readytotaxi
When Pilots Change Aircraft Type?
Wed Apr 21, 2010 2:34 pm
Is it easier for a pilot to train down to a smaller aircraft from a larger one or harder to train up?
Say 747 down to 737 or round the other way.
Growing older, but not up.
PGNCS
RE: When Pilots Change Aircraft Type?
Wed Apr 21, 2010 2:37 pm
Neither. It's different, not harder, and size doesn't matter. Every aircraft has unique characteristics that must be learned.
tdscanuck
Wed Apr 21, 2010 3:32 pm
Quoting readytotaxi (Thread starter):
The size isn't a factor, as PGNCS said. The major factors are the compexity, and the relative difference, between the two aircraft.
From a 757 to a 767 (or the other way) is a whole lot easier than a 777 to a 737 because the design of the flight decks and systems is so different.
Tom.
411A
Wed Apr 21, 2010 4:28 pm
Quoting PGNCS (Reply 1):
I would disagree.
With line operations, a much larger aircraft has much greater momentum that the smaller one, and this takes TIME for the new pilot to adapt.
Not especially difficult...just more time consuming, generally.
readytotaxi
Wed Apr 21, 2010 4:40 pm
Okay, thank you,I understand now.
And just one more question, take the Boeing family for example, which of their craft is the "easy" one to fly?
411A
Wed Apr 21, 2010 4:49 pm
Quoting readytotaxi (Reply 4):
Can't reply to that, as I have flown only one Boeing jet type, the 707.
The 707 required manual dexterity to fly properly, as all of its primary control surfaces, except for the rudder, were without hydraulic assist.
IE: heavy controls.
I personally line trained brand new First Officers (with about 300 total flying hours) onto the type, and once standard procedures were properly learned, they did very well.
tdscanuck
Wed Apr 21, 2010 5:15 pm
Quoting 411A (Reply 3):
That depends a lot on how the control laws are done. For manually controlled, or simple hydraulic boost controls, this is often true. For FBW controls, the momentum differences are much less apparent because you're controlling, approximately, on normal acceleration and roll rate, which are both momentum-insensitive.
The FBW ones (777 and 787) have the most predictable controls and most automation, so they're the "easiest" to fly. Not sure that they'd be called the nicest to fly though.
Tom.
PGNCS
Wed Apr 21, 2010 6:58 pm
I would disagree.
Feel free to disagree, but I went from the DC-9 to the B-727 to the MD-80 to the A-320 to the B-757/767 to the B-744 to the B-727 to the B-737 to the MD-80 to the B-757/767 to the L-1011 to the B-757/767 to the MD-80 and had no difficulties in any of the aircraft, though I had certain favorites, of course. When I said in my original comment "every aircraft has unique characteristics that must be learned," that adequately covers any inertial differences inherent in larger aircraft. I think that the B-744 and L-1011 are FAR easier to physically maneuver than many of their smaller brethren. That doesn't mean that understanding their systems are as easy, but that's a function of systems and performance knowledge not size, per se. The hardest schools I ever went to without question were A-320 and L-1011 Initial, two aircraft that have much more docile flight characteristics than the others I've flown, but also have much more complex systems knowledge requirements. The simplest of the bunch, the B-737, also has the most unpleasant flight characteristics in my opinion (especially the low-speed engine out stuff.) I feel perfectly comfortable with my views on this subject.
PGNCS
Wed Apr 21, 2010 7:07 pm
I haven't flown the B-707 or the B-777, but have flown some model of all the rest (except the B-787, obviously,) and for ease of maneuvering, predictability, and control harmony, as well as relatively simple and logically-designed systems, I have to say the easiest to fly and best of the bunch is easily the B-757 in every regard. It's also, uncoincidentally, my favorite Boeing to fly. My least favorite is the B-737, though it isn't especially difficult to fly, excepting V1 cuts, and especially engine failure when airborne just after V1, when it's a real handful.
2H4
Wed Apr 21, 2010 7:32 pm
Quoting PGNCS (Reply 7):
...And with that, I'd say our friend PGNCS has put the smack in the down and locked position.
Intentionally Left Blank
stratosphere
Wed Apr 21, 2010 9:34 pm
Well line maintenance seems to get no respect but I have gone to all the above aircraft with the exception of the L1011 and had to address issues and was expected by pilots to know the the differences sometimes all in one day. If you work for an airline with a diverse fleet and work the line and have years of knowledge you are worth your weight in gold but you would never get airline management or anyone else to acknowledge that.
stratosphere
Wed Apr 21, 2010 9:35 pm
Quoting 2H4 (Reply 9):
Agreed
c5load
Thu Apr 22, 2010 1:57 am
Quoting tdscanuck (Reply 2):
It seems as though the MD-11 was in class of it's own as far as getting used to flying.
