedral helped the short struts too.
Spacepope
Wed Mar 24, 2010 5:51 pm
Tupovlev used those on tons of aircraft around the same time. Not only on the 134/154, but also on the 95 (Bear), 28 (Fiddler), 16 (Badger), 104/107/110/124 series and the original Tu-22 (Blinder).
It sure seemed in style at the time.
tdscanuck
Thu Mar 25, 2010 3:29 am
It is indeed an area rule thing; this particular implementation is called a Kuchemann carrot:
http://en.wikipedia.org/wiki/Anti-shock_body
Tom.
Users browsing this forum: No registered users and 16 guests
