Quoting bueb0g (Thread starter): Is an overrun preferable to taking an unsafe aircraft into the air? Take the Concorde crash - if V1 training was different, the captain - once aware he was traling heavy flames - may well have aborted. Now, I don't know about the rest of you but I think Concorde sitting in the grass, with possibly no fatalties is better than the actual outcome of that dreadful accident. |
Quoting bueb0g (Thread starter): I could find countless examples of accidents where the outcome would have been less severe had the crew rejected after V1 |
Quoting bueb0g (Thread starter): In fact, V1 is often misleading. I remember one case where a BMI baby 737 aborted its takeoff significantly after V1, when the captain noticed the aircraft to be severely out of trim. Judging that he had enough space to stop, and deciding that if he did overunn it would be preferable to flying an uncontrolable plane, the crew was able to bring the 737 to a safe stop within the confines of the runway. |
Quoting bueb0g (Thread starter): Is an overrun preferable to taking an unsafe aircraft into the air? |
Quoting bueb0g (Thread starter): I remember one case where a BMI baby 737 aborted its takeoff significantly after V1, when the captain noticed the aircraft to be severely out of trim. Judging that he had enough space to stop, and deciding that if he did overunn it would be preferable to flying an uncontrolable plane, the crew was able to bring the 737 to a safe stop within the confines of the runway. |
Quoting 777236ER (Reply 1): From the BEA report (public domain): |
Quoting bueb0g (Thread starter): I think Concorde sitting in the grass, with possibly no fatalties is better than the actual outcome of that dreadful accident. |
Quoting CosmicCruiser (Reply 4): I can't believe you assume that the Concorde would be sitting in the grass after the mentioned abort. |
Quoting bueb0g (Thread starter): Is an overrun preferable to taking an unsafe aircraft into the air? Take the Concorde crash - if V1 training was different, the captain - once aware he was traling heavy flames - may well have aborted. |
Quoting Woof (Reply 3): You just don't have the time to go through a checklist and make an informed decision before the decision gets made for you (ie the runway ends). |
Quoting Lowrider (Reply 10): To reject beyond V1 for anything but the most catastrophic circumstances is extremely hazardous. I would only consider it for things like multiple engine failures, massive structural failure, or collision with another aircraft of vehicle. |
Quoting Illini_152 (Reply 9): Ask DJ AM about aborts after V1 for blown tires. |
Quoting bueb0g (Thread starter): I could find countless examples of accidents where the outcome would have been less severe had the crew rejected after V1, so my question is whether it should be regarded differently? |
Quoting Vmcavmcg (Reply 13): When are the V1 speeds reliable? Just think about it for a moment and I would argue the V1 speeds are only valid when the aircraft is new and on the same runway where the V1 speeds were tested. The V1 speeds are based on new brakes, new tires a known runway surface (flight test) and flight test pilots. I don't know of too many aircraft that fall into that condition. There was an AA DC-10 that rejected the takeoff well prior to V1 and couldn't stop within the runway. |
Quoting Vmcavmcg (Reply 13): The NTSB was extremely critical of the entire V1 concept and the way it was used. |
Quoting thegeek (Reply 14): What did they suggest? A fudge factor? Testing on worn brakes & tires, or what? |
Quoting cobra27 (Reply 17): Think about it if fully loaded 747 can stop a v1 at lets say 135 knots |
Quoting cobra27 (Reply 17): so I said yes cou can stop and he was happy. Am sure that some by the book guy wont agree with me |
Quoting Vmcavmcg (Reply 13): Quoting bueb0g (Thread starter): I could find countless examples of accidents where the outcome would have been less severe had the crew rejected after V1, so my question is whether it should be regarded differently? Please provide just one! |
Quoting cobra27 (Reply 17): I was asked that question on interview, and he specifically said LONG runway so I said yes cou can stop and he was happy. Am sure that some by the book guy wont agree with me |
Quoting thegeek (Reply 18): How is it possible to pass V1, without passing Vr, on a "LONG" runway |
Quoting Vmcavmcg (Reply 13): The V1 speeds are based on new brakes, new tires a known runway surface (flight test) and flight test pilots. |
Quoting thegeek (Reply 18): How is it possible to pass V1, without passing Vr, on a "LONG" runway? |
Quoting Pihero (Reply 21): It's not possible as V1 at most equals Vr |
Quoting DH106 (Reply 20): AA191 at Chicago, 1979? |
Quoting tdscanuck (Reply 22): With carbon brakes, the stopping performance doesn't change much with wear anyway, just the heat capacity. |
