Faro
Fuselage Flex
Tue Apr 06, 2010 8:21 am
Just wondering how much flex is built into a modern fuselage (for example, in cm of deviation from nominal centerline). On the one hand, it would have to take the gravitational sagging of the tail end while on the ground and on the other the up-flex of the nose and tail ends at rotation and -to a lesser extent- in the cruise. For aircraft like the A346, this must be quite significant.
At what range of flex frequency would one get resonance (in clear air turbulence?) and does this get modelled during development or is it too remote a risk? Is fatigue due to such flex a long-term maintenance issue or not?
Faro
[Edited 2010-04-06 01:31:51]
The chalice not my son
oly720man
RE: Fuselage Flex
Tue Apr 06, 2010 2:21 pm
According to this
http://www.pprune.org/archive/index.php/t-329650.html
lateral bending seems to be more of a problem than vertical bending, for passenger comfort at least.
In the above link, it seems there was an interaction between wing bending and fuselage bending that was found in flight testing rather than through analysis, but was related to flying through turbulence.
tdscanuck
RE: Fuselage Flex
Wed Apr 07, 2010 6:01 am
Quoting faro (Thread starter):
It depends, a lot, on dimensions (length and diameter) and material.
Why would the nose and tail "up-flex" at rotation? The fuselage is still being pulled down by gravity, held up by the wings. Other than the nose gear load (which is pretty small), the fuselage loading in flight is slight more "saggy" because of the download on the tail.
A couple of Hz is typical, but it should be damped.
It's modelled. Your yaw damper won't work properly if you don't include the fuselage flexible mode (unless the mode is really small, like on little stubby fuselages).
If you're just talking about the oscillation mode..compared to the stress of normal flight, the stress from fuselage wiggle is relatively small. If you're talking about the entire stress picture, then yes, it's extremely significant. Fuselage bending stress is *the* major reason that crown skins are so much more prone to fatigue cracking than side or belly skins.
Tom.
Faro
RE: Fuselage Flex
Wed Apr 07, 2010 7:37 am
Quoting tdscanuck (Reply 2):
Pulled down by gravity and held up by the wings resulting in no wing flex once in stable climb, yes. But at rotation, the incident airstream has (with respect to the fuselage) a vertical component to it imparting an upward acceleration. Until the AoA is reduced and this acceleration subsides once in stable climb, the force of the upward acceleration should flex the fuselage up, or am I missing something here?
I see this in the same way as wing flex on rotation really: both the wings and the fuselage tips flex upwards on rotation with respect to an aircraft's center of gravity because both receive an upward acceleration due to AoA and both are less rigid than the structure surrounding that CG point.
Faro
[Edited 2010-04-07 01:05:50]
RE: Fuselage Flex
Wed Apr 07, 2010 8:02 am
Quoting oly720man (Reply 1):
Makes sense. Bendy roads tend to make people car sick, while driving over bumps is less nausea inducing. Also it is harder to hold your book steady when the plane is moving side to side than up and down.
cpd
RE: Fuselage Flex
Wed Apr 07, 2010 9:24 am
How about Concorde and fuselage flex! That's surely a good example of it.
Quoting Starlionblue (Reply 4):
Like being on a speeding express train on a twisting section of track trying to type on a laptop computer - it doesn't work well, same with trying to write. Very difficult and uncomfortable.
That's my everyday commute to work pretty well described.
474218
RE: Fuselage Flex
Wed Apr 07, 2010 2:39 pm
Quoting cpd (Reply 5):
Thats because the train shifts outboard on the track as it rounds a curve. If it didn't shift it could not turn. The outboard wheel has to travel a greater distance than the inboard wheel. So the wheels are beveled to make there diameter larger or smaller compensating for the distance traveled.
tdscanuck
RE: Fuselage Flex
Thu Apr 08, 2010 4:28 am
Quoting faro (Reply 3):
It imparts an upward force. There's no upward acceleration (except during the very brief period when the pitch-rate is changing) because the upward force from the wind is countered by the downward force of gravity.
You're missing that the fuselage doesn't generate anywhere close to enough lift to hold itself up (that's why you need a wing). So, even though you do get a small upwards force on the fuselage due to the AoA at rotation, it's not enough to overcome the fuselage's weight so the net load is still downward. Also, the downward force on the tail to rotate is larger than the upward force on the fuselage, so the portion aft of the wing has a higher down load than when just sitting static. And the upward force on the front of the fuselage is partly countered by the loss of the upward force from the nose gear.
Tom.
seattle
RE: Fuselage Flex
Thu Apr 08, 2010 6:35 am
Quoting 474218 (Reply 6):
Geeze... I work for the railroad and i didn't even know that. Learn new things about everything on here.
DocLightning
RE: Fuselage Flex
Fri Apr 09, 2010 5:55 pm
I could swear that when I see the 77W's on approach into SFO, it seems as if the fuselage is very slightly bent. I'm not shocked; no structure that long could be perfectly rigid and yet maintain a reasonable weight.
-Doc Lightning-
-Carl Sagan
Viscount724
RE: Fuselage Flex
Fri Apr 09, 2010 8:38 pm
Quoting DocLightning (Reply 9):
Optical illusion.
aer lingus
RE: Fuselage Flex
Fri Apr 09, 2010 9:12 pm
I seem to notice this too. Does it look like that the fuselage behind the wing is bent downwards?
As Viscount724 says, it could be an optical illusion. There could also be a possibility that the aircraft fuselage section on behind the wing is lower than the section in front of the wing like the 757. There was a thread about this not too long ago about the 757 fuselage.
Split Scimitar or Sharklets?
FlyingColours
RE: Fuselage Flex
Mon Apr 12, 2010 3:27 pm
Quoting Aer Lingus (Reply 11):
Speaking of the 757 has anyone seen the fuselage twisting and flexing during turbulence?
Its a scary sight for the passengers and does really get the attention of new crew. Its very noticeable if you are in the rear several rows looking forward.
On the 757 I've had a few very hard landings sat at the back and it's felt like we were bending to take the strain. That reminds me of the video of the MD80 doing landing stress tests or something and one flexes excellently and the other snaps in two...
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
Users browsing this forum: SCFirefighter and 11 guests