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
Max Q
Thu Apr 22, 2010 3:48 am
The 727 was and still is the best handling Boeing narrowbody. The 757 handles reasonably well but nothing special, it just has a lot of power for it's weight. The 767 Handles like a dream, Boeing got this one just right.
In my experience bigger is always better, generally more stable with good response, the 747 is a good example. the advantage of size and more importantly, weight is the Aircraft simply goes where you want it to.
GGg
411A
As I'm quite comfortable with mine.
Are you, or have you been, an instructor on any of the types you've flown?
And, if so, how long?
wn700driver
Thu Apr 22, 2010 5:16 am
Quoting stratosphere (Reply 10):
Touche, A&P, touche. I've worked a line or two, and yeah, we're basically the Rodney Dangerfields of aviation. You know what really bugged me?
The way that the Airport franchise turned Joe Patroni into a Concorde check airman for the last movie. Seriously, was he not cool enough as a badass mech? It was really sad/funny as I knew a lead or two in my time that could have been well played by George Kennedy there. . . Ok, selfish rant over now.
One thing I think is always interesting is how few people realize exactly how extensive the differences type to type really are, even amongst series. For the record, most pilots I know are pretty good about this. But if you tell the average enthusiast (yes enthusiast, not just brainless media twit, lol), that there is a far greater difference in parts & construction from the 732 to the 739 than there is between say a 752 & 764, the looks one get could skin a tiger.
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
PGNCS
Thu Apr 22, 2010 7:24 am
Quoting 411A (Reply 14):
Like I made clear at the outset, that's fine.
Yes; DC-9/MD-80 7 years; A-320 4 years; B-757/767 2 years; B-744 about six months. Some A-320 and B-757/767 was concurrent. I was an examiner on the A-320 for 3 years as well.
Quoting Max Q (Reply 13):
I never understood why people like that thing. I couldn't wait to get off of it.
Given the above, obviously I disagree.
As I have said in other threads, I very much disagree. After the B-737 and B-727 my least favorite airliner to fly; it's control harmony is like a bad dream at low speeds with all four ailerons active.
[Edited for clarity.]
[Edited 2010-04-22 00:27:21]
Faro
Thu Apr 22, 2010 11:12 am
Quoting PGNCS (Reply 16):
Recall reading in a neighbouring thread that the L1011 comes out as the top control harmony champ, followed by the 757 and 747. The 767 was deemed too sensitive in roll and the 727 very vulnerable to a sinking flightpath on mishandled approaches.
Faro
The chalice not my son
Thu Apr 22, 2010 11:32 am
Staying within the same manufactures line of aircraft would have to be easier than going from one manufacturer to another. Aircraft generally have the same sort gear that does the same sort job, getting your head around all the acronyms they use to perform those functions is the hardest.
The flying is not so hard, same as a C-172, keep the blue side up, and land the main wheels first.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
411A
Thu Apr 22, 2010 12:02 pm
Quoting zeke (Reply 18):
Quite correct.
I noted that the L1011 type was many times more difficult for pilots to understand fully (systems-wise) because, if they had come from Boeing aircraft, the nominclature used was quite different with Lockheed....as was systems design, generally.
Parked next to my private airplane, is an aircraft owned by a former Boeing design engineer, now retired.
He mentioned one day....'When we first got a close look at the L1011, it was a huge wake up call for us, as we found the systems and autoflight operation/integration far superior to what we had at the time.'
Flying the L1011 is the easy part, fully understanding its systems, far more difficult.
I have been an instructor and senior check and training Captain on the L1011 for twenty years.
In that time I have trained quite a number of First Officers and Captains (mostly First Officers, however) and I personally found that many First Officers that had come from the B737 (for example) took just awhile longer in line training, to master the airplane, rather than if they had come from a larger type.
Why?
Number one reason was learning to use the automatics to their full potential.
Number two reason, the airplane was much larger, and the slam-dunk type of approach they were used to on the 737, simply could not be accomplished with the L1011, due to its size and weight.
2H4
Thu Apr 22, 2010 1:18 pm
Quoting 411A (Reply 19):
But isn't the "slam-dunk" capability more a function of the wing, spoilers, flaps, speedbrakes, etc?
411A
Thu Apr 22, 2010 3:46 pm
Quoting 2H4 (Reply 20):
Yes, however, when you have 380,000 pounds of airplane to deal with (versus 110,000 or so) , it takes more TIME to get it stabilized, with a reasonable rate of descent established, and engines spooled up properly.
