Quoting 747400sp (Thread starter): It would be three two wheels bogies across, so could this work? |
Quoting FX772LRF (Reply 3): Could it work? Sure. Would it be feasible? Most likely not. Or else someone would have probably done it already. |
Quoting vikkyvik (Reply 4): Two 3-wheel bogies instead of three 2-wheel bogies. |
Quoting bohica (Reply 5): Another idea is to have four main landing gears with two wheels each like a B-52. |
Quoting bohica (Reply 5): Another idea is to have four main landing gears with two wheels each like a B-52. Ground clearance might be a problem though. |
Quoting bohica (Reply 5): I was thinking of a main gear arrangement similar to the C-17 which is a 2+1 configuration per gear. |
Quoting vikkyvik (Reply 7): The aft gears are too far back for the B-52 to rotate around them. I haven't seen it myself, but I've heard that the -52 actually lifts up the rear gear first, and has a nose-down initial climbout angle. You can see it here: |
Quoting 747400sp (Thread starter): Both Airbus and Boeing has said that the A32X and 737 family would be replaced by wider jetliners. |
Quoting ZANL188 (Reply 8): The -52 lifts off flat. This is due to the wings angle of incidence being fairly high. Nose will go down after liftoff to keep climb rate under control. Looks awkward (it taxies sidewise too) but its worked for 50 years..... |
Quoting Starlionblue (Reply 12): My guess is that the Hustler had the same problem as the Tu-144: limited space in the gear bays. |
Quoting 747400sp (Thread starter): So I am thinking, maybe they could design the a/c's with two nose gear like normal, but have a six wheels main gear. It would be three two wheels bogies across, so could this work? |
Quoting ZANL188 (Reply 8): Quoting vikkyvik (Reply 7): The aft gears are too far back for the B-52 to rotate around them. I haven't seen it myself, but I've heard that the -52 actually lifts up the rear gear first, and has a nose-down initial climbout angle. You can see it here: The -52 lifts off flat. This is due to the wings angle of incidence being fairly high. Nose will go down after liftoff to keep climb rate under control. Looks awkward (it taxies sidewise too) but its worked for 50 years..... |
Quoting vikkyvik (Reply 7): That could work, although on the C-17, I'd bet the inner gear is actually on a separate pylon. |
Quoting tdscanuck (Reply 16): Nope...it's cantilevered off the pair in a really bizarre arrangement. You can see the support beam in this photo: http://www.google.com/imgres?imgurl=...QEwBA |
Quoting Starlionblue (Reply 19): IIRC, the Tu-154 gear sits entirely in pods in the wings, as opposed to most airliners where the struts are in the wings but the wheels end up in the fuselage. Thus there are severe space restrictions. |
Quoting Starlionblue (Reply 21): Seriously though, those pods probably have an area rule function anyway. Also they allow short struts. |
Quoting Starlionblue (Reply 21): Seriously though, those pods probably have an area rule function anyway. |