Quoting tdscanuck (Reply 22): On the flight test pilots side, that's a harder issue to deal with, but it's incorporated into the calculations by assuming a delay between the critical event (usually engine failure, but could be some other things like fire) and the rejection. So, although V1 is the decision speed for the pilots, the calculations behind it assume that the actual event happened at a slightly lower speed and that the pilots only got the chance to react by V1. In other words, the normal delay you expect from a normal pilot who's not expecting an event is built into the V1 calculation |
Quoting tdscanuck (Reply 22): Optional on Boeing, standard on Airbus. |
Quoting Vmcavmcg (Reply 24): Quoting DH106 (Reply 20): AA191 at Chicago, 1979? I think you might want to re-read the accident report. There is no mention of rejecting above V1. The accident led to the V2+10 concept rather than taking your airspeed and if you are above V2 using pitch to achieve V2. |
Quoting DH106 (Reply 26): Granted, but you asked for an example of an accident where the outcome would have been less severe had the TO been rejected after V1. |
Quoting Vmcavmcg (Reply 27): Quoting DH106 (Reply 26): Granted, but you asked for an example of an accident where the outcome would have been less severe had the TO been rejected after V1. And this is your opinion? Sorry, but I disagree. Had the crew kept the speed they had rather than trading it for altitude as was the procedure then, the results would have been different. |
Quoting DH106 (Reply 28): By that narrow criteria AA191 is surely a candidate. |
Quoting DH106 (Reply 28): You're confusing the primary cause of this accident |
Quoting tdscanuck (Reply 22): Quoting Vmcavmcg (Reply 13): The V1 speeds are based on new brakes, new tires a known runway surface (flight test) and flight test pilots. That's not actually true...braking performance testing is done on partially worn brakes, and the worst case (MTOW RTO at V1) has to be done with fully worn brakes. With carbon brakes, the stopping performance doesn't change much with wear anyway, just the heat capacity. |
Quoting Vmcavmcg (Reply 29): Quoting DH106 (Reply 28): By that narrow criteria AA191 is surely a candidate. I disagree. They were we above Vr when the engine departed. The runway available for them to stop within the confines of the airport was insufficient. Now we add in the complete loss of the #1 Hydraulic system. There is no way rejecting the takeoff would have been an option. In addition, the crew did not know the engine had departed the pylon. |
Quoting Vmcavmcg (Reply 29): Quoting DH106 (Reply 28): You're confusing the primary cause of this accident I am not. Had the current engine out procedures been used then, the crew would have had a chance. But, the cause is not an issue. Your statement about rejecting the takeoff V1 and Vr is just absurd. |
Quoting Vmcavmcg (Reply 29): As PiHero stated, this argument had been on this forum many times. The people who argue the most about why it's a good idea are the people who are not in the industry. YOU DO NOT REJECT ABOVE V1!!!!!! |
Quoting tdscanuck (Reply 22): However, most flight crews don't have the data to hand in a line environment to quickly figure out which situation you're in, and an engine failure near V1 is no time to be trying to remember if V1 was moved to match Vr or not. |
Quoting tdscanuck (Reply 22): The flip maneuver (raising Vr to equal V1, or at least raising it some amount above the strictly required speed to fly out at the normal V2) is an improved climb takeoff...using more runway to gain more speed. |
Quoting DH106 (Reply 26): but you asked for an example of an accident where the outcome would have been less severe had the TO been rejected after V1. The engine separation occured at rotation and a rejection at this point would certainly have saved at least 2 lives (the 2 killed on the ground). |
Quoting DH106 (Reply 31): Nevertheless, HAD they rejected at Vr then at the very minimum, 2 lives would have been saved. |
Quoting DH106 (Reply 31): Since the area beyond R33R was pretty sterile that had to be a better outcome than killing people on the ground as did happen. |
Quoting Pihero (Reply 32): I think you're freely playing with a tragedy |
Quoting Pihero (Reply 32): If you think that you could have stopped that 'Ten without a problem on the remaining available runway, then that's fine, and you're the man. Or are you really ? |
Quoting DH106 (Reply 34): Yes, you're quite right Pihero, I was getting too involved in reacting to Vmcavmcg's beligerance |
Quoting DH106 (Reply 31): Once and for all - I'm am not arguing with the princple you state above, merely supplyingy an example for which you challenged |
Quoting Vmcavmcg (Reply 35): I think you are taking way too many liberties with this issue and you really need to read the NTSB report |
Quoting Vmcavmcg (Reply 24): Quoting tdscanuck (Reply 22): Optional on Boeing, standard on Airbus. Granted it's optional on the Boeing but could you elaborate on the Airbus? SRS provides the engine out speeds V2 or higher if you have that and a minimum of 120FPM climb. So, I am somewhat stumped as to what you are trying to point out. |
Quoting Pihero (Reply 32): Quoting tdscanuck (Reply 22): However, most flight crews don't have the data to hand in a line environment to quickly figure out which situation you're in, and an engine failure near V1 is no time to be trying to remember if V1 was moved to match Vr or not. You're quite wrong. Through the use of our RTOW tables during our takeoff preparation, we know exactly where we are in terms of performance, what kind of limitation we're facing, and by how much...That done, we respect those values and the procedure. |