Once learned, it is thereafter easy.
In addition, former Boeing pilots learned that the 'Boeing push' on landing, was not possible with the L1011.
PGNCS
Thu Apr 22, 2010 4:30 pm
Quoting faro (Reply 17):
I agree with the L-1011 being the champ in all aspects, and I imagine 411A will fully support that as well. There has never been an airliner (that I have flown, anyway) with better handling characteristics than the L-1011. I also agree with you about that the B-757 is the best harmonized of the Boeing aircraft, much better than the B-767 which is pointlessly sensitive in roll, most notably at low speeds. The B-744 is fine, but nothing special. The B-727 is relatively underpowered, which initially led to some low-speed sink issues, but as training improved and people were taught to plan ahead a bit better that problem went away (although it could still be mishandled, like any airplane.) I didn't dislike the B-727 so much for its handling qualities (which were OK, but nothing to write home about,) but for having among the worst ergonomics in any Western airliner, numerous ridiculous systems quirks, virtually no automation, and an extremely noisy cockpit. Some people loved it and elected to retire when they left the fleet. I never understood that, but I was happy to see both the plane and the senior pilots go.
I do agree with that wholeheartedly. Different manufacturers embrace different philosophies, which run like threads through their different designs. The autopilot on the B-757/767 and the B-744 work very similarly and either transitioning pilot would be at home with the other plane's autopilot very quickly, where a pilot coming from either fleet would have to be much more studious to master the A-320 autopilot, for example.
Quite correct.
I completely agree with this statement. The L-1011 was a delight to fly, and is my favorite type by a long shot. Having said that, it is an EXTREMELY sophisticated and complex aircraft, and learning its nuances are a bit daunting, particularly for someone coming off something like the incredibly simple B-737. Lockheed (and other manufacturers) have different terminology for everything. Most was better on the L-1011 (though I wonder about who decided to go with "latched" vs. "unlatched"...411A, do you know if those are historical terms at Lockheed?) but it is still different. Even now there isn't much I'd change about the L-1011 (well, OK, I would like glass) except I wish there were more of them left.
And he was right. Moreover certain features (e.g. DLC) are STILL better than what they've got now. The L-1011 has the best and most consistent autoland I have ever seen, by far.
Absolutely 100% correct. That was what my original point was trying to get at: that it doesn't matter that it's bigger as much as it is more complex. You have probably distilled the essence of my thoughts down better than I did. Thank you.
Why?
I generally agree with you, but again, I don't think mastering the automation or systems on the L-1011 are related to its size, rather its complexity. We saw the same thing with guys transitioning to the A-320 coming off of bigger and smaller aircraft. Actually the B-737 is relatively difficult to slam dunk compared to some other Boeings (here the B-727 wins,) but I do understand and respect the point you're making.
readytotaxi
Thu Apr 22, 2010 7:21 pm
You guys are brilliant with your in depth comments. Really adds flesh to the bones of the question. Thanks.
Experience wins out over Knowledge.
411A
Thu Apr 22, 2010 8:11 pm
Quoting readytotaxi (Reply 23):
And, it will continue to do so.
Make no mistake.
474218
Thu Apr 22, 2010 9:31 pm
Quoting PGNCS (Reply 22):
Quoting 411A (Reply 24):
And,it will continue to do so.
Truer words were never spoken! I rigged L-1011 flight controls for six (6) years on the production line, taught L-1011 flight controls for four (4) years in training and worked in the langing gear, hydraulics and flight control group in L-1011 Product Support for twenty (20) years and I still find the L-1011 control system daunting. I could make them the flight control systems work, but why it works the way it does, is way above may pay grade.
Lockheed had some of the brightest engineers in aviation and I was proud to have worked with them. I often said I didn't know everything about the L-1011, but I did need to who to ask!
Max Q
Fri Apr 23, 2010 1:10 am
The 757-300 handles a lot better than the -200. The 200 has a 'dead spot' in pitch on rotation and you also encounter it on landing. The Ailerons are not that responsive either, it is fairly sluggish in roll, it could use 4 ailerons like the superb 727.
Not sure why you think it handles so well PG, you are also the first person I have heard criticize the 727 for it's handling. I flew it for 7 years and enjoyed it tremendously. I think the 757 was a great step backward in control response.
Boeing did a great job on the 767, if you take care with it's responsive Ailerons I think it handles like a dream.
To each his own though, everyone likes different things !
GGg
Users browsing this forum: extender, GalaxyFlyer, SJPBR and 20 guests
