Quoting longhauler (Reply 7): Recall though, that McDonnell Douglas did offer a 2 engine version of the DC-10, named the "DC-10 Twin". |
Quoting travelavnut (Reply 5): If you remove engine No. 2 you would save quite a lot of weight. Although it´s impossible that something like that would offer better economics then 3 engines. I still wonder what kind of economics removing eninge 2 would give. Any experts wanna give this a go? |
Quoting 474218 (Reply 8): It was a "paper airplane" just like the L-1011-600 Twin-Star. Neither were ever offered to the airlines just sketches on paper. |
Quoting spacecadet (Reply 12): Does having that long cowling with all that empty space in front of the engine change anything about the characteristics of the #2 engine vs. the other two? I would think the air rushing in there would get "concentrated" or compressed a bit more than the other two engines before it reaches the engine itself. |
![]() Photo © Brian Harrison | ![]() Photo © Norman Gage |
Quoting CitationJet (Reply 16): I am surprised that no one has mentioned the two engine 727 |
Quoting daviation (Reply 15): the cockpit crew made up for it with the smoothest landing (in RIC) that I have ever experienced. |
Quoting Starlionblue (Reply 18): Going to nitpick here and say that very smooth is not a requirement for a good landing. It is just a bonus, and really only for the pax. |
Quoting FlyHossD (Reply 19): Yes. I'll never forget that one, though I usually said it as "Check Essential, cover the bus." The 727 was (is) a fine, fine machine. |
Quoting Starlionblue (Reply 18): only for the pax |
Quoting kimberlyrj (Reply 23): Is the number 2 engine used as the others on the ground? I mean the same amount of thrust? Or is it used less or more? I was just thinking that the height of the number 2 engine could cause problems at certain airports to terminals and buildings? |
Quoting kimberlyrj (Reply 23): Also, after landing is the number 2 engine kept running or is it shut down before the other engines? Thinking logically I guess the number 2 engine would be kept running when the MD11 aircraft arrives at the stand? I mean there is less risk of ingestion due to its position? |
Quoting CosmicCruiser (Reply 24): We usually shutdown #2 on the taxi in because 1 & 3 have the hydraulics on them for brakes. |
Quoting Starlionblue (Reply 10): Here's an MD-11 with an afterburner fitted to #2. |
Quoting Fly2HMO (Reply 26): Ahh so that was the long forgotten MD-11 Sport version that MD offered for hot and high airports wasn't it (This would have been the perfect troll thread |
Quoting KELPkid (Reply 27): Close to this topic: Didn't McDD create a special DC-10 version for either AeroMexico or Mexicana that had Pratt & Whitney JT9D's so that they could get decent takeoff performance at MEX? |
Quoting KELPkid (Reply 25): Any sort of cool down period that has to be observed before shutting it down? Seems like the MD-11 carries a bit of thrust on a typical stabilized approach |
Quoting MrFord (Reply 28): Quoting KELPkid (Reply 27): Close to this topic: Didn't McDD create a special DC-10 version for either AeroMexico or Mexicana that had Pratt & Whitney JT9D's so that they could get decent takeoff performance at MEX? The DC-10-15, with CF6-50C2Fs tho, derated Series 30 engines. |
Quoting KELPkid (Reply 27): Didn't McDD create a special DC-10 version for either AeroMexico or Mexicana that had Pratt & Whitney JT9D's so that they could get decent takeoff performance at MEX? |