Quoting Pihero (Reply 32): Probably a typo but you can't "raise your Vr to match your V1 but rather the opposite, as Vr is fixed and depends on the aircraft weight, as both FAR and JAR agree : |
Quoting Pihero (Reply 32): JAR 25.107 Subpart B / FAR 25.107 Subpart B |
Quoting tdscanuck (Reply 37): When you fire up Boeing performance software it will default to Improved Climb = None...it will calculate balanced field V1/Vr/V2 unless you tell it not to. Airbus (I was told by a performance instructor) is the other way...by default it will do an unbalanced-field calculation (equivalent to Improved Climb ON for Boeing), and you have to flip it back to do a balanced-field. It's nothing to do with SRS |
Quoting DH106 (Reply 36): You're still missing the point I'm trying to make. However, in the accident as it actually happened, the aircrat impacted nearly a MILE (4600') to the NW of the runway and over a 1000' to the left of the extended centerline, an area which unfortunately contained a trailer park and it killed 2 people on the ground. Since the immediate runway overrun area was pretty much sterile I was merely making the point that these 2 people would have escaped and thus the outcome, in terms of fatalities, would have been better. |
Quoting Pihero (Reply 32): In fact, our performances are computed with a V1 range such as .84 |
Quoting tdscanuck (Reply 37): The FAR/JAR definition is the *minimum* Vr. There's nothing wrong with raising Vr when you're on a longer runway to improve initial climb performance. It's done frequently in service. |
Quoting tdscanuck (Reply 37): hat part defines the lower floor for Vr...as long as you have a runway long enough to have V1 get high, you're perfectly welcome to have Vr be higher than the minimum (up to tire speed limit, usually). |
Quoting tdscanuck (Reply 37): Airbus (I was told by a performance instructor) is the other way...by default it will do an unbalanced-field calculation (equivalent to Improved Climb ON for Boeing), and you have to flip it back to do a balanced-field. It's nothing to do with SRS. |
Quoting Pihero (Reply 40): |
Quoting Vmcavmcg (Reply 38): Please re-read my question. I am well aware of what the OPS will do for Boeing, but I think you are confused on what it will do with Airbus. So, if you could elaborate on your statement with respect to Airbus that would help clarify things. |
Quoting Pihero (Reply 40): The Airbus programs (and I might add that on this case AI was THE pioneers as a computerised performance was already in service for the A-300 and A-310 in the mid-1980s ) gives you the best performance achievable on the actual conditions |
Quoting Pihero (Reply 40): It really galls me that people haven't still accepted any of the Airbus methods and still think that the ole Boeing way is better |
Quoting tdscanuck (Reply 37): When you fire up Boeing performance software it will default to Improved Climb = None...it will calculate balanced field V1/Vr/V2 unless you tell it not to. Airbus (I was told by a performance instructor) is the other way... |
Quoting tdscanuck (Reply 42): You said it yourself: |
Quoting tdscanuck (Reply 42): Airbus will always go to best performance achievable for the conditions, Boeing (by default) will go for balanced field length. Either one can do it the other way, they just choose different defaults. |
Quoting tdscanuck (Reply 37): Airbus (I was told by a performance instructor) is the other way...by default it will do an unbalanced-field calculation (equivalent to Improved Climb ON for Boeing), and you have to flip it back to do a balanced-field. It's nothing to do with SRS.... |
Quoting Vmcavmcg (Reply 43): My point was your statement was incorrect. Boeing and Airbus take a very different approach to TO performance. |
Quoting Pihero (Reply 44): So, if I understand you well, : -Airbus goes for the best performance achieved for the conditions as a default - Boeing is satisfied that the balanced V1 perf is valid for most cases, that's why it's taken as default, right ? |
Quoting Pihero (Reply 44): You could understand that it's a lot different from : |
Quoting Pihero (Reply 44): ...which is wrong as we never revert to the balanced V1 calc (a bloody waste of precious time, especially when the codes for the limitations are well apparent, which was why I wrote that at all times in my takeoff prep I knew where I stood in terms of performance.). |
Quoting GingerSnap (Reply 47): But say an aircraft had an extremely low V1 speed due to a light load |
Quoting GingerSnap (Reply 47): But say an aircraft had an extremely low V1 speed due to a light load (or a positioning flight). Would the V1 speed be misleading in terms of "you must take off from here on". |
Quoting CosmicCruiser (Reply 48): Generally from what I always see under those circumstances V1 = Vr. There would be no reason to have a low V1. I've been very light taking off at CDG for FRA and V1 & Vr = 135kts. |
